Finally a Lotus to add to my TVRs! - LotusTalk - The Lotus Cars Community
 10Likes
  • 2 Post By 6TVRs+
  • 3 Post By 6TVRs+
  • 1 Post By TachItUp
  • 1 Post By glb
  • 1 Post By glb
  • 1 Post By Elise8206
  • 1 Post By Mobius97
post #1 of 8 (permalink) Old 07-25-2019, 07:16 AM Thread Starter
Hello Peeps!
I autocrossed friends Super 7s and Elans years ago. Always had a fond spot for Lotus! Own 6 different TVRs (started when I realised I would never be able to afford a Cobra)
Been friends with Randy Chase for years and went up against him autocrossing my TVR 3000s versus his MR2 (pre Lotus days)
Anyway, got back into autocrossing having a go in a Pontiac GXP coupe.. doing fine locally.. but realised I needed some "other quirky car" to have a better shot and the Lotus fit the bill.
Thanks to Randy for support and info! I'm sure I'll be gleaning more info from him, the site, and others!
Mobius97 and SS Lotus Elise like this.
6TVRs+ is offline
post #2 of 8 (permalink) Old 07-25-2019, 07:20 AM Thread Starter
Oh, some of my TVRs if anyone is interested...
rb26dett, PLAY-DOH and cirving like this.
6TVRs+ is offline
post #3 of 8 (permalink) Old 07-25-2019, 08:06 AM
TachItUp's Avatar
That's the best color too
6TVRs+ likes this.
TachItUp is offline
post #4 of 8 (permalink) Old 07-25-2019, 12:41 PM
glb
glb's Avatar
Good for you. These are brilliant cars.
Stock: “Excuse me”
Stebel: “HONK! LOOK OUT!”
3. The early cars came with misaimed and dim headlights. If you drive at night, convert to HIDs. While better than stock halogen bulbs are available, HIDs throw more light. Stay around 5000k. As of this writing LEDs are not as good.
5. Transmission:
The best transmission lube I’ve found is Redline MT-90 plus a little Power Punch Extreme Gear Oil Additive. (Note that it takes two changes to get rid of the previous lube.)
And, use:
https://www.inokinetic.com/lotus/re-...y=Transmission
For street cars, consider removing one or both oil coolers. Some cover them. Oil doesn’t get hot enough on street, leading to cam wiping.
https://www.lotustalk.com/forums/f311...-u-tube-47232/
https://www.lotustalk.com/forums/f320...ramming-70940/
You NEED a digital multimeter (voltmeter) to work on modern cars. Handy around house too. Get one this week.
14. Visit the Uber Thread
https://www.lotustalk.com/forums/f3/e...ow-here-25131/
Plus, “How to bleed brakes”:
https://www.lotustalk.com/forums/f101...brakes-241138/
How to Search:
6TVRs+ likes this.
glb is offline
post #5 of 8 (permalink) Old 07-25-2019, 12:43 PM
glb
glb's Avatar
PS: Friend is a TVR fan.
Has about 6 or so.
One stock.
One with Supra turbo engine.
And....one where he widened the chassis body and stuffed a TT Corvette V8 in it!
6TVRs+ likes this.
glb is offline
post #6 of 8 (permalink) Old 07-25-2019, 06:04 PM
Elise8206's Avatar
Like the dark color TVR..
6TVRs+ likes this.
'05 Lotus Elise Magnetic Blue
'02 Toyota MR-2 Spyder
'17 Mazda Miata MX-5 RF
'19 Acura RDX A-Specs
'09 Mini Cooper S
Tech Library!
http://wiki.seloc.org/a/Category:S2
Elise8206 is offline
post #7 of 8 (permalink) Old 07-25-2019, 10:45 PM Thread Starter
I had to chuckle as I realised talking to someone recently that the Lotus is the most "common" car in my garage! Lol..
The Lotus... 1 of 2500 or so in 2005?
None of the ones below are broken out by color... just total models made.
Gxp coupe 5 spd manual.. 1266 coupes.. Turbo manuals..1 of 270
77 TVR Turbo Taimar ... 63 Turbos, only 3 LHD.. this is 1 0f 30 Taimars, and was the 1977 NYC auto show car.
68 TVR Tuscan LWB SE V8 .. 302 powered and 1 of 48 in 4 years
79 TVR 3000S ... 1 of 254 in 2 years
72 TVR 2500... 1 of @ 950... and @ 105 of those with this "hybrid" chassis combo. This has a 302 in it also.
But I really am looking forward to time in the Elise!
6TVRs+ is offline
post #8 of 8 (permalink) Old 07-26-2019, 07:42 AM
Mobius97's Avatar
Can I have a TVR? Kindergarten rules apply here...sharing is caring ;P
Welcome to the forums and congrats on the new Elise. Thanks for sharing the pics of your wonderful collection!
6TVRs+ likes this.
2005 Elise- Katana II Supercharged and other fun bits
2011 Evora - Daily Driver
Mobius97 is offline
  LotusTalk - The Lotus Cars Community > Lotus Discussions > New Member Introductions
