Gearbox oil for Elise 111R? - LotusTalk - The Lotus Cars Community
post #1 of 2 (permalink) Old 11-13-2018, 02:24 AM Thread Starter
Hi everyone,
SSC informed the previous owner that they put in Redline Lightweight Shockproof gearbox oil in my car in 2015. Gear changes seem to be ok.
I've been doing a bit of research and I get varying thoughts about this oil in our gearboxes. Some people say can use the RL shockproofs and some say only use Redline MT-90.
Interested in your thoughts, thanks!
noisuf is offline
post #2 of 2 (permalink) Old 11-13-2018, 10:06 AM
glb
glb's Avatar
See #5
Stock: “Excuse me”
Stebel: “HONK! LOOK OUT!”
3. The early cars came with misaimed and dim headlights. If you drive at night, convert to HIDs. While better than stock halogen bulbs are available, HIDs throw more light. Stay around 5000k.
5. The best transmission lube I’ve found is Redline MT-90 plus a little Power Punch Extreme Gear Oil Additive. (Note that it takes two changes to get rid of the previous lube.)
https://www.inokinetic.com/lotus/re-...y=Transmission
For street cars, consider removing one or both oil coolers. Some cover them.
https://www.lotustalk.com/forums/f311...-u-tube-47232/
https://www.lotustalk.com/forums/f320...ramming-70940/
14. Visit the Uber Thread
https://www.lotustalk.com/forums/f3/e...ow-here-25131/
Plus, “How to bleed brakes”:
https://www.lotustalk.com/forums/f101...brakes-241138/
How to Search:
Driving Tips-https://www.lotustalk.com/forums/f100...art-1-a-49665/
Moss Emergency Line-https://www.lotustalk.com/forums/f100...cy-line-36631/
Safely Piercing Wires-https://www.lotustalk.com/forums/f129...esting-106438/
Bleeding Brakes- https://www.lotustalk.com/forums/f101...-brakes-241138
glb is offline
