A better C64 Transmission - Page 7 - LotusTalk - The Lotus Cars Community
 54Likes
post #121 of 250 (permalink) Old 11-24-2015, 12:44 PM Thread Starter
Elise Guru
fzust's Avatar
When you say half-shafts are you speaking of axles? They are FAR more robust than the transmission. I've broken a couple in 10 years on our XP car but that is from repeated drag launches on slicks at Pros. Axles are quite good.
Winning Suspension
6UL wheels
fzust is offline
post #122 of 250 (permalink) Old 12-12-2015, 08:33 AM
ConeKilla's Avatar
Subscribed. I look forward to seeing this in action next Auto-X season and maybe a reasonable upgrade next winter.
ConeKilla is offline
post #123 of 250 (permalink) Old 12-28-2015, 10:39 PM
sleepe's Avatar
Originally Posted by LionZoo View Post
Hi Fred,
I didn't notice this thread the first time. I'm very interested in knowing why you've decided to keep the stock synchros. My 2nd gear synchro is about to go, and it seems that the 2nd gear synchro is a pretty common failure point in these transmissions. Do you believe that the changes to gear spacing will put less stress on the synchro and keep it from failing?
How many miles have you put on your 2011?
...recently replaced my stock trans with MWR 3.9:1 transmission...
2006 Elise ST (someone else has it now . . . )
2008 Exige S240 ST
sleepe is offline
post #124 of 250 (permalink) Old 02-05-2016, 06:15 AM Thread Starter
Elise Guru
fzust's Avatar
Quick update! Back on track with plans to build and install test box this weekend.
We're going to be doing the these gearboxes on a core-charge swap basis. This way you can keep your car on the road as long as possible, swap out the trans and send us the gearbox back as a core. Alternatively, you can keep the stocker if you like, just pay the core charge.
We should have pricing very soon!
Until then, how about a comparison of stock vs our ring gear?
ERDoc74 likes this.
Winning Suspension
6UL wheels
fzust is offline
post #125 of 250 (permalink) Old 02-05-2016, 07:03 AM
glagola1's Avatar
Beef! Neato.
glagola1 is offline
post #126 of 250 (permalink) Old 02-05-2016, 02:26 PM
Jim-C's Avatar
Wow !
2005 Storm Titanium Elise
BOE Power
www.jcrtd.com
Jim-C is offline
post #127 of 250 (permalink) Old 02-06-2016, 05:53 AM
He's on fire!
jds62f's Avatar
This just got interesting. I have a c60 core thats doing nothing right now....
jds62f is offline
post #128 of 250 (permalink) Old 02-06-2016, 06:20 AM
Ryno's Avatar
As someone that has broken quite a few ring gears and axles I'd much rather have a strong gear box and use the axle as a circuit breaker. Those are fairly easy to replace and get you back in the race.
I sure wish these were SP legal.
Ryno is offline
post #129 of 250 (permalink) Old 02-06-2016, 12:39 PM
not your dad's puns
Turbopun's Avatar
Wow. Gives new meaning to the phrase "beefy fillet" Seriously that is a stout looking profile.
because racecar
Turbopun is offline
post #130 of 250 (permalink) Old 02-07-2016, 12:54 PM
Eyelise's Avatar
Tranny options
Now I have two options I know what I'll be doing with my C64 when I pull it to put in the E153 I had built. BTW this E153 has a set of close ratio KAZ gears and the 3.9 FD which made it very close to the C64 in spacing and total range. Each of the first four gears is slightly taller and the 5th is just a bit short of 6th. I think it will be fine for road courses.
05 Saffron Elise (#151)!!!!!
Nitron NTR singles 550/700
BOE Rev 400, fuel surge tank, EFI 1.2
PPE Testpipe, BOE Silent Touch
RacePak IQ3 dash with EFI module
ACT HD/SS clutch, Fidanza FW, LETSA...
