First time Lotus owner in Denver, CO - LotusTalk - The Lotus Cars Community
 3Likes
  • 2 Post By EvoVIIIEric
  • 1 Post By 6TVRs+
post #1 of 16 (permalink) Old 09-21-2019, 11:14 AM Thread Starter
EvoVIIIEric's Avatar
Hello everyone
Thought I would post up an introduction since I just got my first Lotus the 19th. I've been creeping the site before I made my purchase and this is my first post. I live here in Denver and come from the world of AWD 4 cylinder turbo cars like the STI and Evo. Like most of you I'm sure, I have had a thing for Lotus for a long time and have just recently had the chance to get my own. After searching for awhile I landed on a local 2005 Elise in Aubergine Metallic. Touring and sport packages from what I know and its completely stock supposedly sitting at 12500 miles. I'm hoping to keep this stock for awhile, but I'm sure I will change some things soon. I would be sad to ruin such a car. I cant really leave things alone and I like to play with titanium. If I can figure out this site I will attach some pictures if the Elise and my jealous Evo that I've had the past seven years. The Elise might be getting some love soon since I hear the radiator and oil cooler/lines have problems. I have only driven about 100 miles so far and catch the smell of oil, so I'd like to make sure the coolers aren't already screwed. Thanks for looking and for any future advice I may need for this amazing car.
Thanks,
Eric
SS Lotus Elise and 6TVRs+ like this.
EvoVIIIEric is offline
post #2 of 16 (permalink) Old 09-21-2019, 11:29 AM Thread Starter
Few more evo shots of some titanium work I've done
post #3 of 16 (permalink) Old 09-21-2019, 12:03 PM
glb
glb's Avatar
Nice.
Stock: “Excuse me”
Stebel: “HONK! LOOK OUT!”
3. The early cars came with misaimed and dim headlights. If you drive at night, convert to HIDs. While better than stock halogen bulbs are available, HIDs throw more light. Stay around 5000k. As of this writing LEDs are not as good.
5. Transmission:
The best transmission lube I’ve found is Redline MT-90 plus a little Power Punch Extreme Gear Oil Additive. (Note that it takes two changes to get rid of the previous lube.)
And, use:
https://www.inokinetic.com/lotus/re-...y=Transmission
For street cars, consider removing one or both oil coolers. Some cover them. Oil doesn’t get hot enough on street, leading to cam wiping.
https://www.lotustalk.com/forums/f311...-u-tube-47232/
https://www.lotustalk.com/forums/f320...ramming-70940/
You NEED a digital multimeter (voltmeter) to work on modern cars. Handy around house too. Get one this week.
14. Visit the Uber Thread
https://www.lotustalk.com/forums/f3/e...ow-here-25131/
Plus, “How to bleed brakes”:
https://www.lotustalk.com/forums/f101...brakes-241138/
How to Search:
glb is offline
post #4 of 16 (permalink) Old 09-21-2019, 12:18 PM
Addict
LostPawn's Avatar
Always nice to see another Lotus owner in Denver or at least a car not leaving the area. Welcome. Look at the local Lotus club, it $25 a year to join and they do some track days and drives. Hope to see you are around.
https://www.lotuscolorado.com/
We have a track day coming in a couple weeks, not exactly club sponsored but setup by a few from Denver.
https://www.lotustalk.com/forums/f10...2019-a-472810/
LostPawn is offline
post #5 of 16 (permalink) Old 09-21-2019, 01:32 PM Thread Starter
Super helpful stuff already. Thanks for the Colorado welcome and I'll probably end up meeting some local people at some point soon
post #6 of 16 (permalink) Old 09-21-2019, 10:14 PM
Welcome, too cool and too funny!
I bought my 05 Nightfall Blue Elise and kept in So Cal. a bit over 2 months ago and still like to "look". Sadly, due to my fathers death not too long ago I am in Denver to see to that, but my brother lives here and while running errands, I mentioned to my brother "I would like to stop and check out a rare purple Elise I saw for sale in Denver".
When we finally got there an hour or two later and stopped in, the dealer said "Too Late, we just sold it and are cleaning it for the new buyer"!
Dam! What a sweet looking car and with recent changes, I might have bought it! Congrats!
You might like this pic I took!
