Elige reverse lockout permanent disable? - LotusTalk - The Lotus Cars Community
post #1 of 1 (permalink) Old 02-01-2019, 10:51 PM Thread Starter
Varun916's Avatar
I'd like to semi-permanently disable the lockout collar/mechanism, but leave the door open for restoring it later if necessary. I think a couple of set screw collars on the lockout cable should do it, allowing me to remove the collar from the shift rod. I'm planning on machining a steel H pattern shift gate, so the lockout mechanism has to go.
Was wondering if there was any potential issue driving around with the lockout in the "always unlocked" position, aside from the obvious intent of the lockout. I feel like the lockout is overkill, given the position of reverse, and given that there's a resistance "hill" to get to reverse, just like Porsches(which don't have a lockout).
Any concern about damaging the transmission driving with it in the up position?
Varun916 is offline
Similar Threads
Permanent Alarm/Imobilizer disable possible? GR82DRV General Discussion (Lotus related) 22 05-08-2013 03:54 PM
Traction Control permanent disable? trompazo Engine Control (ECU) 27 07-21-2008 02:40 PM
Reverse lockout problem MikeC Maintenance and Repairs. 2 07-14-2006 06:28 AM
Reverse Lockout Broke AGAIN azskycop Maintenance and Repairs. 8 11-04-2005 04:26 PM
Reverse lockout ring stuck drosen Powertrain (Engine, Transmission, etc) 15 06-21-2005 06:47 AM
