Exige S in SLC - LotusTalk - The Lotus Cars Community
 3Likes
  • 2 Post By L1MTD
  • 1 Post By L1MTD
post #1 of 15 (permalink) Old 08-04-2019, 06:03 AM Thread Starter
Exige S in SLC
Hello all, quick intro: my name is Brandon, and I just (finally....long story/saga) picked up a new to me 2007 Exige S/Starlight Black with a little over 13k Miles.
I drove it home from Las Vegas after trading in my 2005 Porsche 997 C2S (going to miss that car forever I think). I thought I would enjoy the stares and attention it gets but even after a 6 hour drive I’m shocked at the level.
People waking up passengers in other cars to look, people taking pictures, entire gas stations stopping everything to watch you pull in, pictures etc etc.
It’s all pretty surreal at the moment but wanted to officially say hello and add a few pics.
Kubera and Jetblast like this.
L1MTD is online now
post #2 of 15 (permalink) Old 08-04-2019, 06:54 AM
Scott M
Molez93's Avatar
Welcome and congrats!
Your experience of passersby is the norm. Doesn't seem to matter what model Lotus, folks have an urge to check them out. Heck, I have a grumpy "friend" who sold his V8 Esprit because he couldn't live with the attention it received.
'03 Esprit (for sale)
'14 Evora S
'13 Subaru BRZ
'11 BMW X5M
'06 BMW Z4M
Molez93 is offline
post #3 of 15 (permalink) Old 08-04-2019, 06:59 AM
glb
glb's Avatar
These are brilliant cars and you will be very happy, albeit a tad too young to drive.
Stock: “Excuse me”
Stebel: “HONK! LOOK OUT!”
3. The early cars came with misaimed and dim headlights. If you drive at night, convert to HIDs. While better than stock halogen bulbs are available, HIDs throw more light. Stay around 5000k. As of this writing LEDs are not as good.
5. Transmission:
The best transmission lube I’ve found is Redline MT-90 plus a little Power Punch Extreme Gear Oil Additive. (Note that it takes two changes to get rid of the previous lube.)
And, use:
https://www.inokinetic.com/lotus/re-...y=Transmission
For street cars, consider removing one or both oil coolers. Some cover them. Oil doesn’t get hot enough on street, leading to cam wiping.
https://www.lotustalk.com/forums/f311...-u-tube-47232/
https://www.lotustalk.com/forums/f320...ramming-70940/
You NEED a digital multimeter (voltmeter) to work on modern cars. Handy around house too. Get one this week.
14. Visit the Uber Thread
https://www.lotustalk.com/forums/f3/e...ow-here-25131/
Plus, “How to bleed brakes”:
https://www.lotustalk.com/forums/f101...brakes-241138/
How to Search:
glb is offline
post #4 of 15 (permalink) Old 08-04-2019, 07:33 AM Thread Starter
Stock: “Excuse me”
5. Transmission:
And, use:
How to Search:
Thanks gents, much appreciated!
L1MTD is online now
post #5 of 15 (permalink) Old 08-04-2019, 12:40 PM
mattjk's Avatar
Congrats!!! I had my eye on this car as well.
2008 Lotus Exige S240 Aspen White
2008 Mercedes G500 Black
2014 BMW i3 Rex White
mattjk is online now
post #6 of 15 (permalink) Old 08-04-2019, 07:08 PM
SelinaS19's Avatar
Your car looks great! I'd take a picture too if I were to see you drive by.
SelinaS19 is offline
post #7 of 15 (permalink) Old 08-05-2019, 06:03 AM
4380r's Avatar
Congrats, beautiful car. The Elise garners a ton of attention, the Exige so much more so.
Owned, loved, enjoyed, and now gone:
1969 Europa S2 Blue
1970 Europa S2 White
1974 Europa Twin Cam Blue
1984 Turbo Esprit Calypso Red
2005 Elise Starlight Black
2005 Elise Saffron Yellow
2005 Elise Ardent Red
2006 Exige Graphite Grey
2007 Exige Canyon Red
Other:
1970 MGB GT
1970 Datsun 510
1984 Honda CRX Si
1984 Pontiac Fiero
2004 Chrysler Crossfire
2009 Pontiac Solstice Coupe
4380r is offline
post #8 of 15 (permalink) Old 08-05-2019, 10:57 AM
NoRawkus305's Avatar
Congrats on the purchase! Very nice Exige. The attention it gets will never get old. Just has such a special and unique look to it all. Enjoy and drive safe!
2002 Honda S2000 - RIP MAY 2012
2005 Lotus Elise Sport and Touring Package - Weekend Warrior
2015 NX200T F-Sport - DD and Winter Beater
2006 Hummer H3 - The wife's
NoRawkus305 is offline
post #9 of 15 (permalink) Old 08-05-2019, 10:58 AM
Nice! Just brought home an Elise to SLC myself. If never had your Porsche out at UMC, and even if you did, definitely find some time to get your Exige out there.
psummerill is offline
post #10 of 15 (permalink) Old 08-05-2019, 11:03 AM
Crazy05's Avatar
I took a visit to that dealer earlier this year. I was drooling over your Exige fore sale. Looks awesome man!
How did you like the drive compared to the Porsche?
Did you take a look at the Noble?
Currently:
2005 Lotus Elise
2015 Audi A3 Wife's car
2012 Toyota Prius C Daily Commuter
Sold:
2006 Pontiac Solstice
2003 350z Touring
2006 Eclipse GT
Crazy05 is online now
post #11 of 15 (permalink) Old 08-05-2019, 07:55 PM Thread Starter
Just came back from my first proper drive.
Oh. My. God! I feel a connection to my Porsche still and don’t want to disrespect it, but not even the same experience at all. Wow.
I actually did check out the Noble but it’s another extreme even beyond the Exige as far as parts access/info. Looked cool but Exige has always been a fav of mine just looks alone.
Crazy05 likes this.
L1MTD is online now
post #12 of 15 (permalink) Old 08-06-2019, 12:52 PM
Hey there fellow SLCer! Brought an Elise to SLC this spring after purchase from a LotusTalk member. If you haven't been on a track yet, definitely try to get out there (Utah Motorsports Campus, fka Larry Miller Raceway).
post #13 of 15 (permalink) Old 08-08-2019, 03:51 PM
Themadknight's Avatar
Welcome! Join up on Facebook. Our group is Lotus Cars Utah. We go on drives all the time.
- Jesse
Themadknight is offline
post #14 of 15 (permalink) Old 08-08-2019, 06:03 PM
Best color! Congrats!!!
2010 Lotus Exige S240
2001 BMW M5
2017 Ford Raptor
2018 Jeep Grand Cherokee Trackhawk (wife-mobile)
REKIII is online now
post #15 of 15 (permalink) Old 08-09-2019, 05:22 AM Thread Starter
- Jesse
Thanks Jesse. I’m not a FB/social media guy at all. I’d love to meet up though. If I can PM I’ll shoot you my email.
L1MTD is online now
  LotusTalk - The Lotus Cars Community > Lotus Discussions > New Member Introductions
