High idle and drop very slowly - Page 5 - LotusTalk - The Lotus Cars Community
 2Likes
post #81 of 145 (permalink) Old 04-13-2015, 04:53 AM Thread Starter
HKFEVER's Avatar
Nobody?
S240 Exige S with BOE FW300 + over 40 mods
HKFEVER is offline
post #82 of 145 (permalink) Old 04-16-2015, 07:11 PM Thread Starter
HKFEVER's Avatar
Can anyone advise how to tighten the 5 bolts of the intake?
I can't reach the bottom bolts
HKFEVER is offline
post #83 of 145 (permalink) Old 04-18-2015, 01:58 AM Thread Starter
HKFEVER's Avatar
So sad
HKFEVER is offline
post #84 of 145 (permalink) Old 04-24-2015, 07:53 AM Thread Starter
HKFEVER's Avatar
Purchased all the O rings and gasket.
Anybody know the torque spec. for those 5 bolts for the head and manifold?
HKFEVER is offline
post #85 of 145 (permalink) Old 05-08-2015, 11:35 PM Thread Starter
HKFEVER's Avatar
After took off the SC, these 2 pictures were what I found.
Replaced the gasket, put everything back.
But did not fix the problem, it just get a little better.
Car was able to crawl up 3 level parking slope. After the fix, it can only crawl 1/2 level
But why not fix right the way? Anything I missed.
These are the pictures that I took after the manifold was off. Why is the leak in blue?
HKFEVER is offline
post #86 of 145 (permalink) Old 05-09-2015, 07:08 AM
Motard's Avatar
What an Odyssey man...
I would jerk the entire intake tract off. Reseal/ torque everything.
For some reason I thought you already have done that, but I see your just to the intake manifold. I would take that off too... Everything. That way you know your problem has nothing at all to do with intake...
Could your intercooler be faulty?
L O T U S
Motard is offline
post #87 of 145 (permalink) Old 05-09-2015, 07:18 AM Thread Starter
HKFEVER's Avatar
Have checked and changed almost every parts multi times!
HKFEVER is offline
post #88 of 145 (permalink) Old 05-09-2015, 08:07 AM Thread Starter
HKFEVER's Avatar
I have already taken off the intake manifold, as the pictures show.
Have checked and replaced:
- Airbox
- MAF
- Vacuum lines
- Soft goose neck from airbox to TB
- Throttle body
- Intercooler silicon tubes
- Intercooler
- Temp sensor on intercooler to check leak
- Intake manifold gasket
What else I have miss?
HKFEVER is offline
post #89 of 145 (permalink) Old 05-09-2015, 08:46 PM Thread Starter
HKFEVER's Avatar
This is before in 2013 year end:
This is after replace intake manifold gasket on May-08-2015:
But still has this:
Any fix?
Can anyone post their idle video to compare?
HKFEVER is offline
post #90 of 145 (permalink) Old 05-10-2015, 06:37 AM
David Craig's Avatar
I will see what mine does. I believe it settles to 800 rpm more quickly than yours but I'll make an effort to check the next time I'm using the car.
Yesterday I disconnected my MAF and drove around for about 20 minutes to see what effect it would have. At 120 km/hr it was about the same as normal. At startup though the car would run rough and idle at 600 rpm and sometimes stall out.
I was checking out the theory that if the car runs better without the MAF then one needs a new MAF.
2009 Saffron Elise
David Craig is offline
post #91 of 145 (permalink) Old 05-10-2015, 07:07 AM Thread Starter
HKFEVER's Avatar
As far as I can remember, it should settles to 800 more quickly.
As far as I can remember, if short burst the gas paddle to 1800, it should drop back to 800 and shouldn't have a jump around 1200.
So might be still leaking somewhere or some sensor has issue. ie the post cat O2 sensor? or else?
HKFEVER is offline
post #92 of 145 (permalink) Old 05-10-2015, 09:11 PM
shay2nak
shay2nak's Avatar
RE: the last video of the idle.
That's the problem? I mean is that really a problem? Maybe that's from the ECU controlling the idle in that way? I can't say for sure since I don't drive my car that much, but I do believe my car has done that once in a while.
'07 Lotus Exige S310
WTC 2
shay2nak is offline
post #93 of 145 (permalink) Old 05-10-2015, 09:29 PM Thread Starter
HKFEVER's Avatar
Dude, please help to post some video of your idle with:
- Paddle to 3000rpm that release the paddle very quick
- Short & fast burst to 1800-2000rpm than release the paddle very quick
HKFEVER is offline
post #94 of 145 (permalink) Old 05-11-2015, 03:59 AM
I checked my car today. Mine responds pretty much like your third video with the exception that yours rises a bit and then falls back. Mine does not rise.
Yours goes to 1100 and then blips up to 1400 and settles back. When yours is doing that mine is hanging around 1200. The rest pretty much matches my car.
2009 Saffron Elise
post #95 of 145 (permalink) Old 05-11-2015, 04:38 AM
RBH
RBH's Avatar
Here is a video of mine. Hope it helps
Do it once. Do it right.
RBH is offline
post #96 of 145 (permalink) Old 05-11-2015, 05:55 AM
Motard's Avatar
At this point could it be anything other than the ECU?
Or possibly a strange reading from a sensor? I have had a issue bother me for a few months before sorting out, but never years.
How is it that LOTUS can just more or less walk away without a solution?
L O T U S
Motard is offline
post #97 of 145 (permalink) Old 05-11-2015, 05:59 AM
Mine was like RBH's video - at least during the first 27 seconds.
I didn't see the upwards blip that he has later in the video.
2009 Saffron Elise
post #98 of 145 (permalink) Old 05-11-2015, 06:40 AM Thread Starter
HKFEVER's Avatar
http://www.youtube.com/watch?v=kZj2XnHTGzo
Yours is almost like mine
As far as I remember, there shouldn't have the jump at around 1100rpm (with short fast burst on gas paddle)
HKFEVER is offline
post #99 of 145 (permalink) Old 05-14-2015, 12:51 AM Thread Starter
HKFEVER's Avatar
Anymore video?
HKFEVER is offline
post #100 of 145 (permalink) Old 05-14-2015, 04:26 AM
Mine's very similar to RBH. The little blip or hang at 12-1300 rpm is a bit random (not exactly the same every time), I've always considered it normal. I think it's just a by-product of the ECU tune. I have a KoldFire tune, but I think it is pretty much the same with the stock S240 tune (though idle is more steady on the KF tune). FWIW, I did have an intermittent stalling and "lean bank 1" issue when my car was new, the dealer replaced the SC/intake manifold gasket on warranty, and it's been fine since.
-Ed
'08 Arctic Silver Exige S240
AustinP is offline
