-   New Member Introductions (https://www.lotustalk.com/forums/f221/)
-   -   After 10 years, finally bought one! (https://www.lotustalk.com/forums/f221/after-10-years-finally-bought-one-467242/)
lance_mn 03-20-2019 09:30 AM
Hey gang!
I finally bought one. I was in love with these cars in college and flew to Chicago after College to buy one... The interior and drive-ability scared me away. Well, over the next decade, literally every time I shopped cars again, I'd search Elises first and dream of owning one. I decided that if I spent a decade vacillating over them, then I should probably just buy one let myself enjoy its quirks.
I purchased one in Denver couple days ago and drove it to Minnesota. The drive was intense. I suspect it may have aftermarket exhaust, as the noise drove me to stop at a walgreens for earplugs. Also it either has a loose ball bearing or else this thing "tramlines" more sporadically than I thought possible.
Overall I'm extremely excited. However, I've found about a half dozen things wrong with it since buying it, which has put a damper on things. Yesterday I typed up a separate post to hopefully get help figuring some of that out. If you're feeling helpful, give a look? https://www.lotustalk.com/forums/f25...issues-467214/
Looking forward to getting to know the community :) I feel like this was a longgg time coming
Lance
lt1_fd3s 03-20-2019 09:48 AM
1 Attachment(s)
congratulations...
LostPawn 03-20-2019 09:59 AM
Originally Posted by lance_mn (Post 5932288)
I purchased one in Denver and drove it to Minnesota. The drive was intense. I suspect it may have aftermarket exhaust, as the noise drove me to stop at a walgreens for earplugs. Also it either has a loose ball bearing or else this thing "tramlines" more sporadically than I thought possible.
Curious what Elise in Denver you purchased? Maybe some pics?
glb 03-20-2019 10:04 AM
Good for you.
Stock: “Excuse me”
Stebel: “HONK! LOOK OUT!”
3. The early cars came with misaimed and dim headlights. If you drive at night, convert to HIDs. While better than stock halogen bulbs are available, HIDs throw more light. Stay around 5000k.
5. The best transmission lube I’ve found is Redline MT-90 plus a little Power Punch Extreme Gear Oil Additive. (Note that it takes two changes to get rid of the previous lube.)
https://www.inokinetic.com/lotus/re-...y=Transmission
For street cars, consider removing one or both oil coolers. Some cover them.
https://www.lotustalk.com/forums/f311...-u-tube-47232/
https://www.lotustalk.com/forums/f320...ramming-70940/
14. Visit the Uber Thread
https://www.lotustalk.com/forums/f3/e...ow-here-25131/
Plus, “How to bleed brakes”:
https://www.lotustalk.com/forums/f101...brakes-241138/
How to Search:
shay2nak 03-20-2019 11:57 AM
congrats!
AwesomeJoe 03-20-2019 11:58 AM
Pics or GTFO.... lol
lance_mn 03-20-2019 05:11 PM
3 Attachment(s)
Haha thanks guys! I've been too busy to really take pics, but I'll give you what I got!
I bought it from AutoNation Chrysler Jeep in Littleton. Carfax says I'm owner #4. 24k miles. I think it'd been in Colorado for ~ 7 years according to carfax?
ALSO: If you'd like to test your elise knowledge or be a good samaritan, I haven't had any responses yet to my troubleshooting thread. I'm still a bit panicked about my red flashing light scenario.
Thanks!
