Elise roll bar extender or lower seat for tall driver (6'3'') - LotusTalk - The Lotus Cars Community
post #1 of 5 (permalink) Old 03-25-2012, 06:36 PM Thread Starter
redduck5's Avatar
I'm tall (6'3'') and with a helmet I stick out an inch or so out of the Elise's frame. Is there an bolt-on roll bar extender that I could bring with me to the track and bolt on for track use? Then unbolt it for street use? It's OK if it interferes with the roof. I want some more piece of mind in case of a rollover on the track.
I have a 2005 Elise with a soft top. I expect to take it to the track three times this summer. Plus many autocrosses, but I am not as concerned about rollovers there.
If there is a replacement seat that lets me sit lower in the car, I would consider that as well. A seat would take a lot more space in my storage unit.
Thank you
redduck5 is offline
post #2 of 5 (permalink) Old 03-25-2012, 06:49 PM
Me!
6.94915254 lbs/hp
Me!'s Avatar
TALLrails are Seat Rails for the Lotus Elise and Exige - Sector111
There you go, these should do the trick, tall seat rails. I have them in my car and I'm 6'2" and have plenty of headroom (4 inches?).
Disclaimer: I haven't tried it with a helmet.
2007 Storm Titanium Exige S w/ sunvisor delete
Me! is offline
post #3 of 5 (permalink) Old 03-26-2012, 07:26 AM Thread Starter
redduck5's Avatar
That is a great idea Me! As a bonus I may be able to see traffic lights.
It looks like the seat will not be able to move back and forth after installation.
Sector 111 says: "Eliminates seat travel on driverís side. Customers who have especially long legs may find that the TALLrails will cause your knees to hit steering wheel."
Are you finding it makes entry and exit harder? I drive in a mid forward position but I slide the seat all the way back for entry and exit.
redduck5 is offline
post #4 of 5 (permalink) Old 03-26-2012, 07:45 AM
cornbeef's Avatar
I'm 6'4 long torso
I had maybe a half inch clearance with the soft top on, head slightly stuck out over the windshield. With a helmet I was sticking out a lot so last year broke down and got the tall rails - huge difference. Now with a helmet on it just brushes the soft or hard top, no helmet I've bags of headroom so it's a major improvement. Now I can see traffic lights thru the windshield rather than over it, overall it's just a better driving experience.
Saying that it does tilt the seat so the front raises a little, again having shorter legs, legroom for me is still fine but I could see where someone with long legs could have issues (although in that case they'd probably fit under the roof anyway so wouldn't need it)
The lack of movement isn't an issue. I don't ever remember anyone driving my car moving it forward before and to be honest if they can't reach the pedals them though, they can't drive it
The seat can be adjusted with the tall rails both in tilt and front/back, it just cannot be adjusted with the lever (taking the mechanism out helps lower it). You set it when you install to where you want it so it's fixed from that point.
"People think I'm an idiot or something, because all I do is cut lawns for a living. People don't say that about you...as far as you know."
LotusPALS http://lotuspals.ning.com/
2006 Elise
2013 Evora S IPS
cornbeef is offline
post #5 of 5 (permalink) Old 04-27-2012, 06:34 AM Thread Starter
redduck5's Avatar
I installed the tall rails recently. Very painful installation - required some hole enlargement to make everything aligned and many attempts at putting the seat in and out. Not as bad as the airbag switch, however. Now I fit in the car much better vertically. Getting in and out is harder as I can't move the seat all the way back before getting out.
The rails have 3 back and forth positions and a sliding tilt position. The two screws controlling the tilt have to be very tight so the seat doesnít twitch as your body weight shifts in the car.
I have it all the way forward and smallest tilt. It seems that increasing the tilt or moving the seat back would bring the top of the seat under the roll bar which is a no-no for safety (also says so in the instructions). So it appears that the range of possible positions is smaller than it may seem.
I will see what other people who have driven the car in the past say about their comfort with the fixed seat.
Also, the rails are deep so the under-seat carpet will get flattened by them.
redduck5 is offline
