Bought '06 Exige - Chrome Orange - Page 2 - LotusTalk - The Lotus Cars Community
 17Likes
post #21 of 31 (permalink) Old 06-19-2019, 06:57 PM
glb
glb's Avatar
Congrats. Nice car.
Sorry I missed you the first time:
Stock: “Excuse me”
Stebel: “HONK! LOOK OUT!”
3. The early cars came with misaimed and dim headlights. If you drive at night, convert to HIDs. While better than stock halogen bulbs are available, HIDs throw more light. Stay around 5000k. As of this writing LEDs are not as good.
5. Transmission:
The best transmission lube I’ve found is Redline MT-90 plus a little Power Punch Extreme Gear Oil Additive. (Note that it takes two changes to get rid of the previous lube.)
And, use:
https://www.inokinetic.com/lotus/re-...y=Transmission
For street cars, consider removing one or both oil coolers. Some cover them. Oil doesn’t get hot enough on street, leading to cam wiping.
https://www.lotustalk.com/forums/f311...-u-tube-47232/
https://www.lotustalk.com/forums/f320...ramming-70940/
You NEED a digital multimeter (voltmeter) to work on modern cars. Handy around house too. Get one this week.
14. Visit the Uber Thread
https://www.lotustalk.com/forums/f3/e...ow-here-25131/
Plus, “How to bleed brakes”:
https://www.lotustalk.com/forums/f101...brakes-241138/
How to Search:
WMBL and 6TVRs+ like this.
glb is offline
post #22 of 31 (permalink) Old 06-19-2019, 07:11 PM
AKA “Prolene”.
I was torn between ordering with manual cranks due to looks and coolness factor and possibly lighter weight. When specs out that electric crank was lighter I didn’t mind the Touring package as much.
I just replaced side switch panel with a new one due to same problem. Realize now would have been easier to epoxy or modify the tab from these posts.
Elise #2393 Bordeaux/Biscuit Interior/Touring and Sport Packs/HT/Lotus Sport ECU/GPan3/DSBrace/Quantum Black SA Dampers/Lowered, Corner Weighted/Radium Catch Can/HKS Special Edition Exhaust/New "3M" Starshield/WindowTinting. Purchased new 06/01/05.
First in Class 2008 Speed Ventures Lotus Challenge Series.
Prolene2 is offline
post #23 of 31 (permalink) Old 06-19-2019, 07:16 PM
The Enforcer
oldmansan's Avatar
Originally Posted by KZ3 View Post
I converted mine and weighed both setups. Manual is lighter, but not by a significant amount.
The majority claim the electric are lighter, by about an ounce.
https://www.lotustalk.com/forums/f25...8/#post1827376
https://www.lotustalk.com/forums/f92...windows-74607/
https://www.lotustalk.com/forums/f92...r-swap-333489/
San
oldmansan is offline
post #24 of 31 (permalink) Old 06-19-2019, 07:21 PM
KZ3
KZ3's Avatar
I don’t see any proof in those threads though, just some anecdotal evidence. I took pictures of the components on a shipping scale. I’ll dig them up and post it.
2007 Chrome Orange Elise
KZ3 is offline
post #25 of 31 (permalink) Old 06-19-2019, 07:45 PM
The Enforcer
oldmansan's Avatar
That would be nice. Of note is that the majority of the wiring for the windows is already in all of the vehicles, and that the touring pack itself is the cause of the weight, not the window mechanisms themselves. I did note in those threads that the cranks supposedly are no longer available, as the original supplier went out of business. Sorry for the hijack OP. Some of us are obsessed with weight, and won't even change out the plastic carpet buttons for aluminum.
San
post #26 of 31 (permalink) Old 06-19-2019, 10:24 PM
Welcome. Love the car. It looks great. Hope enjoy yours as much as I do
WMBL likes this.
Chemgee
2008 Elise-
California
Atlanta
Chemgee is offline
post #27 of 31 (permalink) Old 06-20-2019, 07:06 AM Thread Starter
Even if the crank windows ended up weighing a pound more, there’s something I enjoy about the manual cranks.
6TVRs+ likes this.
2006 Lotus Exige - Chrome Orange
WMBL is offline
post #28 of 31 (permalink) Old 06-20-2019, 07:15 AM
KZ3
KZ3's Avatar
Agreed!
KZ3 is offline
post #29 of 31 (permalink) Old 06-20-2019, 09:31 AM
Agreed!
That is beautiful.
I want to convert mine to manual window too.
Motard likes this.
17sd is offline
post #30 of 31 (permalink) Old 06-20-2019, 09:39 AM
Motard's Avatar
Killing me!!!!
I have polished window pulls on a shelf. I have power windows but high on my priority list of potential future projects are swapping out the ugly electric window buttons for those beautiful aftermarket throwback crank window pulls...
I could not give a single care about the weight, hands down manual windows are on another level of cool on these cars. imo
L O T U S
Motard is offline
post #31 of 31 (permalink) Old 07-09-2019, 01:03 PM
KZ3
KZ3's Avatar
Better late then never. Here are the window weights:
Manual: 2lbs 14.9oz
Auto: 3lbs 12oz
KZ3 is offline
  LotusTalk - The Lotus Cars Community > Lotus Discussions > New Member Introductions
Similar Threads
FS: 06 Chrome Orange Exige in NY chiuman Lotus Cars For Sale 5 12-09-2008 06:03 AM
Bought a New Chrome Orange Lotus Today! TimMullen General Discussion (Lotus related) 23 10-13-2008 04:14 PM
Bought a New Toy, and it's even "Chrome Orange" mopho General Discussion (Lotus related) 80 05-05-2008 05:09 AM
06 Chrome Orange Exige Forsale - Long Island, New York Imolas54 Lotus Cars For Sale 19 11-18-2006 03:58 PM
The chrome in Chrome Orange ekological General Discussion (Lotus related) 10 04-18-2005 08:26 AM
