SCCVC11187HL80628 2007 Exige S - LotusTalk - The Lotus Cars Community
post #1 of 18 (permalink) Old 08-24-2018, 07:21 PM Thread Starter
Not mine but looks like someone had a hard hit (tree?) to the drivers side https://autoforwarder.com/en/detail/6677144-lotus-exige
Slow_Polk is offline
post #2 of 18 (permalink) Old 08-25-2018, 05:29 AM
not your dad's puns
Turbopun's Avatar
Well now we know how well the door intrusion beams work
because racecar
Turbopun is offline
post #3 of 18 (permalink) Old 08-25-2018, 06:06 AM
tomrev's Avatar
Looks like a great donor car; nice selective, limited damage, well done!
tomrev is offline
post #4 of 18 (permalink) Old 12-01-2018, 06:16 AM
https://www.ebay.com/itm/2007-Lotus-...2:pf:0&vxp=mtr
on ebay now, rebuildable in description....
that'l buff out.....
Hope the driver is ok, pushed the seat over into console and the throttle pedal is gone
exigegus is offline
post #5 of 18 (permalink) Old 12-01-2018, 08:24 AM
eldonz's Avatar
How do they consider that the car can be rebuilt? My guess it happened on track since the car has an Accusump, racing belts and a fire extinguisher. I would consider that to be a parts car.
Later,
Eldon
eldonz is offline
post #6 of 18 (permalink) Old 12-06-2018, 07:26 PM
sleepe's Avatar
Tough little nut . . . worst damage I've ever seen!
2006 Elise ST (someone else has it now . . . )
2008 Exige S240 ST
sleepe is offline
post #7 of 18 (permalink) Old 12-07-2018, 02:00 AM
blaising's Avatar
Tub is dead..not rebuildable.
"In general, the Elise will be kept in best operating condition by regular use."
Page 152 Lotus Elise owner's manual
blaising is offline
post #8 of 18 (permalink) Old 12-07-2018, 07:52 AM
Many great parts there, but no tub = no car. Lots of quality go-fast bits, though.
steelypip is offline
post #9 of 18 (permalink) Old 12-07-2018, 08:27 AM
Race & Pamper
Kubera's Avatar
note the last picture in the ebay description, no gas pedal!!!
Kubera is offline
post #10 of 18 (permalink) Old 03-09-2019, 06:32 PM
Parts Finder
Partsfinder's Avatar
I purchased this car and also a 08 Exige tub and parts. Rebuild will start in a couple weeks.
Partsfinder is offline
post #11 of 18 (permalink) Old 03-13-2019, 05:08 PM
Parts Finder
It has a gas pedal now. I had them install it so hauler can load on trailer under its own power. Also hoping to drive in industrial park before I tear it down for rebuild
Past favorites
99 Esprit
02 Eurovan Weekender
62 Falcon 450hp under 2000lbs
(My first power to weight car)
post #12 of 18 (permalink) Old 03-14-2019, 05:40 AM
Race & Pamper
Kubera's Avatar
@Partsfinder good choice for a parts car, rear clam can easily be fixed.
Kubera is offline
post #13 of 18 (permalink) Old 03-14-2019, 06:31 AM
Parts Finder
Rear clam, roof and front splitter will be headed to body shop within a couples after car arrives. Then strip the chassis to transfer to the 08 chassis arriving in April.
Past favorites
99 Esprit
post #14 of 18 (permalink) Old 03-14-2019, 07:16 AM
Race & Pamper
Kubera's Avatar
That is the same approach I would take if that was my car, also don't forget the crashbox...removal is tricky...do it carefully-you can save it for another car, or sell it here.
From the pictures, it looks like the driver's seat is damaged, you will have to remove both seats to get access to the rear clam bolts.
Kubera is offline
post #15 of 18 (permalink) Old 03-14-2019, 08:01 AM
As the chassis is scrap aluminum, couldn't you just cut the front of the tub off with a sawzall (presumably after removing everything of value bolted on)? You'd still have to remove the aluminum from the crash structure interface, but now it would be a small part you could carry around. A couple of sectioning cuts to either side and then a transverse cut would seem the logical way.
There are times to think like a car dismantler insead of a mechanic. Sometimes a sawzall and aviation tin snips are your best tools.
post #16 of 18 (permalink) Old 03-14-2019, 10:43 AM
Race & Pamper
Kubera's Avatar
@steelypip the main chassis tub is useless scrap with so much damage, after removing the parts that can be used again, it is best to cut the chassis to pieces. For a Lotus fan like myself... truly a heartbreaking thing to do, I've done it times so far to 3 totaled Exiges :/
Kubera is offline
post #17 of 18 (permalink) Old 03-14-2019, 11:52 AM
If you like cars, it's hard to just cut one up, even if it is obviously beyond repair. I get it - I have a parts car in a shed that needs to go off to the scrapyard this year and I have been resisting going after it with the sawzall...
post #18 of 18 (permalink) Old 03-14-2019, 01:42 PM
Parts Finder
Yes plan is just like you described. Tub is scrap so saw saw saw. I’ve been doing auto salvage since 8 years ago. Grew up at family’s auto salvage yard. I’ve taken saw or torch to 1000’s of cars 🚗
Past favorites
99 Esprit
  LotusTalk - The Lotus Cars Community > Lotus Discussions > The Salvage Yard
