How to repair (straighten) header flange? - LotusTalk - The Lotus Cars Community
post #1 of 8 (permalink) Old 12-29-2008, 10:55 PM Thread Starter
shay2nak
shay2nak's Avatar
If a header's flange is not completely flat. (the flat piece that goes against the motor) What's the best way to even out the surface? Have a machine shop grind it flat?
also, the cat was damaged in shipping and I've already had a muffler shop make the outlet round again. It was a bad dent that flattened out a portion of the edge. Hopefully I won't have installation issues with that.
thanks!
'07 Lotus Exige S310
WTC 2
shay2nak is offline
post #3 of 8 (permalink) Old 12-30-2008, 11:19 AM
Moderator Extraordinaire!
tesprit's Avatar
If the header is not used, have the machine shop true up the flange using a press and then take a thin skim off the flange surface using a surface grinder if needed. If the header flange is warped from use, it may be better to have the flange ground flat because the header flange warped as a result of stress relief and it will likely try to warp again the next time it is heated if it is just pressed back to being flat.
tesprit is offline
post #4 of 8 (permalink) Old 12-30-2008, 11:40 AM
Jack's Avatar
Ara,
Here's some advice relating to your issue from DMH...for what it's worth....
"No flange is perfectly flat after welding -- none. If you know how to install them, it just doesn't matter. And if you have to ask how, you shouldn't be undertaking the work."
Jack
2008 2-Eleven
2015 Exige CupR
Jack is offline
post #5 of 8 (permalink) Old 12-30-2008, 11:53 AM
dmh
dmh's Avatar
Originally Posted by Jack View Post
Ara,
I was just being smug. Torque the flange bolts when hot/warm and it will be just fine.
"Political correctness is a doctrine, fostered by a delusional, illogical minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end."
dmh is offline
post #6 of 8 (permalink) Old 12-30-2008, 05:41 PM
Inactive
dstevens's Avatar
No flange is perfectly flat after welding, that is why you then grind it flat on a surface plate.
2005 Elise with Honda engine
Please don't PM me - this forum is no longer usable and I do not monitor it.
It was fun while it lasted.
dstevens is offline
post #7 of 8 (permalink) Old 12-31-2008, 08:31 PM Thread Starter
shay2nak
shay2nak's Avatar
Thanks all for your advice!
Ara,
I have never worked on cars before the Lotus. I've tried to do all the work on this car myself. Save when I don't have time and I get impatient with all the goodies lying around. So I don't know all the tricks just yet.
Yeah, that's what I'm gonna do. By advice, I will re-torque the flange bolts after 500 miles. Maybe at 250 miles and 500...
WTC 2
shay2nak is offline
post #8 of 8 (permalink) Old 07-07-2017, 05:13 PM
thanks!
I found a solution to warped, weakened header flanges.
JoePublicVA is offline
