Gear oil change question - LotusTalk - The Lotus Cars Community
 2Likes
  • 1 Post By glb
  • 1 Post By glb
post #1 of 6 (permalink) Old 08-27-2017, 02:43 PM Thread Starter
mness4's Avatar
I'm planning to change my tranny fluid soon using the following procedure:
Lotus Elise Maintenance, Drain and Refill Gearbox Oil
The instructions say to pump in gear oil until it starts to drip out. Is the assumption that the car is level on jack stands? How sensitive is exact level of the the gear oil? If I only have the rear of the car on Rhino ramps, will this procedure still give the right level of gear oil?
Thanks,
Mike
mness4 is offline
post #2 of 6 (permalink) Old 08-27-2017, 03:31 PM
You want to level it out as much as possible. Put stands on the front and rear. It's not much more work to get it done right.
Nessal is offline
post #3 of 6 (permalink) Old 08-27-2017, 09:42 PM
glb
glb's Avatar
I got really good shifting:
5. The best transmission lube Iíve found is Redline MT-90 plus a little Power Punch Extreme Gear Oil Additive. (Note that it takes two changes to get rid of the previous lube.)
a) Early cars have wobbly shift towers. Look up Stanís Mod (bolt and spacer; http://www.billswebspace.com/ShifterReinforcement.pdf) and
https://www.inokinetic.com/lotus/re-...y=Transmission
nacho.martinez likes this.
Driving Tips-https://www.lotustalk.com/forums/f100...art-1-a-49665/
Moss Emergency Line-https://www.lotustalk.com/forums/f100...cy-line-36631/
Safely Piercing Wires-https://www.lotustalk.com/forums/f129...esting-106438/
Bleeding Brakes- https://www.lotustalk.com/forums/f101...-brakes-241138
glb is online now
post #4 of 6 (permalink) Old 08-28-2017, 10:15 AM
David Craig's Avatar
I've changed the transmission oil twice now. Each time I had the rear on ramps but also the driveway had roughly the right slope so that the engine was level. Perhaps your driveway has a slope too?
David Craig is offline
post #5 of 6 (permalink) Old 08-28-2017, 11:59 AM
glb
glb's Avatar
I don't believe it's that important. Been driving 5 decades....
Nevinear likes this.
glb is online now
post #6 of 6 (permalink) Old 08-28-2017, 12:19 PM
Nevinear's Avatar
I will admit I am one of the OCD people that jacks up the car up front to be level for such things, but it probably doesn't matter, I can imagine the difference in fluid only being a few milliliters... Maybe on transmissions that are known to be sensitive to oil levels (I don't think ours is).
Nevinear is offline
