Best mod - LotusTalk - The Lotus Cars Community
 9Likes
post #1 of 41 (permalink) Old 03-30-2019, 06:27 AM Thread Starter
Best mod
Soon to be new owner looking at several all stock cars.
What is the best mod for these cars besides Ohlins?
BlackTundra is offline
post #2 of 41 (permalink) Old 03-30-2019, 08:10 AM
glb
glb's Avatar
Like I know which model.......
Answer: 1 & 2
Stock: “Excuse me”
Stebel: “HONK! LOOK OUT!”
3. The early cars came with misaimed and dim headlights. If you drive at night, convert to HIDs. While better than stock halogen bulbs are available, HIDs throw more light. Stay around 5000k.
5. The best transmission lube I’ve found is Redline MT-90 plus a little Power Punch Extreme Gear Oil Additive. (Note that it takes two changes to get rid of the previous lube.)
https://www.inokinetic.com/lotus/re-...y=Transmission
For street cars, consider removing one or both oil coolers. Some cover them.
https://www.lotustalk.com/forums/f311...-u-tube-47232/
https://www.lotustalk.com/forums/f320...ramming-70940/
14. Visit the Uber Thread
https://www.lotustalk.com/forums/f3/e...ow-here-25131/
Plus, “How to bleed brakes”:
https://www.lotustalk.com/forums/f101...brakes-241138/
How to Search:
Driving Tips-https://www.lotustalk.com/forums/f100...art-1-a-49665/
Moss Emergency Line-https://www.lotustalk.com/forums/f100...cy-line-36631/
Safely Piercing Wires-https://www.lotustalk.com/forums/f129...esting-106438/
Bleeding Brakes- https://www.lotustalk.com/forums/f101...-brakes-241138
glb is offline
post #3 of 41 (permalink) Old 03-30-2019, 08:18 AM
Less is Better
me73's Avatar
Have you ever driven on a track? Driver training is the best place to put your first $$$.
jds62f, XHILR8N!, Kubera and 1 others like this.
me73 is online now
post #4 of 41 (permalink) Old 03-30-2019, 09:03 AM
Best for what? Looks? Speed? handling? Comfort?
mwehnes is offline
post #5 of 41 (permalink) Old 03-30-2019, 10:37 AM
He's on fire!
jds62f's Avatar
Another vote for the good ol driver mod
jds62f is offline
post #6 of 41 (permalink) Old 03-30-2019, 11:03 AM
The Enforcer
oldmansan's Avatar
OP is asking about an 05/06, so presuming an Elise/Exige, the best mod isn't Ohlins, it's Penskes. It's not even close between the two.
San
Kubera and Lotusxs like this.
oldmansan is offline
post #7 of 41 (permalink) Old 03-30-2019, 12:31 PM
https://www.lotustalk.com/forums/f25...ramming-70940/
This was in my opinion the best first mod.
17sd is online now
post #8 of 41 (permalink) Old 03-30-2019, 01:45 PM
glb
glb's Avatar
I like this too, but my first thoughts go to safety, as with mirrors, horns, headlights.
glb is offline
post #9 of 41 (permalink) Old 03-31-2019, 05:44 AM
Lotusxs's Avatar
+1 for Penskes
Fresh high quality tires would be the first thing I would do.
Kubera likes this.
Lotusxs is offline
post #10 of 41 (permalink) Old 03-31-2019, 08:26 AM
XHILR8N!'s Avatar
Best mod I ever did was the convex side mirrors. So much more driveable in traffic on or off track.
2005 Elise LRG, Trim Shop interior, full cage, Cup wheels, BWR 'charger lives!
2016 370Z Nismo
2013 Bentley Continental GT Speed
XHILR8N! is online now
post #11 of 41 (permalink) Old 03-31-2019, 10:00 AM
The Enforcer
oldmansan's Avatar
That's interesting. I still have the stock mirrors, but I'll try to check out someone else's setup based on your opinion. Thanks.
