Break-in Method for Built Engine - LotusTalk - The Lotus Cars Community
 6Likes
  • 1 Post By Ron-323
  • 1 Post By Harix
  • 1 Post By titaniumdave
  • 3 Post By eldonz
post #1 of 11 (permalink) Old 07-03-2019, 11:24 AM Thread Starter
Installing a new built engine in my 2007 Exige and would like to get advice on break-in (located in the Texas Heat)
The engine was specified for endurance not max hp.
Specs:
ARP hardware for girdle, rods, head, and flywheel
Darton Sleeved Block
forged pistons 10.5 / 1
Ported Head
Stock thickness head gasket
Billet oil pump gears
upgraded valves (stainless) and valvesprings
Harden intake cam with stock grind
Lighten flywheel w/arp bolts
170 degree thermostat
BOE Fastworks Tune
Think of starting with Motul Break-in oil for about 200 miles and going with:
Motul 300V 0w40 https://www.motul.com/us/en-US/produ...0v-trophy-0w40 or
Motul 300V 15w50
https://www.motul.com/us/en-US/produ...ition-15w50--2
Trick Wheels likes this.
Ron-323 is offline
post #2 of 11 (permalink) Old 07-03-2019, 11:37 AM
kfennell's Avatar
I was told 3 changes with Motul 10w40 break in oil during dyno testing and tuning before you even start to drive it by Dave at DDPR.
kfennell is online now
post #3 of 11 (permalink) Old 07-03-2019, 12:03 PM Thread Starter
What do the three changes of the Motul Break-n Oil consist of?
A track day or a mileage #?
Thanks,
Ron-323 is offline
post #4 of 11 (permalink) Old 07-03-2019, 12:07 PM
Race & Pamper
Kubera's Avatar
+1 great question
Kubera is offline
post #5 of 11 (permalink) Old 07-03-2019, 12:18 PM
kfennell's Avatar
Thanks,
I said in my post. before it even gets off the dyno. So assuming my car needed 10 hours on the dyno that is a change every 3 hours or so.
post #6 of 11 (permalink) Old 07-03-2019, 12:43 PM Thread Starter
Thanks - I was not sharp enough to catch that!
What do you recommend after the Break-in?
Ron-323 is offline
post #7 of 11 (permalink) Old 07-03-2019, 01:38 PM
glb
glb's Avatar
Have you consulted with the engine builder??
glb is offline
post #8 of 11 (permalink) Old 07-03-2019, 02:31 PM
kfennell's Avatar
I use motul 8100 5w30 in my track car but I change it a lot.
post #9 of 11 (permalink) Old 07-03-2019, 02:43 PM
A1 Automotive & Smog
Harix's Avatar
As former Toyota tech (21 yrs ago) I can only remember a few manufacturer break-in recommendation:
-Period about 600-1000 miles
->3500 Rpm, light load preferred
->15 miles per warm up
-non synthetic, low to non-detergent oil. May be replaced with fully synthetic after break-in period
That was back then, I don't know if now is different. But I still do the same to all regular passenger vehicle when new and it's been trouble free.
titaniumdave likes this.
Harix is offline
post #10 of 11 (permalink) Old 07-03-2019, 05:01 PM
titaniumdave's Avatar
Break in oil till the rings seat. I will keep the same oil in during the break in but change the filter 2 times, once after the first set of heat cycles...about 1.5 hours. Again after 200 miles or so. The break in oil is actually prompting all the internal parts to wear in, making them fit better and removing any high places in the bearing surfaces and well as helping the rings and cylinder bore wear into a better fit. This is putting micro bits of metal in the oil so a new filter makes sense, but the oil does not break down. The goal is to get the rings to seat and have as much contact as possible which will make them seal better but more importantly creating a better thermal path to get heat out of the pistons and into the cylinder wall where it can be dissipated into the coolant.
eldonz likes this.
2006 Elise with BOE 400 supercharger and some aero mods, CRF floating oversized rotors, MCS single adjust coil overs, CRF exhaust, CRF sway bar w/adjustable link, mono-ball pivots, machined steer arms, baffled oil pan, CRF titanium toe link brace, hardened motor mounts, Ethos wheels w/Yoko slicks
titaniumdave is offline
post #11 of 11 (permalink) Old 07-05-2019, 07:47 AM
eldonz's Avatar
OK, I double checked with my engine builder and this is the process that they use. It takes about 15-30 minutes to break in the cam shaft. You want to change the oil filter after doing this because the high pressure lubes and sloppy use of silicon will clog the oil filter. You can change the oil at the same time to get any other residuals out of the oil but the filter should have most of the garbage in it. The next step is break in the rings which won't really happen until you have cylinder pressure. This takes about 12 good pulls on the dyno. If you had a lot of assembly debris then it would be good idea to change the filter again. Now you can start getting some stable HP numbers on the dyno.
Good Luck,
Eldon
glb, titaniumdave and Trick Wheels like this.
eldonz is online now
