After 10 years, finally bought one! - LotusTalk - The Lotus Cars Community
 4Likes
  • 2 Post By lt1_fd3s
  • 1 Post By LostPawn
  • 1 Post By AwesomeJoe
post #1 of 7 (permalink) Old 03-20-2019, 09:30 AM Thread Starter
lance_mn's Avatar
Hey gang!
I finally bought one. I was in love with these cars in college and flew to Chicago after College to buy one... The interior and drive-ability scared me away. Well, over the next decade, literally every time I shopped cars again, I'd search Elises first and dream of owning one. I decided that if I spent a decade vacillating over them, then I should probably just buy one let myself enjoy its quirks.
I purchased one in Denver couple days ago and drove it to Minnesota. The drive was intense. I suspect it may have aftermarket exhaust, as the noise drove me to stop at a walgreens for earplugs. Also it either has a loose ball bearing or else this thing "tramlines" more sporadically than I thought possible.
Overall I'm extremely excited. However, I've found about a half dozen things wrong with it since buying it, which has put a damper on things. Yesterday I typed up a separate post to hopefully get help figuring some of that out. If you're feeling helpful, give a look? https://www.lotustalk.com/forums/f25...issues-467214/
Looking forward to getting to know the community I feel like this was a longgg time coming
Lance
lance_mn is offline
post #2 of 7 (permalink) Old 03-20-2019, 09:48 AM
lt1_fd3s's Avatar
congratulations...
XHILR8N! and lance_mn like this.
WNC Tour Guide - WNC Drives (click me!)
'93 Vintage Red RX-7 - NA 20B
'06 Chili Red Exige - RIP 2017.12.01
'06 Ardent Red Exige Katana2 - try this again
lt1_fd3s is online now
post #3 of 7 (permalink) Old 03-20-2019, 09:59 AM
Addict
LostPawn's Avatar
Originally Posted by lance_mn View Post
I purchased one in Denver and drove it to Minnesota. The drive was intense. I suspect it may have aftermarket exhaust, as the noise drove me to stop at a walgreens for earplugs. Also it either has a loose ball bearing or else this thing "tramlines" more sporadically than I thought possible.
Curious what Elise in Denver you purchased? Maybe some pics?
lance_mn likes this.
LostPawn is offline
post #4 of 7 (permalink) Old 03-20-2019, 10:04 AM
glb
glb's Avatar
Good for you.
Stock: “Excuse me”
Stebel: “HONK! LOOK OUT!”
3. The early cars came with misaimed and dim headlights. If you drive at night, convert to HIDs. While better than stock halogen bulbs are available, HIDs throw more light. Stay around 5000k.
5. The best transmission lube I’ve found is Redline MT-90 plus a little Power Punch Extreme Gear Oil Additive. (Note that it takes two changes to get rid of the previous lube.)
https://www.inokinetic.com/lotus/re-...y=Transmission
For street cars, consider removing one or both oil coolers. Some cover them.
https://www.lotustalk.com/forums/f311...-u-tube-47232/
https://www.lotustalk.com/forums/f320...ramming-70940/
14. Visit the Uber Thread
https://www.lotustalk.com/forums/f3/e...ow-here-25131/
Plus, “How to bleed brakes”:
https://www.lotustalk.com/forums/f101...brakes-241138/
How to Search:
glb is offline
post #5 of 7 (permalink) Old 03-20-2019, 11:57 AM
shay2nak
shay2nak's Avatar
congrats!
'07 Lotus Exige S310
WTC 2
shay2nak is offline
post #6 of 7 (permalink) Old 03-20-2019, 11:58 AM
AwesomeJoe's Avatar
Pics or GTFO.... lol
lt1_fd3s likes this.
Euro Press/Spec lotus Elise Cup car
----- Sector111-----
Facebook group -----> SouthWest Florida Lotus Owners Club
[email protected]
AwesomeJoe is offline
post #7 of 7 (permalink) Old 03-20-2019, 05:11 PM Thread Starter
lance_mn's Avatar
Haha thanks guys! I've been too busy to really take pics, but I'll give you what I got!
I bought it from AutoNation Chrysler Jeep in Littleton. Carfax says I'm owner #4. 24k miles. I think it'd been in Colorado for ~ 7 years according to carfax?
ALSO: If you'd like to test your elise knowledge or be a good samaritan, I haven't had any responses yet to my troubleshooting thread. I'm still a bit panicked about my red flashing light scenario.
Thanks!
lance_mn is offline
  LotusTalk - The Lotus Cars Community > Lotus Discussions > New Member Introductions
Similar Threads
Finally a LOTUS dealer in London (!) after 6 years! vavoo General Discussion (Lotus related) 2 05-13-2015 08:40 PM
Radiator Replacement: After 10 years of service, mine finally gave up TachItUp General Discussion (Lotus related) 7 02-05-2015 01:52 PM
After 2 years, finally got an S240!!!!! Exiges007 New Member Introductions 10 10-12-2010 11:13 AM
Finally after lusting for 32 years... flexcrac New Member Introductions 18 04-28-2010 01:13 PM
Will a SA2005 bought today be good 10 years? Darth G-F Track and Technique 8 10-23-2007 09:26 AM
