Popped out of third gear - LotusTalk - The Lotus Cars Community
post #1 of 10 (permalink) Old 08-07-2017, 09:04 PM Thread Starter
titaniumdave's Avatar
Had an odd experience with my '06 Elise, steady state driving in third gear, and the car popped out of gear. I put it back in gear and everything seemed fine. Tried a few hard accelerations and it only popped out once. Any suggestions for what's going on? I assume the issue is a worn synchro but it makes me wonder if there is a chance this is a shifter adjustment?
Any input would be helpful, thanks.
2006 Elise with BOE 400 supercharger and some aero mods, CRF floating oversized rotors, MCS single adjust coil overs, CRF exhaust, CRF sway bar w/adjustable link, mono-ball pivots, machined steer arms, baffled oil pan, CRF titanium toe link brace, hardened motor mounts, Ethos wheels w/Yoko slicks
titaniumdave is offline
post #2 of 10 (permalink) Old 08-08-2017, 01:30 PM
Sold my Exige S
+TSRAGR's Avatar
REV400 with stock gears? It probably is the synchro then, especially knowing how much abuse 3rd gear sees. Fastest way to find out is to drain the transmission fluid and check for metal bits with a magnet.
Others here have said to adjust the shift cables, look for excessive cable play, or simply top off the transmission fluid. Honestly though, I'd expect more than one gear to be giving you grief if it were any of those.
+TSRAGR is offline
post #3 of 10 (permalink) Old 08-08-2017, 01:51 PM
Addict
LostPawn's Avatar
I'm not sure popping out of gear would be a synchro, the synchro helps match gear speed with RPMs, as far as I know it does not help the gear actually stay engaged. I would first look at cables, slop in the shifter assembly, adjustments on the transmission linkage and play in the motor mounts. Could also be a warn 3rd gear as +TSRAGR says
Edit: With a little reading on the subject, it does seem worn synchros can lead to gears not staying engaged. I would expect it to also grind some when shifting but maybe not.
LostPawn is online now
post #4 of 10 (permalink) Old 08-08-2017, 02:04 PM
XHILR8N!'s Avatar
Yep. Third takes a real beating and the brave little stock trans gives up there first. I have one in the basement.
2005 Elise LRG, Trim Shop interior, full cage, Cup wheels, BWR 'charger lives!
2016 370Z Nismo
2013 Bentley Continental GT Speed
XHILR8N! is offline
post #5 of 10 (permalink) Old 08-08-2017, 05:46 PM
Elise Guru
fzust's Avatar
It is likely the 3rd gear dog ring and the selector ring. The synchro gets worn, it doesn't effectively match the speed and then the wear happens on the teeth in the dog ring and the selector ring. If anyone ever has trouble with grinding gears or reluctance to go in gear, address it quickly. the synchro is quite cheap.....
Winning Suspension
6UL wheels
fzust is offline
post #6 of 10 (permalink) Old 08-09-2017, 09:40 AM Thread Starter
Thanks for the input. I have only 200 miles on the car with the BOE400, nothing on the track so I'm not sure if that is the cause of the problem. That being said, I have beat the car pretty hard with a Katana before the BOE400 so it could have been more than a little compromised. I have a trans build with an OS Giken LSD and Blackwatch 3/4 gears going to happen, I was hoping to get through 1 or 2 track days before I HAVE to do the rebuild. Fred, your assessment matches my experience, it feels like the dogs are not 100% engaged so they can just pop out of gear, seems worse with less load. I will try and adjust the shift cable to see if it's sloppy to get through at least my track day next week.
post #7 of 10 (permalink) Old 08-14-2017, 03:17 PM Thread Starter
I was able to tighten the shift cable about 2 mm, all I could get out of the inside rod-end, I was too lazy to drop the under tray. The good news is it seems to have corrected the problem for the time being, I'm on the track on Friday so I will see if the adjustment holds or I'm dropping the trans soon.
post #8 of 10 (permalink) Old 09-19-2017, 10:01 AM Thread Starter
Life has been busy since the last post. Follow up to say the transmission worked fine for the first 2 sessions of the day, solid smooth shifts, never popped out of gear. Toward the end of the 3rd session it did the pop out of gear thing once or twice then 3rd gear was just gone. I can shift into gear and nothing hooks up...I blew up something but good.
I'm doing a C60 rebuild right now, new bearings, syncros and BWR 3/4th gears as well as OS Giken 1-way LSD with the plan to be back on the track on Sunday to shake things down. Fingers crossed...
After much searching I found and online manual for the C60 transmission:
Index of /car/Toyota/celica/repair information/repair manual/16 - Manual Transaxle (C60)
Seems like this is a good resource and others might find it helpful.
post #9 of 10 (permalink) Old 09-19-2017, 10:39 AM
Sold my Exige S
+TSRAGR's Avatar
Thanks for the update. At least you got every bit out of that transmission.
Let us know what you find when you get it apart.
+TSRAGR is offline
post #10 of 10 (permalink) Old 09-19-2017, 01:13 PM
eldonz's Avatar
You really should look at BWR's gear set for the C60. It will make your motor perform even better because of better RPM matching. It will also take the abuse that you are going to be causing with the extra HP.
Take care,
Eldon
eldonz is online now
