2005 Elise - LotusTalk - The Lotus Cars Community
post #1 of 5 (permalink) Old 10-07-2019, 12:05 PM Thread Starter
2005 Elise
Hi guys,
I'm relatively new. I just bought a 2005 Elise with a Forced Fed 275 kit. Just wanted to introduce myself. Anyone else skip N/A and go straight for a boosted Elige?
Scape is offline
post #2 of 5 (permalink) Old 10-09-2019, 08:55 PM
Mobius97's Avatar
Welcome to the club! You need to post some pics with your intro man! Let her shine, lol.
Force Fed 275....awesome. As for skipping, I waited until I was out of warranty and paid off, then went S/C'ed. Loved the jump in power.
2005 Elise- Katana II Supercharged and other fun bits
2011 Evora - Daily Driver
Mobius97 is offline
post #3 of 5 (permalink) Old 10-10-2019, 04:35 AM
lt1_fd3s's Avatar
my first '06 exige was NA... then when I was looking for a replacement a few months later, i picked up another '06 Exige but with a Katana2 this time...
WNC Tour Guide - WNC Drives (click me!)
'93 Vintage Red RX-7 - NA 20B
'06 Chili Red Exige - RIP 2017.12.01
'06 Ardent Red Exige Katana2 - try this again
lt1_fd3s is online now
post #4 of 5 (permalink) Old 10-10-2019, 05:14 AM
glb
glb's Avatar
These are brilliant cars.
Stock: “Excuse me”
Stebel: “HONK! LOOK OUT!”
3. The early cars came with misaimed and dim headlights. If you drive at night, convert to HIDs. While better than stock halogen bulbs are available, HIDs throw more light. Stay around 5000k. As of this writing LEDs are not as good.
5. Transmission:
The best transmission lube I’ve found is Redline MT-90 plus a little Power Punch Extreme Gear Oil Additive. (Note that it takes two changes to get rid of the previous lube.)
And, use:
https://www.inokinetic.com/lotus/re-...y=Transmission
6. As per some engine builders on these sites, wait AT LEAST 20 -35 minutes after coolant has reached full operating temp before engaging cam switchover.
For street cars, consider removing one or both oil coolers. Some cover them. Oil doesn’t get hot enough on street, leading to cam wiping.
I use Mobil 1 5W-40 Turbo Diesel oil. 85k miles and fine, but one is not a useful example.
https://www.lotustalk.com/forums/f311...-u-tube-47232/
https://www.lotustalk.com/forums/f320...ramming-70940/
You NEED a digital multimeter (voltmeter) to work on modern cars. Handy around house too. Get one this week.
14. If you are fooling with sparkplugs, remember to slather those tubes in dielectric grease (prevents shorts).
15. Visit the Uber Thread
https://www.lotustalk.com/forums/f3/e...ow-here-25131/
16. Most parts on the car are made by Toyota and others, so buying things like a/c compressors, engine parts, etc. is wildly expensive when purchased thru Lotus.
17. The soft high-grip tires on most of our cars lose much of that grip when temperatures drop below 50 F. I know of too many ppl who spun their cars when not remembering this. I use hi-performance all-seasons.
Plus, “How to bleed brakes”:
https://www.lotustalk.com/forums/f101...brakes-241138/
How to Search:
glb is online now
post #5 of 5 (permalink) Old 10-10-2019, 09:33 AM
NoRawkus305's Avatar
Congrats and welcome! Share some pics!
2002 Honda S2000 - RIP MAY 2012
2005 Lotus Elise Sport and Touring Package - Weekend Warrior
2015 NX200T F-Sport - DD and Winter Beater
2006 Hummer H3 - The wife's
NoRawkus305 is offline
  LotusTalk - The Lotus Cars Community > Lotus Discussions > New Member Introductions
