Garage Lighting - Page 2 - LotusTalk - The Lotus Cars Community
post #21 of 27 (permalink) Old 12-04-2008, 05:52 AM
Inactive
dstevens's Avatar
High performance T8 lamps are significantly better than T12 fixtures, but take the time to learn about system efficacy and compare between different fixtures, as there is a large variance. T5 fixtures are better under some temperature conditions, but rarer and more expensive than T8.
2005 Elise with Honda engine
dstevens is offline
post #22 of 27 (permalink) Old 12-04-2008, 06:59 AM
SirLotus's Avatar
Fluorescent tubes are the best light source in a working environment with low ceilings because there will be less shadows cast from a linear source. The longer the tube the better the coverage without shadows. In a garage with a regular ceiling height of between 8 - 12 feet, get those fixtures as high as you can. If you are concerned about getting the correct foot candles there are many calculators on line. No overhead light source is going to give adequate coverage on the work area, therefore quality, point source inspection lighting is needed to supplement.
SirLotus is offline
post #23 of 27 (permalink) Old 04-05-2009, 03:08 PM
Ravenbk's Avatar
if you have the $$, there are some really interesting LED solutions out there (not talking about the cheap Chinese crap)
Ravenbk is offline
post #24 of 27 (permalink) Old 04-05-2009, 03:37 PM
Desperado's Avatar
I have 3 of these in my 2.5 car garage with light gray epoxy flooring - works well.
Six Tube Fluorescent Fixture - Lighting & Power - In Your Garage - Griot's Garage
I used the full spetrum (daylight) bulbs too.
''Whaddya hear, Starbuck?''
''Nothing but the rain.''
''Well grab your gun and bring in the cat.''
Desperado is offline
post #25 of 27 (permalink) Old 04-05-2009, 05:08 PM
steuspeed's Avatar
I finally added 2 more of the Griot's twin tube fixtures.
steuspeed is offline
post #26 of 27 (permalink) Old 04-05-2009, 07:17 PM
craracer's Avatar
I have five 8ft cold-start ballasts in my garage. If you live in a colder climate, the cold-starts are a must.
It also helps if your walls are painted white as they will reflect a lot of light. It made a huge difference in my last garage (haven't got to painting my current garage walls).
craracer is offline
post #27 of 27 (permalink) Old 05-20-2009, 04:48 PM
my opinion would have to be 2 lamp 8' t5's (2 x 4' long). make sure you get high outputs, they will start/work better in the cold. only problem with t5's are as dstevens said, quite expensive, but im always amazed at the light output whenever i enstall t5's
hunter is offline
  LotusTalk - The Lotus Cars Community > Community > Garage Majal
