HOW MANY BLOWN ALTERNATORS??? - Page 3 - LotusTalk - The Lotus Cars Community
post #41 of 57 (permalink) Old 08-14-2008, 04:14 PM
OSX Black hat
charliex's Avatar
yes indeed.
Black Exige S / Elan M100. Don't run a smaller pulley without an upgraded fuel pump! http://www.goth.am ecu stuff.. New reflash box coming soon!
charliex is offline
post #42 of 57 (permalink) Old 08-16-2008, 10:31 AM
choi0706's Avatar
choi0706 is offline
post #43 of 57 (permalink) Old 08-16-2008, 10:46 AM Thread Starter
perryeyges's Avatar
I'll pass on the $840.. 1/2 price? - I'll take one!
perryeyges is offline
post #44 of 57 (permalink) Old 08-16-2008, 10:54 AM
choi0706's Avatar
the weight savings would justify the ducting..
Jay-05' ST, HT, Touring Red
choi0706 is offline
post #45 of 57 (permalink) Old 08-16-2008, 01:29 PM Thread Starter
perryeyges's Avatar
The duct will draw off the inside of the right hand rear 1/4 scoop and with a fan and duct I have a total of $27 invested. I appreciate you offering up the idea but $800+ is just way wrong....
I am guilty of spending stupid $$ on things like a Dry carbon undertrayand titanium wheel bolts, etc.(@Sector111) but they do have at least some trick/bling factor. An alternator for four times the price of the OE unit is not happening for me..
post #46 of 57 (permalink) Old 11-11-2008, 07:39 PM
Alternate cooling solution for the alternator
I was inspired by Perry and others to add a cooling hose to keep my
alternator & its regulator from over-heating after adding the VF SC kit.
After a track day at Laguna Seca (daytime temps maxed out at 65 F),
i could feel that the striped, black hose (see pic 3) was cool in front
of the orange cooling hose but warmer closer to the engine block. This was verified
by another Lotus driver, Jerry. I could even put my fingers on the alternator
regulator and it wasn't hot.
Below are pics of
<ul>
<li>Exterior of the passenger side grill (pic #1),
<li>Inside of the passenger wheel well (pic #2),
<li>Pic above the alternator where the hose was compressed to a rough oval shape to fit below the black hose with the reddish stripe (pic #3),
<li>ABS plastic sheet used to form a shroud to limit air movement (preventing air from going behind or above the hose on the left, but allowing air to flow thru the hose and to the right of the hose (pic #4)
<li>Shroud installed after bending it to fit. (pic #5)
</ul>
Sold: 2005 Saffron Yellow Elise, Sport/Touring, SA Nitrons, VF Stg2, 2bular hdr/sport cat, 2bular 8" exhaust, Saikou CC, shifter mods, SSC shifter cable, LETSLA, FF engine damper, ACT/Toda, AEM AFR/oil temp gauges, PLX vac/boost and IAT sensors with dash-mounted DM100 display, RTV toelink, Moroso oil pan, AlumDiffuser, FF spoiler, 5-pt harness
2002 Silver M3, SMG, Ground Control suspension, AP Racing BBK, RAC RS110s --sold--
biodan is offline
post #47 of 57 (permalink) Old 01-12-2009, 01:48 PM
plastique999's Avatar
sweet setup dan
2011 Final Edition S260 Isotope Green
2005 Track Elise LotusCupUSA
2008 211 FS
plastique999 is offline
post #48 of 57 (permalink) Old 01-12-2009, 01:51 PM
Originally Posted by exarkun1178 View Post
i blew my alt a few weeks ago.
not sure why, but i have placed new heat shielding around the new one....
How did you heat shield yours?
2008 211 FS
post #49 of 57 (permalink) Old 01-12-2009, 01:56 PM
Bavarian Motorist's Avatar
Will having no rear panel help with the heat issue? My Reverie diffuser is being installed now.
Best Auto Insurance | Auto Protection Today | FREE Trade-In Quote
Bavarian Motorist is offline
post #50 of 57 (permalink) Old 01-12-2009, 02:40 PM
Well I have the rear panel delete as well, still had the problem with the alternator.
2008 211 FS
post #51 of 57 (permalink) Old 01-12-2009, 02:48 PM
Did you wrap the headers?
post #52 of 57 (permalink) Old 01-12-2009, 04:03 PM
I'm on stock headers....my setup is 2bular decat, 2bular exhaust....
so headers aren't wrapped...
2008 211 FS
post #53 of 57 (permalink) Old 06-17-2019, 01:14 PM
Phil S's Avatar
Can ANYONE identify the Toyota or other part number for the 2007 Elise alternator?
The genuine lotus part in Canada lists for over $2600!
I have been searching the forums and the net but can’t get a definitive answer.
BWR SC, LETSLA, BWR sway bar, Nitron Sport Pro, RTD, LSS R6, LSS 048, HT, HID, 5 pt Schroth, 111 V brace, Boomerang, Stage II, Manly mounts
Phil S is offline
post #54 of 57 (permalink) Old 06-17-2019, 01:47 PM
glb
glb's Avatar
Use search method on bottom of list.
Stock: “Excuse me”
Stebel: “HONK! LOOK OUT!”
3. The early cars came with misaimed and dim headlights. If you drive at night, convert to HIDs. While better than stock halogen bulbs are available, HIDs throw more light. Stay around 5000k. As of this writing LEDs are not as good.
5. Transmission:
The best transmission lube I’ve found is Redline MT-90 plus a little Power Punch Extreme Gear Oil Additive. (Note that it takes two changes to get rid of the previous lube.)
And, use:
https://www.inokinetic.com/lotus/re-...y=Transmission
For street cars, consider removing one or both oil coolers. Some cover them. Oil doesn’t get hot enough on street, leading to cam wiping.
https://www.lotustalk.com/forums/f311...-u-tube-47232/
https://www.lotustalk.com/forums/f320...ramming-70940/
You NEED a digital multimeter (voltmeter) to work on modern cars. Handy around house too. Get one this week.
14. Visit the Uber Thread
https://www.lotustalk.com/forums/f3/e...ow-here-25131/
Plus, “How to bleed brakes”:
https://www.lotustalk.com/forums/f101...brakes-241138/
How to Search:
One example:
Don't know, but if you want to buy one, make sure you order the Celica GT-S manual transmission alternator. It is designed for higher revs.
"Toyota Parts" - OnlineToyota Parts and Accessories.
Choose Toyota Celica, Year 00-05, GT-S, manual transmission
$201.30
It is going to be refurbished. I don't know if you can even buy a new one. A refurbished alternator is just like new, though. I think the only part they don't replace is the casing and that is going to be clean as a whistle.
Make absolutely sure it is for the GT-S manual transmission, no matter where you buy it.
https://www.lotustalk.com/forums/f12...-toyota-62540/
glb is offline
post #55 of 57 (permalink) Old 06-17-2019, 02:09 PM
2011 chrome orange's Avatar
I do not own an Elise, just trying to help.... check this old thread. Not sure its for a 2007 but maybe will help??
https://www.lotustalk.com/forums/f10...ernator-44812/
Good luck!
2011 chrome orange is offline
post #56 of 57 (permalink) Old 06-17-2019, 08:15 PM
Lotus Part #A120E6369S
You can buy any aftermarket 80amp unit made for the 2ZZ-GE. Searching for a Toyota Celica GTS alternator on RockAuto.com or the like will get you a compatible alternator.
mwehnes is offline
post #57 of 57 (permalink) Old 06-18-2019, 06:44 PM
Phil S's Avatar
Done
Phil S is offline
