Will the EZ lift work with the Elise? - LotusTalk - The Lotus Cars Community
post #1 of 8 (permalink) Old 02-21-2010, 07:08 PM Thread Starter
ttime4four's Avatar
Just curious if this would work given the complicated Elise jacking / jackstand sequence?
EZ CAR LIFT - FREE-STANDING USE-ANYWHERE CAR LIFT! FAST. SAFE. STRONG. EASY.
ttime4four is offline
post #2 of 8 (permalink) Old 02-22-2010, 09:34 AM
TimMullen's Avatar
Sure it will work. And it will be lifting the car from the same wrong places that caused QBALLs car to "Qball" off the lift.
The problem with the Elise is that the rear jacking points (the "C" & "D" points) are under the under-tray. You have to remove the under-tray to get to the support points.
Unless you get a (highly recommended) Jack Helper that lets you lift the rear of the car in one operation (but you still have to remove the under-tray to support the car).
Or you get one of the "four post lift adapters" that one of the vendors made (I believe another company makes now makes it) that bolt onto the rear of the car and provide lift points for the various lift options.
94 Miata R Package - Black
TimMullen is offline
post #3 of 8 (permalink) Old 02-22-2010, 11:09 AM Thread Starter
ttime4four's Avatar
Thanks for the reply - still a noob here and took delivery of my Elise SC on Saturday. I want to get under this thing, take off the wheels and look around.
Assuming this is the part you are referring to...and cheaper to boot.
'08 Elise SC Storm Titanium
post #4 of 8 (permalink) Old 02-22-2010, 11:59 AM
TimMullen's Avatar
Yep, that's the Jack Helper - it is worth it. I put it off for a long time then kicked myself for not getting it sooner.
I allows you to lift the car, but you still need to support it after you get it up. Most use it to lift the car to put ramps under the wheels (I do). Then you can remove the under tray and do oil changes etc. You can also just back up on the ramps (I did that before I had the Jack Helper) which is also very easy. The problem is after you get the back end up in the air and the under tray off. Then you need to get it on jack stands to work on the wheels, etc. NEVER get under a car supported only by a floor jack (they been known to let go suddenly).
So, you can back up on ramps or use a jack helper to lift it and place the ramps (use RhinoRamps not the higher metal kinds). The remove the under tray, then use the jack helper to lift again and place the jack stands under the rear sub-frame (the lift points "C" - the "D" lift points are farther back under the rear diffuser). Then you can lift the front - lift by the "A" point on each side and place the jack stand under the "B" point.
Best way to lift an Elise is a drive on four post lift. That picks up the whole car by the wheels and you can get to the underside then. A good four post lift can also have built in "jack trays" that can then be positioned to lift the car while it's on the lift (that sounds silly, but you need a way to raise the car off it's wheels so you can do brake and suspension work). But that is more expensive and most importantly, requires a tall enough garage.
post #5 of 8 (permalink) Old 02-22-2010, 01:14 PM
JWA
JWA's Avatar
LotusTalk member tesprit designed and made those originally, and now Thomasio, of Really Light Stuff is producing them. A search should bring up the threads.
JWA is offline
post #6 of 8 (permalink) Old 02-22-2010, 06:19 PM
British_Marques's Avatar
I use the Rhino ramps and Jim jack helper most of the time. But Phil has a similar Model and has used it without incident on the Elise constantly.
2005 Elise Starlight Black
1991 Elan Monaco White
1973 Triumph Stag, second owner.
1975 XJ12C Jaguar pillarless coupe.
1960 Daimler Limo, drives great look like hell, project in the works.
British_Marques is offline
post #7 of 8 (permalink) Old 02-23-2010, 03:27 AM
Chococar's Avatar
There's a good thread on lifts. I bought a scissors lift that is great! It lifts my Elise up to the ceiling and makes it super easy to work under the car. I can even sit on my little roller stool to do most things.
Chococar is offline
post #8 of 8 (permalink) Old 02-23-2010, 08:47 AM
TimMullen's Avatar
Thanks... I bought mine form the original batch Tesprit made, but my mind was just blocking out the name (they say the second thing to go is the mind). High quality, perfect fit. Recommended even if you don't have a lift as it might make it easier for some shop to lift your car and not do a Qball...
The problem with lifting the car from the "A" through "B" jack points is that it barely keeps the car on the lift. I was at a shop and out of curiosity, we used a two post lift once to see how to lift my car. Placed the lift arms at the "B" points up front, and the "A" points in the rear. Lifted the car so the tires were a couple of inches off the ground. Pushed gently on the rear spoiler of the car, and the front lifted off the "B" points. The car looks like it's on there solid, but it isn't. That's what happened with Qball's car - they lifted it up high, and remove one front tire - that was enough to shift the balance, and it went over backward.
I think I'd skip a scissor lift that spread the load between the "A" and "B" points. The problem is that you want the rear held up farther back than the "A" point. Tespri's (and now Thomasio's) lift kit solves that problem. The scissor lift might work just fine with the lift kit installed.
  LotusTalk - The Lotus Cars Community > Community > Garage Majal
