Dallas Reedís >700whp turbocharged k20 Elise - Page 5 - LotusTalk - The Lotus Cars Community
 10Likes
post #81 of 94 (permalink) Old 03-12-2017, 06:26 AM Thread Starter
because racecar
dallasreed's Avatar
I'm not sure it was ever run at the strip before the sequential was added. The 9 sec pass was done with a no lift shift setup
2005 Lotus Elise turbo k20a2 757whp 536wtq 31psi [email protected]
2005 Lotus Elise 2zz supercharged 'streetable' race car
2007 Lamborghini Gallardo Spyder
2010 Ford F350
2004 Mazda RX8
2007 Mazda Mazdaspeed 3
2010 Ford Fusion Hybrid
I passed my license test in a 3cyl 70hp Geo Metro
I learned to drive a manual on a Lotus Elise
dallasreed is offline
post #82 of 94 (permalink) Old 03-12-2017, 08:17 PM
Can you explain what no lift means? I'm not really educated into the sequential stuff.
Formula313 is offline
post #83 of 94 (permalink) Old 03-12-2017, 08:18 PM
post #84 of 94 (permalink) Old 03-12-2017, 08:22 PM Thread Starter
because racecar
dallasreed's Avatar
The gear controller cuts power quickly instead of having to manually lift your foot from the throttle during upshifts.
2010 Ford F350
2004 Mazda RX8
post #85 of 94 (permalink) Old 03-12-2017, 08:32 PM
That makes a lot of sense. What's your target goal ? 8?
post #86 of 94 (permalink) Old 03-13-2017, 11:16 AM Thread Starter
because racecar
dallasreed's Avatar
Just in it for the fun.
2010 Ford F350
2004 Mazda RX8
post #87 of 94 (permalink) Old 03-13-2017, 11:28 AM
If it was for fun you would have a manual.
XtinctElise likes this.
post #88 of 94 (permalink) Old 03-16-2017, 09:08 AM
Soundeffects's Avatar
Glad to hear your making progress on this amazing build!
Soundeffects is offline
post #89 of 94 (permalink) Old 03-16-2017, 10:25 AM Thread Starter
because racecar
dallasreed's Avatar
There's nothing quite like a sequential upshift
2010 Ford F350
2004 Mazda RX8
post #90 of 94 (permalink) Old 03-18-2017, 12:33 PM
I PM'd you Dallas. Do you have any logs comparing the shifting before and after the geartronics?
post #91 of 94 (permalink) Old 05-11-2017, 10:26 AM Thread Starter
because racecar
dallasreed's Avatar
Still ironing out bugs, but things are coming along. Things are on track to run it at a test n tune autocross in about 2 weeks, and Putnam Park / road course should be in the works for no later than July. I suspect it will take a good bit more testing and tweaking to get the car 100% for that sort of usage but it is coming along.
Various little things. More, gauges, catch can, oil cooler. Modifications to the motor mounts (had the left one shear at tx2k this year and the oil pan puncture when it shifted and made contact with the subframe!) Only ran the car on low boost up and including the breakage. Trapped 130 something.
The car runs surprisingly cool.
The geartronics / blipper has been problematic. Not sure if there is an issue with slop the barrel in the trans or something similar but it is hard to get consistent readings from the barrel sensor for blip/cut timing.
The wing makes a massive difference in the sketchiness, breaking loose, grip factor.
2010 Ford F350
2004 Mazda RX8
post #92 of 94 (permalink) Old 05-12-2017, 10:52 AM
Ryno's Avatar
Do you think the wing helps or hurts in the 1/4 times? Just wondering if the additional grip outweighs the added drag.
Ryno is offline
post #93 of 94 (permalink) Old 05-12-2017, 10:55 AM Thread Starter
because racecar
dallasreed's Avatar
Id assume it hurts. It feels slower but it sticks and is a ton more stable
2010 Ford F350
2004 Mazda RX8
post #94 of 94 (permalink) Old 12-15-2017, 04:17 AM
Mobius0034's Avatar
Dallas,
I am starting my own Honda turbo swap. Couple questions, you are still running stock cams? And you cut the clam your self for the wider wheel setup? any advice on that?
Thanks!
Mobius0034 is offline