Eyelise is offline
post #131 of 250 (permalink) Old 02-07-2016, 01:19 PM
indifferent's Avatar
Price yet?
indifferent is offline
post #132 of 250 (permalink) Old 02-13-2016, 09:13 AM
purveyor of lightness
darkSol's Avatar
I want to run this transmission with the C65 4.312 final drive, the C60 0.725 6th gear and 245-40-17 tires.
This should yield @ 8500 rpm:
1st: 61 mph <- NICE
2nd: 84 mph
3rd: 112 mph
4th: 136 mph <- won't have to shift to 5th in the quarter mile
5th: 157 mph
6th: 200 mph (yeah right!)
Cartest reports the following (@ 410hp):
0-60: 2.45 seconds
0-100: 6.15 seconds
0-130: 9.66 seconds
0-150: 13.05 seconds
Quarter mile: 10.62 @ 135.92 mph
It's the golden ticket
shay2nak and ERDoc74 like this.
d.a..v...i....d
David Thomas Stewart - [email protected]
2005 Midnight Silver Lotus Elise (www.darksol.com)
388hp (342whp) BOE RevX 1676lbs.
darkSol is offline
post #133 of 250 (permalink) Old 02-13-2016, 12:39 PM Thread Starter
Elise Guru
fzust's Avatar
I know I keep saying "soon" on the pricing. I have the test box nearly together. I keep getting screwed by snap rings. There are about 12 different snap rings with literally 12 different thicknessess. I should have them Tuesday and in the car soon thereafter. I need to get some idea of interest, which requires getting the pricing out there....
Winning Suspension
6UL wheels
fzust is offline
post #134 of 250 (permalink) Old 02-18-2016, 01:18 AM
jojonline's Avatar
Which one is your final drive gear?
The lower one, right?
Why do you grind this with so much stock on flank and without any protuberance?
What about tip relief? chamfers ?
jojonline is offline
post #135 of 250 (permalink) Old 02-18-2016, 04:44 AM Thread Starter
Elise Guru
fzust's Avatar
The lower one is ours. It was a regrind of the proto to fix it, hence the lack of chamfers. Production one will be chamfered.
Winning Suspension
6UL wheels
fzust is offline
post #136 of 250 (permalink) Old 03-09-2016, 04:06 PM
BudUSMC's Avatar
Any update on these being available and pricing? Trans is out and need another one to put in. Right now E153 is really the only option until this is available
2005 Lotus Elise - Storm Titanium
BoE Rev400TVS SC, MWR E153 Trans, ACT HDSS Clutch, 2bular Full Exhaust, Ohlins Double Suspension, BoE Catch Can, BoE TOC Oil Pan and so forth
BudUSMC is offline
post #137 of 250 (permalink) Old 03-09-2016, 04:12 PM
Me too! I just rebuilt mine to stock Toyota spec but plan on breaking it every chance I get....hopefully less than parts plus labor for a standard rebuild as it is not that hard of a diy job if your handy.
2005 Elise, Graphite Grey (soon to be nightfall blue), Ohlins DA, VF2 SC, Volk wheels, LSD, and pretty much everything else on this lemon.
post #138 of 250 (permalink) Old 03-09-2016, 04:46 PM
Trans is on the garage floor. Trying to decide between rebuild, MWR and if this would be an option.
tpearsall is offline
post #139 of 250 (permalink) Old 03-09-2016, 05:12 PM
BudUSMC's Avatar
Originally Posted by tpearsall View Post
Trans is on the garage floor. Trying to decide between rebuild, MWR and if this week be an option.
DITTO, MWR E153 or this if it is actually an option.
BudUSMC is offline
post #140 of 250 (permalink) Old 03-09-2016, 06:03 PM
widebodyelise's Avatar
I was in the same boat I went E-153 remember even though the gear box is stronger it's still the same size clutch. The E-153 has a bigger clutch that was my deciding factor well and this better C64 still not being available
widebodyelise is offline
