Inokinetic CG/GS Shifter Cables? - LotusTalk - The Lotus Cars Community
 3Likes
  • 2 Post By AustinP
  • 1 Post By AustinP
post #1 of 9 (permalink) Old 07-20-2019, 08:44 PM Thread Starter
Stealthy Blackmobile
freshyip's Avatar
hi all,
anybody using Inokinetic CG/GS Shifter Cables?
how they compare with SSC Cables?
Car is on 2007 S2 Exige S220
"...Make Every Road Your Own....."
2007 Lotus Exige S
freshyip is offline
post #2 of 9 (permalink) Old 07-21-2019, 09:56 PM Thread Starter
freshyip's Avatar
wow nobody has the Inokinetic cables????
2007 Lotus Exige S
freshyip is offline
post #3 of 9 (permalink) Old 07-22-2019, 03:18 AM
I have them, theyíre good quality, definitely an upgrade from the stock cables, but I have no experience with the SSC cables. I think the challenge is finding someone that has experience with both. You probably canít go wrong either way. I installed the cables at the same time that I installed the LETSLA and the ShiftR111, the end result was excellent, but I canít separate out how much each contributed.
HTH, -Ed
Caseman and SS Lotus Elise like this.
-Ed
'08 Arctic Silver Exige S240
AustinP is online now
post #4 of 9 (permalink) Old 07-22-2019, 03:20 AM
BigHair's Avatar
I have the InoKinetic cables and it was a big improvement over the OEM cables; My cables were binding pretty bad though. I can't give you a comparison since I don't have any experience with new OEM cables or the other cable set you mentioned. I also replaced the shift assembly with the InoKinetic one and added the LETSLA linkage at the transmission at the same time. My opinion is this combination gives very acceptable shift performance and feel now. Best regards...
06 Lotus Elise: Ardent Red, Sport+Touring, ShiftR111, S111 TransCables, LETSLA, Driving lights
02 Honda S2000: Spa yellow, Berk Hi-flow Cat, Alpine head unit, Focal speakers
09 Honda Civic EX Coupe: Stock winter bomber
BigHair is online now
post #5 of 9 (permalink) Old 07-22-2019, 04:13 AM
HTH, -Ed
I should qualify my "end result was excellent" comment, because the shift quality is still highly dependent on the transmission itself (the one component I didn't change). By watching the motion at the transmission while the shift lever was wiggled while in gear, I could tell that most or all of the remaining slop at the shifter was due to internal slop within the transmission.
-Ed
BigHair likes this.
post #6 of 9 (permalink) Old 07-22-2019, 05:17 AM
kfennell's Avatar
I've driven both and I think the inokinetic cables were better, but like was just said above, it depends so much on the transmission and the cable routing that its harder to compare then you would think.
kfennell is online now
post #7 of 9 (permalink) Old 07-26-2019, 01:23 PM Thread Starter
freshyip's Avatar
thanks for all da responses guys!
hi kfennell, how you compare inokinetic cables vs ssc cables?
and what makes you say the inokinetic ones are better? in which sense?
plssssssssss reply shortly!
2007 Lotus Exige S
freshyip is offline
post #8 of 9 (permalink) Old 07-26-2019, 05:03 PM
Parts Finder
Partsfinder's Avatar
I went with the InoKinetic shifter and stock cables and feel shifting is good. Even after have car at track for 4 hours.
Past favorites
99 Esprit
02 Eurovan Weekender
62 Falcon 450hp under 2000lbs
(My first power to weight car)
Partsfinder is offline
post #9 of 9 (permalink) Old 07-26-2019, 06:13 PM
Caseman's Avatar
I installed the same with exactly the same results. Marked improvements however which for now, I am satisfied with.
Caseman is offline
