Insane Elise - Page 2 - LotusTalk - The Lotus Cars Community
 13Likes
post #21 of 25 (permalink) Old 01-13-2018, 04:10 AM
RichardNHCooper's Avatar
Upgrade.
Hi Phil what supercharger are you using to get to 25 psi. Do you think using a 70 mm throttle body (DBW) would be worthwhile upgrade on my Rev 400 setup ( Ported head, stage 3 cams running pump E85 on the track ) will it have any detrimental effects on this as a daily.
Thanks
Still jealous of what you are able to achieve.
2009 Elise S,Rev 400 ,t Ferrea Valves , MWR springs,PPE headers and decat,SSC Harness bar, PenskeDA,Shaved V2 steering arms ,FF engine damper. Saikou Michi catch cans, Modded Toyota E153 gearbox ,60l Proalloy fuel tank , Aeromotive 320 fuel pump,Exedy clutch LSD , SSC ECU, CompositeWorx SP1 seats ,Varexy muffler, Haltech Elite 1500 ECU, Racepak IQ3 Street dash, Aussie-clamhinge.
RichardNHCooper is offline
post #22 of 25 (permalink) Old 01-16-2018, 10:39 AM
JIF
Jeremy
JIF's Avatar
Thanks
It's a Whipple 2.3 liter s/c. Recall Phil saying something about it being custom - hope that helps.
JIF is offline
post #23 of 25 (permalink) Old 11-04-2018, 03:17 AM
Rev X Rev 400 comparison
The torque curves, same dyno with my Rev 400 setup 65 mm pulley vs Rev X both on E85. Now with Ferrea roller rockers. It idles perfectly even down to 850 rpm which was a major surprise as it only uses the “big cam” profile all the time.
post #24 of 25 (permalink) Old 01-11-2019, 02:53 PM
I don't really care where you get the motor, but take care that you spec the correct compression for your fuel. 9:1 is required for pump fuels and pump E85, IMO. If you're running barrel VP/Sunoco E85 or 100+ octane from VP/Sunoco you can bump the compression up to 10.5 or 11:1 for more power...
-Phil
Are you saying this because pump E85 can sometimes be E40 or some other lower ethanol mixture?
Sent from my SM-G950U using Tapatalk
ScottH83 is offline
post #25 of 25 (permalink) Old 01-11-2019, 04:09 PM
Mobius0034's Avatar
E85 does vary but haven’t seen it down to 40. Winter blends can be 65-70. The ability to use a flex fuel sensor handles that and blending with std pump gas nicely....
Mobius0034 is offline
  LotusTalk - The Lotus Cars Community > Vendors > BOE Fabrication
