Newbie - LotusTalk - The Lotus Cars Community
post #1 of 3 (permalink) Old 04-20-2019, 05:43 AM Thread Starter
Newbie
Hello Fellow Lotus owners. I’m a new owner of an Elise since Oct 2018. My favorite car by far! Glad be able to get on Lotus talk.
Jeppreee is offline
post #2 of 3 (permalink) Old 04-20-2019, 07:21 AM
glb
glb's Avatar
Great for you.
Where are you located?
Stock: “Excuse me”
Stebel: “HONK! LOOK OUT!”
3. The early cars came with misaimed and dim headlights. If you drive at night, convert to HIDs. While better than stock halogen bulbs are available, HIDs throw more light. Stay around 5000k.
5. The best transmission lube I’ve found is Redline MT-90 plus a little Power Punch Extreme Gear Oil Additive. (Note that it takes two changes to get rid of the previous lube.)
And, use:
https://www.inokinetic.com/lotus/re-...y=Transmission
For street cars, consider removing one or both oil coolers. Some cover them.
https://www.lotustalk.com/forums/f311...-u-tube-47232/
https://www.lotustalk.com/forums/f320...ramming-70940/
14. Visit the Uber Thread
https://www.lotustalk.com/forums/f3/e...ow-here-25131/
Plus, “How to bleed brakes”:
https://www.lotustalk.com/forums/f101...brakes-241138/
How to Search:
glb is offline
post #3 of 3 (permalink) Old 04-20-2019, 05:20 PM
shay2nak
shay2nak's Avatar
Congrats & welcome!
'07 Lotus Exige S310
WTC 2
shay2nak is offline
  LotusTalk - The Lotus Cars Community > Lotus Discussions > New Member Introductions
Similar Threads
Stupid NewBie Questions... Francesco Lotus Elise 35 12-17-2003 05:53 PM
Newbie Introduction: MOKOSpeeD MOKOSpeeD Other 1 10-29-2003 08:21 PM
Another newbie introduction Andrew Other 3 10-18-2003 01:11 PM
Newbie Says Hi! Beowoulf Lotus Elise 3 10-05-2003 06:45 PM
Elise Talk- Newbie... lotus elise S1 Lotus Elise 14 08-15-2003 01:14 PM
