Another wiped Cam but a bit different! - Page 5 - LotusTalk - The Lotus Cars Community
 2Likes
post #81 of 287 (permalink) Old 02-20-2009, 05:56 AM
xtn
xtn's Avatar
Originally Posted by vao4v View Post
Yes, sorry about the cams, guys.
If it happens to me I might try one of the shops that the NASCAR guys use to heat treat, cryo, special coating, ??? to the new cams before replacing. Wonder if anyone has done it yet? Has anyone tested the failed cams for improper metallurgy?
It's very probably that SOMEONE has. But probably not any of us owners that I know of. I'm thinking along the lines of some engineer at Lotus. They keep their mouth shut, but it seems they would surely want to find out what's going on. I know after they replaced my engine they took the broken one home with them.
xtn
2006 McLareghini Bugatterrari, Storm Titanium... installed: air horn, Scroth 4-point ASM harnesses, Sector111 halon extinguisher and mounting bracket, Von Hep exhaust and rear panel delete, Pagid brake pads, red Volks CE28n wheels, Toyo RA-1 tires, Nitron SA coilovers, Sector111 (WorksBell) quick-disconnect steering wheel kit. awaiting installation: Scroth "pull-up" lap belts, Sector111 RTD Brace, Tony's heater bypass mod, and dropped steering rack mounting plates.
xtn is offline
post #82 of 287 (permalink) Old 02-20-2009, 08:38 AM
ekological's Avatar
I'm assuming you're talking about replacing cams and lifters?
Sorry to read the news... the good news is that the parts are cheap and not too tough to replace should you choose to do the work yourself.... Just buy the bits from Toyota- cost about 200 bucks...
Custom Plug-N-Play Elise HIDs, Arqray SS Double Tip Exhaust, RAC Monolites
ekological is offline
post #83 of 287 (permalink) Old 02-20-2009, 09:28 AM
Moderator Extraordinaire!
tesprit's Avatar
Yes, the lifters/rockers come with the new cam as a set. If you were to install a new cam without replacing the used lifters/rockers, it would not bed in correctly and you would just get to the job all over again in the near future.
tesprit is offline
post #84 of 287 (permalink) Old 02-20-2009, 12:40 PM
ekological's Avatar
Good to know. Obviously, if the cam lobes are scored, the lifters can't be in good shape. I was wondering if Phil was saying total cost for parts would be around $200 as I'm used to working on BMWs with Shrick cams where they provide just the cams.
post #85 of 287 (permalink) Old 02-20-2009, 12:53 PM
tesprit's Avatar
If you purchase the parts through Toyota, $200-$300 is about the right price for the cam with lifters/rockers so it isn't nearly as expensive as it could be. These should be the only parts you need unless the engine was run to the point of rocker arm failure which could cause damage to the intake valve. The rocker shafts seem to be very durable and show little to no wear so they can almost always be reused.
tesprit is offline
post #86 of 287 (permalink) Old 02-20-2009, 02:50 PM
Icedog_16's Avatar
When my rocker arm broke, I was quoted $510 for the set by my local Toyota dealer.
Icedog_16 is offline
post #87 of 287 (permalink) Old 03-07-2009, 05:33 AM
Wicked's Avatar
Update
I picked up the repaired Elise from the Lotus dealer yesterday with a new intake cam and rockers. Lotus covered the entire worn cam replacement under warranty. Man that was a relief!
Now I just have to figure out how to keep it from happening again.
Dave
06' STi Elise, LSS, LSD-TC, Touring, Hard Top, Star Shield, Katana SC, HIDs and Manly's motor mounts, Newman's Climate Controls, BHL Raptor Ehaust. No More Larini SE w/Euro grills = No More P0171 Codes.
Wicked is offline
post #88 of 287 (permalink) Old 03-08-2009, 02:05 PM
Icedog_16's Avatar
Dave
Just added you to this thread: https://www.lotustalk.com/forums/f25/...ml#post1235772
If you want to post your year and mileage, I will update it accordingly so we can get more data points.
Seems as though Lotus must have realized that there is a problem and is now warranting these on a regular basis as the relative silence is deafening.
post #89 of 287 (permalink) Old 03-08-2009, 02:16 PM
any '07+ cars affected?
Phantom Black 2007 Exige Kold Fire, Tesla double din dash.
Black 01' Mustang Cobra 'Vert ("some" modifications) daily driver
IamBatman is offline
post #90 of 287 (permalink) Old 03-08-2009, 04:17 PM
shay2nak
shay2nak's Avatar
I don't think I've heard of one yet. Maybe one, not sure...
'07 Lotus Exige S310
WTC 2
shay2nak is offline
post #91 of 287 (permalink) Old 03-08-2009, 05:38 PM
Manxman's Avatar
So what is the update - how many LT owners have reported a cam problem?
2006 Elise, Chrome Orange, Sport Pack, Touring Pack, Stage 2, LETSLA, Quick Rack, Sport ECU
2004 Cooper S, Black, -15% s/c pulley, 22mm sway bar
Manxman is offline
post #92 of 287 (permalink) Old 03-08-2009, 05:48 PM
Wicked's Avatar
Icedog_16,
Requested info is in post #74 of this thread with pics of the failure.
Dave
Wicked is offline
post #93 of 287 (permalink) Old 03-09-2009, 09:47 AM
Icedog_16's Avatar
Icedog_16,
Dave
Got it and updated it. Thanks!
post #94 of 287 (permalink) Old 03-09-2009, 09:51 AM
Icedog_16's Avatar
Based on the list, I don't think there's a big problem with '07+s.
post #95 of 287 (permalink) Old 03-09-2009, 09:52 AM
Icedog_16's Avatar
I've got ~30, plus various anecdotal cases mentioned by people here and on other sites.
post #96 of 287 (permalink) Old 04-01-2009, 04:42 PM
lebrunseven's Avatar
any trouble w/ replacement toyota cams
seeing lots of these cams are going bad because of faulty hardening- my question is: are the replacement factory toyota cams hardened properly? has anybody who replaced theirs already having the same issue again? what a pain for all us elise owners. lotus/toyota should replace all of them and be done w/ it. i am having a tappet noise, that is not consistant, now and then. wonder if mine is now gone, too? my car is a 05 w/ 5,000 miles on it, all road use. anybody who has had the problem had a tappet noise intermittently? thanks!!
lebrunseven is offline
post #97 of 287 (permalink) Old 04-02-2009, 06:37 AM Thread Starter
Plug Whisperer
turbophil's Avatar
Just gotta pull the cover and have a look. 15 minute job to take a peak... The intake cam phaser make some rattling noise from time to time that has nothing to do with tha cam wiping problem, FWIW... that may be what you're hearing...
Best,
Phil
turbophil is offline
post #98 of 287 (permalink) Old 04-02-2009, 08:42 AM
shay2nak
shay2nak's Avatar
i think one person had this problem come up once or twice after the original cam was replaced.
WTC 2
shay2nak is offline
post #99 of 287 (permalink) Old 04-07-2009, 05:25 PM
could you elaborate on the intake phaser? there is no other information i can find. the tappet noise comes and goes, always after car warms up, funny- it never did it until i installed a katana supercharger. i suspected the ecu was giving the cam a signal or something. any help is appreciated.
post #100 of 287 (permalink) Old 03-08-2010, 01:52 PM
over40's Avatar
Best of luck,
Phil
So when I talk to the friendly parts folks. I ask for a Celica GTS intake cam for the same model year as my Elise?
(Intake Cam 1&4 BTW)
over40 is offline
