BOE Manual Brake Cage - Install Review - Page 3 - LotusTalk - The Lotus Cars Community
 24Likes
post #41 of 47 (permalink) Old 02-18-2018, 09:25 PM
eldonz's Avatar
Originally Posted by artmt View Post
Thanks.
I am trying to figure out whether a valve is "a reasonable low budget solution, not as good as a bias cage" or just "not a good idea".
Looks like it is the former.
It is "Not a good idea". The Lotus cannot generate enough rear brake bias so adding the proportioning valve to the rear is useless. The only way to get the valve to work would be to increase the rear brake bias to the point that you had too much. If you keep the stock brake master, the only way to accomplish this would be to install larger calipers on the rear. You would not want to install the valve in the front brake line.
Later,
Eldon
eldonz is offline
post #42 of 47 (permalink) Old 02-19-2018, 05:45 PM
artmt's Avatar
I think you may have misread my original question, or I didn't make myself clear.
The question was:
Can someone explain why proportioning valves are not a good solution for braking bias when running front calipers on 4 corners?
Black/Silver 60th Anniv Elise
artmt is offline
post #43 of 47 (permalink) Old 02-20-2018, 04:58 AM
Elise Guru
fzust's Avatar
The question was:
Hi Art,
Prop valves have a hysteresis via the cracking pressure and can be somewhat non-linear. I toyed with this on my car for a while before ultimately decided to just do it correctly. Maybe it will work great, but the theory says you will be leaving some performance on the table. My $0.02
titaniumdave likes this.
Winning Suspension
6UL wheels
fzust is offline
post #44 of 47 (permalink) Old 09-09-2018, 12:36 PM
thebuzzard's Avatar
I am in the middle of installing the BOE cage and removing my ABS (2007 Exige S with AP racing 2-pots all four corners).
I'd be interested in what folks did with their ABS unit. I understand that I need to keep the computer in place for the wheel speed pass-through (speedo) but am not decided on how much to rip out and where to secure the remainings bits.
Thanks!
2007 Exige S
Stripped down and turned into a track animal
thebuzzard is offline
post #45 of 47 (permalink) Old 09-09-2018, 01:35 PM
eldonz's Avatar
Thanks!
Remove the electronics from the valving and reinstall it in the car. Place the unit to the right, towards the passenger side, of the brake cylinders and down. There should be enough room there. You can also wrap a little foam around it to give it some cushion.
Later,
Eldon
eldonz is offline
post #46 of 47 (permalink) Old 09-14-2018, 01:52 PM
thebuzzard's Avatar
Many thanks Eldon!
I am wrapping up now and have one more question: Adjust the pedal push rod so that there is no tension or tension the master cylinder springs a little?
Thanks!
2007 Exige S
post #47 of 47 (permalink) Old 09-15-2018, 08:23 AM
thebuzzard's Avatar
According to Tilton (and BOE) there should be no master cylinder preload, so I shortened the push rod to be neutral.
2007 Exige S
  LotusTalk - The Lotus Cars Community > Vendors > BOE Fabrication
