Cars stalls after hard driving - LotusTalk - The Lotus Cars Community
post #1 of 10 (permalink) Old 07-24-2019, 07:59 AM Thread Starter
Parts Finder
Partsfinder's Avatar
At track event, also has happened on street. After running car hard coming to stop at a light (or today off track) car flutters a little below 1000rpm then just shuts off. Does not do it every time. On restart does fine. Any ideas
Past favorites
99 Esprit
02 Eurovan Weekender
62 Falcon 450hp under 2000lbs
(My first power to weight car)
Partsfinder is offline
post #2 of 10 (permalink) Old 07-24-2019, 08:51 AM
kfennell's Avatar
You have an exige S right? They all seem to do that. You can have the throttle minimum increased in the programming, or try to find the possible very small vacuum leak.
kfennell is online now
post #3 of 10 (permalink) Old 07-24-2019, 09:03 AM
eldonz's Avatar
Yep, a known PITA problem. I managed to get mine better by installing multispark coils. They are not cheap.
As Kevin said, you can have the idle increased, this helps, too.
Later,
Eldon
eldonz is offline
post #4 of 10 (permalink) Old 07-24-2019, 11:47 AM Thread Starter
Parts Finder
Later,
Eldon
Thank you for the input. Little glad to hear it’s a common issue. I checked all vacuum lines all look good. I’ll look into both your suggestions. BOE is doing a tune for me so that may be a fix.
Past favorites
99 Esprit
post #5 of 10 (permalink) Old 07-24-2019, 12:10 PM
Addict
LostPawn's Avatar
You can also give it some gas to keep it from stalling, though you have to catch it in time for this to work. Happened to my Exige S as well and wasn't always after hard driving, sometimes it just had a hard time keeping idle.
LostPawn is online now
post #6 of 10 (permalink) Old 07-24-2019, 12:16 PM
eldonz's Avatar
I have a BOE tune and it can still do it. Their solution is to increase the idle RPM so it stays out of the RPM hunting mode. They will most likely set it around 1100-1200 RPM.
Later,
Eldon
eldonz is offline
post #7 of 10 (permalink) Old 07-24-2019, 12:24 PM
AKA “Prolene”.
I have gotten OBD codes occasionally for high idle. When idle settles at sub 1K I get no code.
Elise #2393 Bordeaux/Biscuit Interior/Touring and Sport Packs/HT/Lotus Sport ECU/GPan3/DSBrace/Quantum Black SA Dampers/Lowered, Corner Weighted/Radium Catch Can/HKS Special Edition Exhaust/New "3M" Starshield/WindowTinting. Purchased new 06/01/05.
First in Class 2008 Speed Ventures Lotus Challenge Series.
Prolene2 is offline
post #8 of 10 (permalink) Old 07-24-2019, 12:40 PM
eldonz's Avatar
Mine idles at 1100-1200 all day long with no codes. What code do you get?
Later,
Eldon
eldonz is offline
post #9 of 10 (permalink) Old 07-24-2019, 07:27 PM
AKA “Prolene”.
Later,
Eldon
It could have been P0507. Haven’t had it in awhile. Just erased code and see what happened.
Prolene2 is offline
post #10 of 10 (permalink) Old 07-26-2019, 08:57 AM Thread Starter
Parts Finder
Later,
Eldon
Only code is P0139 do to o2 sensor not in stream
Past favorites
99 Esprit
