Another wiped Cam but a bit different! - Page 6 - LotusTalk - The Lotus Cars Community
 2Likes
post #101 of 287 (permalink) Old 03-08-2010, 02:00 PM Thread Starter
Plug Whisperer
turbophil's Avatar
Not exactly...
Celica GTS, 2ZZ engine. 2000-2004 will work (they're the same cams across the board). Not a celica expert, but I don't believe they went passed 2004... My generic year I ask for is 2002 just to keep it simple...
Rgds,
Phil
turbophil is offline
post #102 of 287 (permalink) Old 03-08-2010, 02:17 PM
over40's Avatar
Not exactly...
Rgds,
Phil
Thanks for the quick reply!
So many of these things have gone bad, I am surprised no one has started a group buy yet.
over40 is offline
post #103 of 287 (permalink) Old 04-05-2010, 10:52 AM
over40's Avatar
Spent some time looking around on the web for a part number. Lots of sites list the camshaft but none have the part number.
Here is a local dealer`s site:
Mechanical Catalog - 2005 - Toyota - Celica
Engine, Camshaft and timing, Intake camshaft, Intake camshaft, celica, gt-s - 1.8l w/vvt - 1.8L W/VVT
BTW the dealer wants $286.
Toyotaparts123.com wants $205
ToyotaPartsCenter.com wants $228
ToyotaPartsBarn.com wants $212
They all have a similar description, although the non-dealer sites listed years as 00-05, the same illustration and the same buttons. Portal?
over40 is offline
post #104 of 287 (permalink) Old 04-05-2010, 11:58 AM Thread Starter
Plug Whisperer
turbophil's Avatar
I usually budget 250 for the cam/rocker combo, so you're right in the ballpark with those prices...
We have our pistons and engine bearings coated... I've been meaning to try a similar coating on the cam, although I'm not sure how long the coating will last in that situation... It couldn't hurt though!
The last cam I took out the other week looked like hell--the worst I've seen yet... I'm starting to question the slider on the rocker. In each cam wiping situation I've seen, the rocker was also in bad shape... In this latest instance, the rockers were terribly worn. Hard telling which is the chicken and the egg though...
Cheers,
Phil
post #105 of 287 (permalink) Old 04-05-2010, 04:05 PM
willbhere4u's Avatar
When I worked at a local race shop we built GSXR and Huyabusa powered SCCA C and D sports racers we coated the valve spring and picked up 2-4 hp on the Dyno on the 1k motors something to do with the spring twisting as it compressed? probably useless here!
willbhere4u is offline
post #106 of 287 (permalink) Old 04-05-2010, 06:51 PM
Does anyone make roller followers for this motor?
All torque, no traction...Exige S.
Real sports cars don't have A/C!
Ken Wright is offline
post #107 of 287 (permalink) Old 04-06-2010, 04:40 PM
We've caught a few engines early with only a light indication of excessive wear on the intake cam lobes. In those cases we've replaced the cam only and then either modified or replaced the valve cover to get the lube oil re-aimed. Have not seen any of those have any future problems. I just mention it because the cam alone is under $100 and much easier to replace than cam+rockers. We haven't had to reshim in these cases either. If there is any doubt about the condition of the rockers though I still tell people to replace them to be safe.
The 2ZZ was in the Celica from 2000-2005.
Nobody makes an alternative roller valvetrain because the VVL mechanism is fairly complicated making a replacement very expensive especially for such low volume. Most of the engines (especially earlier model years) have had no issues with the excessive wear and besides that the stock valvetrain works very well. It's good that the word is out and so many people know to watch for this issue so they can catch it before any real damage is done.
Monkeywrench is offline
post #108 of 287 (permalink) Old 04-18-2010, 11:52 AM
mx1
I'm trying to pull my valve cover and have all bolts out. The cover seems to be stuck down. How aggressive do you have to get with this??? Thanks.
Rob
Previous--66 Austin Healey 3000; 79 Alfa Spyder; 72 BMW 2002; 85 944; 86 MR2; 89 944S2; 89 944S2 w M030;
Current--01 Audi S4, modded twin turbo;07 Lotus Exige S
Lucky enough to have driven the autobahn for 5 years
mx1 is offline
post #109 of 287 (permalink) Old 04-18-2010, 12:12 PM
mx1
Just found a final bolt under the intercooler mount. Looks like I'll have to pull the inter cooler to get the cover off.
mx1 is offline
post #110 of 287 (permalink) Old 06-02-2010, 06:19 PM
FIL
FIL's Avatar
Took my cover off... they lobes feel pretty smooth, but I'm not sure exactly what I should be looking for... Thoughts?
