newbie -14 3/4" Jack height from harbor freight... - LotusTalk - The Lotus Cars Community
post #1 of 27 (permalink) Old 02-28-2012, 04:29 AM Thread Starter
Gamera The Atomic Turtle
komiko's Avatar
i was wondering if this low profile jack's 14 3/4" max height was good enough to raise the Elise high enough to get jack stands installed for working under the car. I'm going to be using the jack helper to put jack stands under the lift kit cylinders (monkey wrenches/tesprit's kit) on the rear of the car for maintenence. Have not bought jack or jackstands yet. Was hoping for some experienced comments. Thanks.
Lotus Elise #134 - S O L D BOE REV400 street car built at BOE in KC. , Stock motor, low boost w/stock cat/mani, 292whp, (5.95 lbs/hp) passes all 50 states emissions/OBD, BOE ST exhaust, ACT HDSS, BOE Clam Hinge, BOE Oil Cooler Relocation, BOE Surge Tank/750cc injectors, BOE Race Links, MWR Rear Lift Kit etc. 0-100 = you bet!
Build thread :
https://www.lotustalk.com/forums/f160...seline-114302/
komiko is offline
post #2 of 27 (permalink) Old 02-28-2012, 04:45 AM
XHILR8N!'s Avatar
I just this last weekend picked up one of their top jacks, 3000 lb I think, that goes to over 19" vertical. This because of exactly what you mentioned. For the rear the smaller jack is no problem. For the front I was using Sector's flat topped stands and needed more height. If you have short stands then maybe the smaller one woulod work.
Thing for me is I do not want to have to max out a jack. Have already busted up the fiberglass on the right by not placing the jack far enough inboard a few years back.
The larger jack is so much easier to use. It's not at all stressed. And having one for each side was great this weekend after installing shocks and adjusting ride height.
2005 Elise LRG, track prepped ,
2016 370Z Nismo
2013 Bentley Continental GT Speed 2019 Lexus LC500
XHILR8N! is offline
post #3 of 27 (permalink) Old 02-28-2012, 04:57 AM Thread Starter
komiko's Avatar
ok - lets review - you have 2 jacks?(I'll need to do the front also eventually) Do you have the link or model # of what you bought - (harbor freight?) I'm asking because one of the reviews on the 17 1/2 jack came back as as only 14" in real life, and the buyer was angry about the false advertising - i'll get back on their site and look around some more.. I'm ok with the sector 111 pin safety lock jack stands - they look sweet. Thanks again.
Build thread :
komiko is offline
post #4 of 27 (permalink) Old 02-28-2012, 05:23 AM Thread Starter
komiko's Avatar
ok - i found it - $199 - did you buy 2? or am i misreading your post? thanks again.
Build thread :
komiko is offline
post #5 of 27 (permalink) Old 02-28-2012, 09:31 AM
metrocube's Avatar
I take it you don't realize that this depends on the height of the jack stands?
I never like putting the car at extreme angles, so I lift the car 6" on one side then put boards under the wheel. Then lift the other side of the car the rest of the way to get a jackstand under it. Minimizes the chance the single jackstand will shoot out from under the car while you're trying to get the other side up to the same height.
metrocube is offline
post #6 of 27 (permalink) Old 02-28-2012, 10:42 AM
www.theapexinn.com
kestrel74's Avatar
Their 79.00 one ( that you can get for less with a coupon or sale ) is fine. and yes, you can get a stand or ramps underneath.
Elise #2292 (SOLD) / CO / Starshield / Nitron Sport SA / RTDbrace / Uprights machined / Down Low rails / DBA 4000 Wiper Slot Rotors/ V1 / SS lines w/Pagid Black / G-Pan / Odyssey PC680 with RLS Bracket / Difflow 5 Element diffuser / Stebel Nautilus horn
www.theapexinn.com
kestrel74 is offline
post #7 of 27 (permalink) Old 02-28-2012, 11:10 AM Thread Starter
komiko's Avatar
yup - i guess s111's stands are the ones i want as i need pin locks, not those ratchet things that have already dropped a car and crusheed one of our members. The S111's stands - those go fairly high. Your boards sound smart. This will be my first jack stand lift, so far i've only lifted a side with a jack to change from summer tires to storage tires. Don't want to get myself killed, don't want to get the car killed. Thanks.
Build thread :
komiko is offline
post #8 of 27 (permalink) Old 02-28-2012, 12:23 PM
metrocube's Avatar
Yeah, the S111 stands are VERY tall. I would strongly advise placing at least three 2"-thick boards under a wheel as a half-way step so that you don't get such an extreme angle on the flat top stands.
I go so far as to get the rear wheels on top of race ramps first to make sure the front to back angle isn't so extreme as well.
post #9 of 27 (permalink) Old 02-28-2012, 02:09 PM
XHILR8N!'s Avatar
The Sector stands are what I have, yes tall. I have two jacks from Harbor Freight, the smaller US General 1.5 ton and the Pittsburgh 3 ton.
