High idle and drop very slowly - Page 4 - LotusTalk - The Lotus Cars Community
 2Likes
post #61 of 145 (permalink) Old 03-19-2014, 07:49 PM
Puff Daddy
Bane's Avatar
Are you SURE it's not leaking somewhere in the intake tract?
I've seen people post they had a slight leak between the supercharger and the intake manifold.
Mine is still doing it also. I have no engine codes or anything to help me narrow down what the issue is so I'm just driving around it
I may try swapping out the intake this weekend to see if that helps it...
Bane is offline
post #62 of 145 (permalink) Old 04-15-2014, 07:02 AM Thread Starter
HKFEVER's Avatar
Any luck for your swap?
HK Lotus dealer told me that there is no leak
S240 Exige S with BOE FW300 + over 40 mods
HKFEVER is offline
post #63 of 145 (permalink) Old 04-15-2014, 07:05 AM Thread Starter
HKFEVER's Avatar
Weather is warming up. With A/C on is even worst.
HKFEVER is offline
post #64 of 145 (permalink) Old 04-15-2014, 06:03 PM
Puff Daddy
Bane's Avatar
No luck. I swapped out the entire intake system upstream of the throttle body and it still does it.
I plan on removing the throttle body, cleaning the idle control valve, and checking all the mechanical bits in it next.
If that doesn't work... I'll have to try the pedal assembly
Bane is offline
post #65 of 145 (permalink) Old 04-15-2014, 08:11 PM Thread Starter
HKFEVER's Avatar
Do you mean all the parts starting from the head backward all the way to the throttle body?
Re toque all the bolts?
HKFEVER is offline
post #66 of 145 (permalink) Old 04-15-2014, 09:00 PM
Puff Daddy
Bane's Avatar
No, upstream of the throttle body which means (on my car) the rubber intake tube and the airbox primarily.
Hopefully I will have time on Friday to remove the throttle body and will report back as to what I find.
Bane is offline
post #67 of 145 (permalink) Old 04-21-2014, 08:30 AM Thread Starter
HKFEVER's Avatar
Why there is no fix for this issue? Anyone?
HKFEVER is offline
post #68 of 145 (permalink) Old 04-22-2014, 07:50 AM
Stealthy Blackmobile
freshyip's Avatar
Are we still stuck???
"...Make Every Road Your Own....."
2007 Lotus Exige S
freshyip is offline
post #69 of 145 (permalink) Old 04-22-2014, 11:34 AM
Now that's frustrating.... :-(
2006 Elise Magnetic Blue | BOE REV300tvs SC kit with 85mm pulley, ITG airbox, Exedy Sport Clutch, 2bular Headers, 2bular Silenced Decat, 2bular 8x22 Oval Tip Exhaust, Black Exige Rear Diffuser, Black Forged 7spoke wheels, BOE Uprated Rear Engine Mount, Exige V6 Mirror Plinths, etc... (SOLD)
stekki is offline
post #70 of 145 (permalink) Old 04-22-2014, 08:52 PM Thread Starter
HKFEVER's Avatar
No, luck.
HKFEVER is offline
post #71 of 145 (permalink) Old 06-22-2014, 04:05 AM
hi HKfever, any luck on ur car ?
mokwcw is offline
post #72 of 145 (permalink) Old 06-22-2014, 08:16 AM
Puff Daddy
Bane's Avatar
Mine resolved on it's own...
It started getting noticeably better and now appears to be just about 100% gone. I have no good explanation for this. The only thing that's changed is it's a lot hotter out now... maybe the warmer ambient temperature could be affecting the pedal assembly?
Bane is offline
post #73 of 145 (permalink) Old 06-27-2014, 10:35 PM
sleepe's Avatar
Assuming the problem is not resolved I have some advice: Chill out
Let the car adjust to the all the parts you've been throwing at it. It needs
a breather. Drive it frequently and go through lots of ready cycles (meaning engine on/off..on/off..)
2006 Elise ST (someone else has it now . . . )
2008 Exige S240 ST
sleepe is offline
post #74 of 145 (permalink) Old 06-28-2014, 12:58 AM
The Enforcer
oldmansan's Avatar
He's been having issues for 4.5 years and your advice is to chill out? Insert face plant emoticon here.
San
oldmansan is offline
post #75 of 145 (permalink) Old 06-28-2014, 01:53 AM
sleepe's Avatar
that's my advice...yes...life is not ending if your idle is a little high: BFD
2008 Exige S240 ST
sleepe is offline
post #76 of 145 (permalink) Old 06-28-2014, 08:49 AM
Puff Daddy
Bane's Avatar
San
I believe you mean facepalm
Facepalm | Know Your Meme
In all seriousness, I still think mine was due to something not being quite right in the ECU. The weird thing is it never settled down (even after over a thousand miles) with the stock airbox on. Now that I have an aftermarket one on there it seems to be running fine which means my stock airbox must have been leaking past the MAF (and I can't find any evidence of that)...
Bane is offline
post #77 of 145 (permalink) Old 07-03-2014, 08:23 AM
Vroom vroom
Swic's Avatar
https://www.lotustalk.com/forums/f25/...gh-idle-98214/
2005 CO Elise: stage II CLF exhaust, B&M shifter, 5.25"/6.5" speakers, footwell lighting, RLS side mirrors, and 2 Dartholders (caffeine injection improves performance)
Uncage your garage queen and quit being a pansy. Daily drive it!
Swic is offline
post #78 of 145 (permalink) Old 08-22-2014, 07:41 PM Thread Starter
HKFEVER's Avatar
Oh man, mine is 2008+ DBW version.
HKFEVER is offline
post #79 of 145 (permalink) Old 08-22-2014, 08:37 PM
freshyip's Avatar
It's also been taught all over the internet that CABLE throttle bodies can be fixed, but hkfever's is by WIRE: which means electronic.
2007 Lotus Exige S
freshyip is offline
post #80 of 145 (permalink) Old 04-10-2015, 10:41 PM Thread Starter
HKFEVER's Avatar
My issue still there. Damn
Can anyone advise how to tighten the bolts of the intake?
Lotus dealer can't help: - They tried lots of things
UK ran out of suggestion.
HKFEVER is offline