05' Elise - REV400, PPE Header, Quaife LSD, Ohlins, BOE Silent Touch, LETSLA, ACT HDSS, Fidanza flywheel, BOE CAB Intake, BOE Catch Can, V2 Fuel Tank, V2 Steering Arms, BWR sway bar, ForcedFed CF splitter, Manly's engine mounts, All Mesh Grilles, Volk CE28 wheels
FIL is offline
post #111 of 287 (permalink) Old 06-03-2010, 02:14 PM
Wicked's Avatar
FIL, I would run my thumbnail across the high lift intake lobe on number 4 (large lobe on the left in your first picture). Number 4 looks a little sketchy in your pictures compared to the others but it may just be the picture. You should not feel any surface variation as you scrape your thumbnail across the high point of the lobe. You should have your thumbnail perpendicular to the cam shaft moving it across the lobe axially along the cam shaft. See my pictures in post #74 of this thread for a good esxample of the problem.
Dave
06' STi Elise, LSS, LSD-TC, Touring, Hard Top, Star Shield, Katana SC, HIDs and Manly's motor mounts, Newman's Climate Controls, BHL Raptor Ehaust. No More Larini SE w/Euro grills = No More P0171 Codes.
Wicked is offline
post #112 of 287 (permalink) Old 06-03-2010, 02:35 PM
FIL
FIL's Avatar
Thanks, Dave. I didn't feel any grooves, but probably need to take a closer look. TurboPhil is pretty sure the the #4 intake lobe is dead.
FIL is offline
post #113 of 287 (permalink) Old 06-03-2010, 04:03 PM
ERP
ERP's Avatar
I am glad this problem is well talked about. Decided to take a look at my cams and #1 and #4 are completely ruined. .025"-.030" is gone form the top of the lobe Nothing broken yet, but from what I have seen on here the rocker arm would let go at my first track event. I'm ordering a new set today.
This problem is interesting becuase #2 and #3 looked fine, surface marks but no measurable wear. Can't tell you much about the cars history, I have only owned it since February. It's an 06 with 22k miles. I can hear cam ticking at idle, much above that and the exhaust drowns it out. It quiets down a bit once it has gotten up to temperature.
2006 Chrome Orange Elise - 6.3 lbs/hp - MP-62 Supercharger, 3.2" Pulley, BOE Fast-Works Tune, Ported Head, MWR Stage 3 Cams, Penske Suspension, Cup Air Box, PPE Header with Catless Custom Twin Tip Exhaust, Fidanza Flywheel, ACT Clutch, MWR Water Pump + Alternator Pulley, 1900 lbs
Saab Turbo X, 415hp, 532 tq
Tesla S P85D - Wife's daily driver
ERP is offline
post #114 of 287 (permalink) Old 06-03-2010, 04:08 PM
zygotesoup's Avatar
#4 looks no good. do yourself a favor...
Toyota OEM Intake Camshaft and Rocker Set (4) - 2ZZ-GE - TOY-13501-29025 van Toyota OEM -
2005 Krypton Green Lotus Elise
1993 Black BMW 325i
zygotesoup is offline
post #115 of 287 (permalink) Old 06-06-2010, 08:49 PM Thread Starter
Plug Whisperer
turbophil's Avatar
Once a wiper, always a wiper
I've been trying to document the cam wiping thing a bit more. Normally, I'm in such a hurry to get a car back on the road, I haven't taken the time to write down the measurement pre and post cam wiping...
Toyota specs the intake cam lash at .007-.0010 and the exh at .014-.018". This makes sense due to the exh valve being so much hotter that it should grow more than the intake valve... Now Toyota probably also spec'd these tolerances to a "normal" street driven car--- not a lotus. Even the weekend wally driver of a lotus probably averages a much higher rpm (which means more heat too) than what the engine was designed for. I'm going to bet that in NA form, lotus spec'd these engines as a standard GTS engine with no changes and then tuned them up a bit for the elise and NA exige of 05 and 06... Then when they started with the Exige S, they asked toyota to spec a larger intake lash, leaving the exh alone. This is my guess as to why we see so many 05 and 06 cars with wiped intake cams. To compound the problem, we add blowers which further adds combustion heat helping the intake valve to grow even more--- similar to an exhaust valve...
It's also been evident that cars that wipe a cam will wipe another despite lash being within Toyota spec. I think it would be good practice for those of you who wipe a cam to increase your lash to about .012" to help avoid the problem in the future... Or more if you're really worried about.