SS Lotus Elise likes this.
6TVRs+ is online now
post #7 of 16 (permalink) Old 09-22-2019, 05:13 AM Thread Starter
It's a small world in the world of Lotus it would seem. That's pretty crazy. Sorry to hear about your father. Thanks for the picture
post #8 of 16 (permalink) Old 09-22-2019, 08:34 AM
thebuzzard's Avatar
I have had a couple of these cars down to the bones a couple of time and I have a theory about the perennial oil smell. There are several (like 6 or 7) open holes in the firewall behind the rear speaker panel that are good sources of air from the engine bay. See the bits of black tape (and there are more under the trim just below the window) plus others in hidden spots that can be seen from inside the cabin. I am not sure but it will be interesting to see if this helps.
2007 Exige S
Stripped down and turned into a track animal
thebuzzard is offline
post #9 of 16 (permalink) Old 09-29-2019, 11:41 AM
Haha I have to know how this car works out. I’ve been sending it to a buddy of mine for months telling him to buy it.
Would love to know the condition it is in. I believe it’s been sitting for awhile with very few miles over the last 5 years or so, right?
Anyhow, congrats on the purchase!
L1MTD is offline
post #10 of 16 (permalink) Old 09-30-2019, 07:52 AM
Le0nz's Avatar
Hey man..... Found you post to be a but funny.. I'm also an ex-STI junkie and also a new Elise owner in the Denver area and I saw your car on sale a month ago or so... Nice color!!
I just joined Lotus Colorado but let me know if you want to do a quick photoshoot at some point or maybe I'll see you at local Denver area Lotus events. Perhaps I'll make my own into thread here as well.
Le0nz is offline
post #11 of 16 (permalink) Old 09-30-2019, 09:42 AM
Crazy05's Avatar
Your car has been for sale for a while and wondered why it didn't sell sooner due to the rare color. Beautiful car and color with low miles. From what I remember it was at a fair price as well. It seems that is a common theme, (STI owners that have a Lotus), I know one locally as well that has a turbo elise and has an built STI. It seems that would be the best of both motoring worlds. Have fun with your Elise!
Currently:
2005 Lotus Elise
2015 Audi A3 Wife's car
2012 Toyota Prius C Daily Commuter
Sold:
2006 Pontiac Solstice
2003 350z Touring
2006 Eclipse GT
Crazy05 is offline
post #12 of 16 (permalink) Old 09-30-2019, 07:10 PM Thread Starter
To the local colorado guy I'm game for meeting up and cruising sometime. I usually turn up to the Lafayette cars and coffee every first Saturday of the month. As for why nobody snagged it for awhile I would assume people were turned off by the accident reported on the carfax and the spongy brakes. When I looked at the clams it seemed to be in good condition and had been fixed back in 2015, so I gave it a shot. Been looking around and so far seems like it's all good. Not sure if it really has 12,400 miles. Brake fluid either shows how it has many more miles than shown possibly having one of the LCD previously installed making it seem like it wasn't driven or the lack of driving has the seals disintegrating into the fluid making it black. The car is stupid clean which would make me think it is low mileage.
post #13 of 16 (permalink) Old 10-13-2019, 08:40 AM
Was that a typo? Or does the car have an LSD and the traction control button by the shifter? If so, now I'm really sad..
post #14 of 16 (permalink) Old 10-13-2019, 04:02 PM Thread Starter
LCD meaning dash screen replacement
post #15 of 16 (permalink) Old 10-13-2019, 05:19 PM
Less is Better
me73's Avatar
Dark brake fluid is pretty normal, even after just a year. I've had that a few times with ATE gold. I switched to Castrol and it's not doing it any more. Welcome to the world of rear weight bias, it's a completely different animal. I grew up in Littleton (now Centennial, about a mile from where Ferrari of Denver is now) and also lived in Loveland for several years. Colorado has the greatest backroads in the country. Twisty, often empty, and amazing scenery. I miss that alot.
me73 is offline
post #16 of 16 (permalink) Old 10-13-2019, 10:31 PM
Mobile Mechanic
Queenie Li's Avatar
Welcome! I'm new as well. Thanks for sharing.
Queenie Li is offline
  LotusTalk - The Lotus Cars Community > Lotus Discussions > New Member Introductions
