Evora Power Packages are HERE! - Page 3 - LotusTalk - The Lotus Cars Community
 6Likes
post #41 of 44 (permalink) Old 10-03-2017, 09:42 AM
Phil, is it necessary to remove side engine cover (timing chain cover) in order to install your cams? Also do they come with necessary gaskets?
I bought your stage 2 and 3 but wondering about the installation of the cams
Thanks Andreas
Originally Posted by Andreasrous View Post
Do you need valve gap adjustment (shims etc) in order to install your cams?
Thanks Andreas
No sir.
Andreasrous is offline
post #42 of 44 (permalink) Old 10-03-2017, 10:30 AM Thread Starter
Plug Whisperer
turbophil's Avatar
the timing chain cover stays on and the gaskets are reusable.
We don't have a tutorial on camshaft replacement put together at this time, so you'll need to be sure to be familiar with the 2GR to make your way through it...
Hope that helps a bit,
Phil
turbophil is offline
post #43 of 44 (permalink) Old 10-05-2017, 05:44 AM
jrb3's Avatar
Phil,
I am really interested in adding Stage 2 to my NA Evora and I've already added the CAI which I really, really like in terms of sound and, although it's always subjective, seat of the pants dyno. What I am wondering is what kind of improvements in HP and TQ are there from just header versus header and tune? Any problem going just header, then tune? Thanks
'11 Evora
jrb3 is offline
post #44 of 44 (permalink) Old 10-05-2017, 08:46 AM
cain-it's Avatar
With just hardware changes (manifolds & CAI) won't the engine run lean with an ECU re-map to change fueling etc?
Arabian Elises R US
cain-it is offline
  LotusTalk - The Lotus Cars Community > Vendors > BOE Fabrication