Couple more for the well....
Phil
post #116 of 287 (permalink) Old 06-07-2010, 02:15 PM
Systemz's Avatar
just like to add my own update..
Early batch 2005 Elise, not sure on assembly #.
Driving habits: Never tracked, but driven quite hard (I thoroughly enjoyed the car!) I would hammer it into 2nd cam as soon as the car allowed.
17,000 miles: during cam change, engine threw codes, car went into limp mode
damage: replaced cams, rockers, complete valve job, machined the damage from bits of metal going into the #3 cylinder. Every setting back to factory. Parts purchased from Lotus.
22,000 miles: Lost nearly all power, and an incredibly loud knocking noise, Also happened during cam change.
Damage: detonation of #3 cylinder, broken cam lobe #3, #2. you get the picture~
I live in san antonio TX, and the car has more than once had issues with keeping cool in high summer. More than once it went into limp mode due to coolant heat being above 210F (or whenever it starts flashing), usually in stop traffic. Both incidents happened during the coldest parts of winter.
For the engine build, we talked to lotus, $15,000 for a crated motor.
We looked at replacement used motors off celica GTS, and i believe two other toyotas, $6000-$7000 for low mileage.
Ultimately we just purchased every single individual part from Toyota, and are assembling it our selves. I believe it was $3000-$4000.
I believe this is the safest method to avoid the possible causes for this issue. If its a bad batch lotus received from toyota, or if its an issue with the cam cover, then I think I'll be fine.
Any thoughts or questions?
91' Elan M100
04' Lexus Is300
05' Elise
09' Audi TTS
Systemz is offline
post #117 of 287 (permalink) Old 06-08-2010, 03:39 PM
FIL
FIL's Avatar
There appear to be two intake camshafts offered on the toyota sites, one for '00-'05 and another for '03'-'05. Which one is correct?
CAMSHAFT SUB-ASSY N - 1.8L W/VVT
03-05 $288.19 $213.26
00-05 $286.06 $211.68
FIL is offline
post #118 of 287 (permalink) Old 06-27-2010, 03:32 PM
DWebb's Avatar
All 4 Lobes Wiped
Early '05 with production date of '04 the vin is 0194.
It has about 42,000 miles.
Mine started tapping loudly last week after church. No check engine light and No codes.
Pulled coil connectors one at a time and tap never changed. Pulled the plugs and ran a compression test. All cylinders within 5psi dry.
Removed valve cover and found this:
Ordered intake cam and followers yesterday. I drive it hard and I'm still pissed.
I agree with your recommendation to increase valve lash, thanks for posting I wouldn't have thought of that in my current state.
What about oil pump and regulator valve? I was thinking all that metal had to go somewhere.
Thanks All
05 BRG Elise - 9:1 built motor- rev 400 66mm pulley
04 Yamaha R6
02 Volvo S80
92 Toyota Previa
DWebb is offline
post #119 of 287 (permalink) Old 06-27-2010, 05:39 PM Thread Starter
Plug Whisperer
turbophil's Avatar
Don't get too upset. Can't change it now It's pretty easy to fix as well and you'll learn something doing it...
FWIW- the metal is sitting in your oil filter...
Swap out your cam and rockers. Pretty easy. You slide your coolant catch tank out of the way just by removing the top 8mm bolt and then the catch can lifts up and out of it's mount... Remove VVT actuator and the shafts will slide out the drivers side... Once the rockers and cam are in, measure the lash on all 8 valves. Write it down. Whatever the difference is between your desired lash and the measured lash is what you need to change... You'll probably see a lot of 8s... shoot for 12 thou... allow yourself 11-13 thou... How you get to the desired lash is up to you and what you're comfortable with... New buckets or filing down the old buckets will be your options since you can't tip the valves with the head on the engine. New buckets are the right way to do it... FWIW- The buckets are small enough that their hardness seems to go all the way through the part, so the filing technique can be considered... Regardless of the technique, you'll need a micrometer and something to place inside the bucket since your mic won't fit... Pretty easy stuff once you sit down and do it...
Good luck,
Phil
post #120 of 287 (permalink) Old 07-03-2010, 10:58 AM
DWebb's Avatar
Installed new cam and rockers last night.
Sounds and runs great.
Measured buckets with the dial indicator.
I'll go easy till new buckets come in.
04 Yamaha R6
02 Volvo S80
92 Toyota Previa
DWebb is offline
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
