Uh oh! Wreck?! - Page 2 - LotusTalk - The Lotus Cars Community
post #21 of 33 (permalink) Old 03-09-2009, 07:49 PM
anglophile in exile
Aedo's Avatar
Originally Posted by Seb View Post
If that is a section of the monocoque, then that is a write off (I believe). If it is something just bolted to it, then you should be fine.
It is not a write off - as Vulcan Grey posted above from the service manual "Superficial, cosmetic, or non-structural localised damage may be repaired as necessary".
Aedo is offline
post #22 of 33 (permalink) Old 03-09-2009, 09:32 PM
shokwaves's Avatar
Damn! time to get out the shotgun. BTW, remove the thumb ring when posting pic. it changes the whole impression of a lotus driver.
shokwaves is offline
post #23 of 33 (permalink) Old 03-09-2009, 09:58 PM
Flash G's Avatar
I have a hard time believing that an insurance company is going to total a car for non-structural "cosmetic" damage that can be fixed MUCH cheaper.
I'm going to say that it won't be a loss and should be a fairly inexpensive repair.
Turn your flatscreen TV into a work of art.
Modern Art DVD | Plasma Aquarium DVD | Widescreen Fireplace DVD
07 Exige S - Ardent Red, Stage II Exhaust, LSD, Touring pack
06 Range Rover Supercharged - Java Black
06 Range Rover Sport - Java Black
05 Elise - Ardent Red, Stage II Exhaust, Touring pack
Flash G is offline
post #24 of 33 (permalink) Old 03-10-2009, 06:23 AM
Baysailor's Avatar
On a side note... either your undertray is installed upside down or the NACA ducts are installed upside down. The plastic duct should be on the upper side of the panel.
2006 Lotus Elise - Solar Yellow, HT, LSS, LSD/TC, Touring, StarShield, S111 RTDbrace, S111 microMirror, S111 Carpet Buttons, Painted A/C Surround, CF Center Console, Nitron S/A, Tempest BAB26-12 AGM Battery, Fujita Intake, Top Speed Pro 1 Exhaust, 4Tress Harness Bar, JDM ASTAR Cree H1 LED Headlights, Plinthless front clam, BRIDGESTONE POTENZA RE-71R 205F/235R on LSS Wheels, Heater Core By-Pass, Shifter Reinforcement, LETSLA v2 Shift Kit
Baysailor is offline
post #25 of 33 (permalink) Old 03-10-2009, 07:39 AM
andykeck's Avatar
Good eye!
andykeck is offline
post #26 of 33 (permalink) Old 04-05-2009, 02:45 AM
Westrock's Avatar
Westrock is offline
post #27 of 33 (permalink) Old 04-05-2009, 03:35 AM
looney's Avatar
as steve says, this is no major issue.
S1's and early S2's had problems with corrosion on those panels that were installed.
on occasion that piece was simply removed and replaced with a new piece of alu,
dont worry you'r car should be fine.
looney is offline
post #28 of 33 (permalink) Old 04-05-2009, 08:37 AM
But what an earth caused the hole in the fist place ?
Conrad is offline
post #29 of 33 (permalink) Old 04-05-2009, 08:49 AM
Chris Mackey's Avatar
I'd fix it with a piece of aluminum, glue and rivets.
2006 Elise, Ardent Red, Black Pack, LSS wheels, shocks and springs.
Chris Mackey is offline
post #30 of 33 (permalink) Old 04-05-2009, 09:15 AM
xtn
xtn's Avatar
Aircraft Inspection, Repair, and Alterations: Acceptable Methods, Techniques, and Practices (FAA Handbooks)
Look for that. It gives very good and detailed explanations on the proper methods of cutting out a damaged area of aluminum and preparing a doubled replacement piece to be rivetted into place (no pop rivits!).
I have some dents in my passenger side floor pan that I intend to repair using that publication as a guide.
xtn
2006 McLareghini Bugatterrari, Storm Titanium... installed: air horn, Scroth 4-point ASM harnesses, Sector111 halon extinguisher and mounting bracket, Von Hep exhaust and rear panel delete, Pagid brake pads, red Volks CE28n wheels, Toyo RA-1 tires, Nitron SA coilovers, Sector111 (WorksBell) quick-disconnect steering wheel kit. awaiting installation: Scroth "pull-up" lap belts, Sector111 RTD Brace, Tony's heater bypass mod, and dropped steering rack mounting plates.
xtn is offline
post #31 of 33 (permalink) Old 04-05-2009, 01:00 PM
thruthefence's Avatar
here ya go
http://rgl.faa.gov/REGULATORY_AND_GUIDANCE_LIBRARY/RGADVISORYCIRCULAR.NSF/0/99c827db9baac81b86256b4500596c4e/$FILE/Chapter%2004.pdf
scroll down to cha 4 sect 4 , pg 11 of this pdf.
thruthefence is offline
post #32 of 33 (permalink) Old 04-16-2009, 12:04 PM
kverges's Avatar
And I have been researching glue Like crazy and think the Hysol H4800 is the way to go, even though it appears the factory may have used Araldite 2015
kverges is offline
post #33 of 33 (permalink) Old 07-06-2016, 11:15 AM
pasiva's Avatar
Which type of aluminium sheet should be used for doubled replacement piece? 6063, 5052, other???
pasiva is offline
  LotusTalk - The Lotus Cars Community > Lotus Discussions > The Salvage Yard
