Bought a 2006 Elise - LotusTalk - The Lotus Cars Community
 1Likes
  • 1 Post By Mike_K
post #1 of 4 (permalink) Old 05-15-2019, 09:06 AM Thread Starter
Bought a 2006 Elise
I live in Raymond, Alberta, Canada. Looking forward to summer with my new toy!
Aedo likes this.
Mike_K is offline
post #2 of 4 (permalink) Old 05-15-2019, 10:14 AM
Mobius97's Avatar
Congrats and welcome!
However I will take one gold star off your board because you did not post some pics.
2005 Elise- Katana II Supercharged and other fun bits
2011 Evora - Daily Driver
Mobius97 is offline
post #3 of 4 (permalink) Old 05-15-2019, 04:13 PM
glb
glb's Avatar
Welcome and good for you.
Stock: “Excuse me”
Stebel: “HONK! LOOK OUT!”
3. The early cars came with misaimed and dim headlights. If you drive at night, convert to HIDs. While better than stock halogen bulbs are available, HIDs throw more light. Stay around 5000k.
5. The best transmission lube I’ve found is Redline MT-90 plus a little Power Punch Extreme Gear Oil Additive. (Note that it takes two changes to get rid of the previous lube.)
And, use:
https://www.inokinetic.com/lotus/re-...y=Transmission
For street cars, consider removing one or both oil coolers. Some cover them.
https://www.lotustalk.com/forums/f311...-u-tube-47232/
https://www.lotustalk.com/forums/f320...ramming-70940/
14. Visit the Uber Thread
https://www.lotustalk.com/forums/f3/e...ow-here-25131/
Plus, “How to bleed brakes”:
https://www.lotustalk.com/forums/f101...brakes-241138/
How to Search:
glb is offline
post #4 of 4 (permalink) Old 05-15-2019, 06:28 PM
AwesomeJoe's Avatar
Welcome. In for pics!
Euro Press/Spec lotus Elise Cup car
----- Sector111-----
Facebook group -----> SouthWest Florida Lotus Owners Club
[email protected]
AwesomeJoe is offline
  LotusTalk - The Lotus Cars Community > Lotus Discussions > New Member Introductions
Similar Threads
Bought minivan, had baby, sold my Elise and bought a 2-eleven docjay General Discussion (Lotus related) 33 01-12-2012 07:31 PM
Bought, sold, bought again? bfm01 Lotus Elise 10 12-13-2010 08:44 AM
[bought] WTB - 2006-2007 low mileage Elise, any grey EXT w/Red Leather INT the1sen Lotus Cars Wanted 6 03-05-2009 04:48 PM
Bought a 2006 Pontiac GTO t65tampa Other Cars and Comparisons 16 01-16-2007 06:07 AM
Just bought a New 2006 Elise 2small2fast General Discussion (Lotus related) 29 03-25-2006 08:31 AM