San
post #12 of 41 (permalink) Old 03-31-2019, 12:08 PM
XHILR8N!'s Avatar
San
Multivex is what they were called. Some occasionally come up but they are now rare, no longer made. There are threads I have not fully read, but seems like there are other solutions.
The best solution, but not Lotusy, is in our $22,000 Honda Civic Si. A tiny camera in the passenger mirror. Ought to be required on all cars. Touch of a button on turn signal stalk and a perfect view on center screen, with graduated marks to indicate safe passing. Endurance racers at nifht especially rely on them.
Any mid engine car is awful in traffic. Wide angle mirrors change this a lot. And not just the little stick on ones. I use the inside mirror to judge distance for point by.
2016 370Z Nismo
post #13 of 41 (permalink) Old 03-31-2019, 12:16 PM
XHILR8N!'s Avatar
Once we got to moving pretty well, a 6 point harness system was a great mod. No longer had to brace my knees into things through curves.
But this is only with a helmet and neck protector. A harness system on street is nuts. Just there for that racy look, but a real danger to your life.
2016 370Z Nismo
post #14 of 41 (permalink) Old 03-31-2019, 12:18 PM
The Enforcer
oldmansan's Avatar
I bought my son a Civic Si after he totalled his normal Civic. I remember that feature, but he traded the Si in on a WRX STI. I had the original 2002 bugeye WRX, so I'm slightly jealous of "his" STI, even though I make the payments. I sure wish someone had bought me a nice car (or any car) when I was young.
San
post #15 of 41 (permalink) Old 03-31-2019, 12:28 PM
ksm
ksm's Avatar
One good "mod" may be to ensure that all of the recalls have been performed.
'05. Eyes up.
ksm is offline
post #16 of 41 (permalink) Old 03-31-2019, 01:37 PM
glb
glb's Avatar
San
San, this makes you much safer.
I have an extra set of Multivex mirrors and another from RLS.
You never have to turn your head.
g
glb is offline
post #17 of 41 (permalink) Old 03-31-2019, 01:56 PM
XHILR8N!'s Avatar
San
I hear you. My Dad was an automobile dealer and I had all sorts of cars, but never the Lotus I wanted. “You wiill have to do that for yourself son.” Took me decades but evetually got three. So far.
I got my son a nice low mile Nissan 350Z. He modded it to an extreme. Not sure where he got that from?
So I wound up getting him a Mitsub Lancer to have something to actually drive.
2016 370Z Nismo
post #18 of 41 (permalink) Old 03-31-2019, 03:27 PM
glb
glb's Avatar
I would really like to know your thought on that Lexus. Would you mind?
Thx.
g
glb is offline
post #19 of 41 (permalink) Old 03-31-2019, 03:46 PM
The Enforcer
oldmansan's Avatar
Attachment 1227676
He can't have got the "stickers" from you. I won't even address the wing.
San
post #20 of 41 (permalink) Old 03-31-2019, 04:55 PM
XHILR8N!'s Avatar
I deff was never one for stickers. That’s Gunpilot’s specialty.
But that wing is an APR, same brand most of we Lotus folk use. Real track car stuff. He has done a well thought out job with it. And after several attempts got an exhaust system that sounds less like a rolling explosion and more like a performance car.
2016 370Z Nismo
Similar Threads
First mod: Stan's shifter mod hotspoons Lotus Elise 30 05-15-2014 02:41 PM
My best mod to date smokin orange General Discussion (Lotus related) 134 02-28-2011 06:37 PM
Another shifter stiffening mod. (Sector111 + Stan mod + this...) newman General Discussion (Lotus related) 3 01-12-2009 08:20 AM
Pass Airbag Mod / ABS Mod stinkoe General Discussion (Lotus related) 1 05-27-2008 06:09 AM
To Mod or not to Mod...that is the question sjkblack1 General Discussion (Lotus related) 20 01-20-2007 07:23 PM