I've had the smaller one for years, it's good for our little cars. When I went to use the (very nice) Sector stands, I went to HF the next day. Just plain scared of using a jack that is near vertical on the front B jack points.
Very glad to have a more robust jack as well.
Rhinoramps are very useful. That jack helper is a must, should come with the car.
Very good idea to raise the car gradually one side at a time.
While under there mark the C and D lift points perhaps with the arrows available on this board.
2016 370Z Nismo
XHILR8N! is offline
post #10 of 27 (permalink) Old 02-28-2012, 02:16 PM Thread Starter
komiko's Avatar
So are the S111 stands what alot of folks go with? are they "too tall"?
Build thread :
komiko is offline
post #11 of 27 (permalink) Old 02-28-2012, 02:49 PM
addertooth's Avatar
I use the Sector111 "flat jacks" which have the rubber pad on top (4 jack stands), to work on the car. I use the 1.5 ton harbor freight aluminum racing jack to lift the car onto the stands. I sometimes use a hockey puck (courtesy of BWR) on top of the aluminum racing jack lift point to get that extra inch to get the car on top of the sector111 flat jacks. With any lifting hydraulic jack, make sure it is rolling freely as you lift, so the lift point does not move reletive to the car's chassis. I refuse to pay dealer price for an oil change.
addertooth is offline
post #12 of 27 (permalink) Old 02-28-2012, 02:57 PM
Giantmcm's Avatar
I own one of these jacks and absoluetly LOVE it. It skys high so I can actually jack my 4 runner up, but is still LOW pro to get under the lotus and my wife's passat. A great jack for the price. If you are ok with steel, if you want aluminum, then I would find another like it then.
Low Profile Floor Jack - 2 Ton, Rapid Pump® Jack
Maverick ML8 - Other daily
Giantmcm is offline
post #13 of 27 (permalink) Old 02-28-2012, 03:42 PM Thread Starter
komiko's Avatar
I looked at that today too! (when I was searching) I almost bought it on the spot, then saw "no rubber pad", but that cant be too hard to fix. How do you work with the unpadded top? Hockey puck or something else?
Build thread :
komiko is offline
post #14 of 27 (permalink) Old 02-28-2012, 03:44 PM Thread Starter
komiko's Avatar
I'm with you on that one. $250 in NYC.
Build thread :
komiko is offline
post #15 of 27 (permalink) Old 02-28-2012, 04:48 PM
hroundy's Avatar
Hockey puck works.
BTW there is a Harbor Freight in Amherst on 101a on left coming from Nashua. It quite a ways from Nashua, I almost gave up thinking I missed it.
Howard
2005 Elise AP LSS hardtop
hroundy is offline
post #16 of 27 (permalink) Old 02-28-2012, 08:25 PM
Giantmcm's Avatar
It really is a great jack, completely endorse this jack in terms of ability and convience of use. I just put a soft pad on the jack head and called it good. Works great, no slippage, and awesome height/smoothness of factor. Also love the handle design and the turn knob to lower the jack with. VERY nice stuff.
Giantmcm is offline
post #17 of 27 (permalink) Old 02-28-2012, 08:49 PM
Mulholland>SCC
agirls's Avatar
I was going to point out that the lift kit is NOT for jack stands, but I suppose it would be fine with a flat top jack stand.
Toys-
05 Ducati S4R
02 Suzuki SV650
09 Kawasaki KLX250
agirls is offline
post #18 of 27 (permalink) Old 02-29-2012, 11:59 AM Thread Starter
komiko's Avatar
ya - that's the one i'm buying but could you elaborate on your soft pad? (If it was a diaper out of the hamper, please disregard this request)
Build thread :
komiko is offline
post #19 of 27 (permalink) Old 02-29-2012, 12:01 PM Thread Starter
komiko's Avatar
I hear ya - there are others doing this no problem - they are using the jack helper to get the back up, and installing the jack stands directly under the lift cylinders. Voila! ONE STEP!!!!! (I think this is when you are ONLY lifting the rear..ie oil changes) But you are correct - the lift kit is for.....lifting.
Build thread :
komiko is offline
post #20 of 27 (permalink) Old 02-29-2012, 12:04 PM
Mulholland>SCC
agirls's Avatar
That's not quite what I meant. I wasn't being a smartass. There are stickers on it saying not for jack stands and since most, if not all but one brand of jack stand are curved, it would not be safe which is why I said I suppose it would be fine with flat top stands as it would be safer.
Toys-
05 Ducati S4R
02 Suzuki SV650
09 Kawasaki KLX250
agirls is offline
  LotusTalk - The Lotus Cars Community > Community > Garage Majal
