Installed sportINSERTS! - Page 2 - LotusTalk - The Lotus Cars Community
post #21 of 29 (permalink) Old 05-18-2015, 11:30 AM
TachItUp's Avatar
I just bought a rear insert kit, so thanks for the update. Did you have any issues getting the mount back into the bracket after pressing in the rear inserts?
TachItUp is offline
post #22 of 29 (permalink) Old 05-18-2015, 11:48 AM
V EQLS IR
afex's Avatar
I'm interested as well - I have yet to run into anyone that had the crazy squishing that I had from the earlier post on page 1:
http://i.imgur.com/oG3CJaj.png
I contacted Powerflex to see if they had any thoughts but they never got back to me, so i'm running just the front insert which is not exactly ideal
2006 Mag Blue/Biscuit Elise, Touring+Sport
2015 BMW X1
afex is offline
post #23 of 29 (permalink) Old 05-20-2015, 07:45 AM
driftwood's Avatar
nearly 4 years later my rear insert flairs out similar to yours Kris... kinda always has, but nothing severe enough to negatively effect the advantages (suppose i'm curious as to how the rear 'manly' inserts seat compared to the 'powerflex')
over that span I haven't really notice a difference in vibrations/cabin noise, but it certainly has crispened up the shifting (by obvious design)
'05 ST Elise: DHP exhaust, Quantum Zero's, Forge MS radiator, s111 v3 eliminator, s111 DSbrace, ce28n, ic7 dash...
driftwood is offline
post #24 of 29 (permalink) Old 05-25-2015, 03:11 PM
afm
afm's Avatar
Noticed both the vibration and the drastically improved shift accuracy after adding SportInserts.
(Both are positive qualities in my mind)
2007 Storm Ti Elise, Cup wheels, REV300
1992 Miata, gutted, Tillett seats
2007 Volvo V70R
afm is offline
post #25 of 29 (permalink) Old 06-07-2018, 01:59 PM
was looking at these, seems like a bargain for $50. How difficult is the install? can it be done DIY with a floor jack and hand tools?
Beemerb0y is offline
post #26 of 29 (permalink) Old 06-07-2018, 05:41 PM
Supporting Vendor
shinoo's Avatar
Yes, you can but it easier with a lift. I would say someone with average mechanical skills can do the job.
shinoo is offline
post #27 of 29 (permalink) Old 06-07-2018, 09:41 PM
Can you post instructions? Ty
post #28 of 29 (permalink) Old 12-30-2018, 06:36 PM
111rSil's Avatar
Hi all - quick question on this job...re the rear mount inserts.
Iím struggling to get the main 17mm bolt free, despite the nit on other side being removed. The mount itself is entirely off the subframe and itís loose as youíd expect. Have tried heat, penetrating fluid etc.
Anyone else have this problem & if so what was done to overcome?
111rSil is offline
post #29 of 29 (permalink) Old 01-27-2019, 05:29 PM
Hopefully you already figured this out but just in case... I just hammered the main bolt out (used a flat punch to drive it out of the hole). I did it with everything connected to the car. If you already have the whole thing out of the car, try putting it in a vice and just hammering it out. I just took mine off today for a clutch change, the bolts have been in there since about 2014. No problem getting them out, just tapped them with a hammer.
'06 Exige Chrome Orange | NA | Touring | Traction Control | Cup Air Box | FastWorks Torque 200 | PPE Headers | PPE Cat Delete | LBH Racing Raptor Exhaust | Engine Mount Inserts | Penske DA with 600/800 springs | BOE Toe-links | Shaved Steering Arms | Sector 111 Harness Bar | Schroth Harnesses | Shifter Reinforced | DBW Pedals | DIY Clutch Stop | Team Dynamics 1.2's | Sector 111 Ultradisks | BOE TOC Oil Pan | ProRad | Radium Coolant Expansion Tank
lotusninja is offline
