First post - LotusTalk - The Lotus Cars Community
 1Likes
  • 1 Post By Weshore
post #1 of 7 (permalink) Old 04-16-2019, 09:54 PM Thread Starter
First post
Hi Lotus enthusiasts, Canadian member here hoping to educate myself more about the Elise and take my driving to the next level. Owning an Elise has been a very long time dream of mine. Last summer I became the happy owner of a 60th anniversary edition in yellow. Absolutely loving this car!
SS Lotus Elise likes this.
Weshore is offline
post #2 of 7 (permalink) Old 04-17-2019, 01:06 AM
Toronto's Avatar
Welcome! Can’t give any new advice just share what I was advised and followed, you are probably already aware. Double check that the recall from 2007 regarding the oil line was addressed, consider changing the original radiator that tends to break down, keep a distance from other cars, and stay out of other drivers’ blind spots. Cheers.
Toronto is offline
post #3 of 7 (permalink) Old 04-17-2019, 06:23 AM
^^ all good advice, along with never, ever parallel park.
steelypip is offline
post #4 of 7 (permalink) Old 04-17-2019, 08:38 AM Thread Starter
Thanks for the advice!
Weshore is offline
post #5 of 7 (permalink) Old 04-17-2019, 09:51 AM
glb
glb's Avatar
That looks terrific.
Stock: “Excuse me”
Stebel: “HONK! LOOK OUT!”
3. The early cars came with misaimed and dim headlights. If you drive at night, convert to HIDs. While better than stock halogen bulbs are available, HIDs throw more light. Stay around 5000k.
5. The best transmission lube I’ve found is Redline MT-90 plus a little Power Punch Extreme Gear Oil Additive. (Note that it takes two changes to get rid of the previous lube.)
And, use:
https://www.inokinetic.com/lotus/re-...y=Transmission
For street cars, consider removing one or both oil coolers. Some cover them.
https://www.lotustalk.com/forums/f311...-u-tube-47232/
https://www.lotustalk.com/forums/f320...ramming-70940/
14. Visit the Uber Thread
https://www.lotustalk.com/forums/f3/e...ow-here-25131/
Plus, “How to bleed brakes”:
https://www.lotustalk.com/forums/f101...brakes-241138/
How to Search:
glb is offline
post #6 of 7 (permalink) Old 04-17-2019, 02:30 PM Thread Starter
Wow, absolutely amazed by your post. Thanks so much for taking the time to go into so much detail. This has gotta be the holy grail of best advice.
MUCH APPRECIATED !
Weshore is offline
post #7 of 7 (permalink) Old 04-17-2019, 02:39 PM
shay2nak
shay2nak's Avatar
Congrats!
'07 Lotus Exige S310
WTC 2
shay2nak is offline
  LotusTalk - The Lotus Cars Community > Lotus Discussions > New Member Introductions
Similar Threads
First post, first Lotus, Very Excited REKIII New Member Introductions 12 05-16-2017 01:47 PM
First day, first post Paul Orofino New Member Introductions 25 01-23-2015 05:02 AM
Impeach Cheney First? or Bush First? climb4fun Other 27 04-18-2007 02:46 PM
Free Lotus Goodies: First come, first served. slaughtr Other 16 11-16-2006 09:57 AM
First things first- Waiver news? _JD_ Lotus Elise 7 01-15-2004 11:42 AM
