Project Car: Exige + Honda K24A2 + MPx90 Supercharger - Page 2 - LotusTalk - The Lotus Cars Community
 9Likes
post #21 of 355 (permalink) Old 12-30-2013, 08:21 PM
aztec1382's Avatar
At least it's solved
slwkart
aztec1382 is offline
post #22 of 355 (permalink) Old 12-30-2013, 08:40 PM
Exiged's Avatar
Glad you are making some good progress! I get a lot of messages on my swap and my best advice is to make sure you have someone who knows these cars very well and quite possibly has done them before (like me). Keep it going you will get her done!
Sent from AutoGuide.com App
DIY 2007 Exige S K20A2 C38 Rotrex
Www.onetonracing.com
Exiged is offline
post #23 of 355 (permalink) Old 12-30-2013, 10:24 PM Thread Starter
Butters's Avatar
Exiged, do you remember if your axles came with castellated nuts? Or if they had that pressed on dust seal?
2007 SUZUKI SV650 Track bike.
Butters is offline
post #24 of 355 (permalink) Old 12-31-2013, 05:44 AM
streetthrowback's Avatar
I ordered my axles last week. Waiting on them to show up on my door
06 OCM elise r.i.p.
streetthrowback is offline
post #25 of 355 (permalink) Old 12-31-2013, 06:56 AM
Exiged's Avatar
I had sent all my axle parts to innovative to have them built. They came back ready to go. You should be reusing your original axle nut
Exiged is offline
post #26 of 355 (permalink) Old 12-31-2013, 08:04 AM
I sold my axles so I was a nice seller and gave them to the buyer. If you order a set of axles they should come with the axle nut and washer. I have never ordered axles and haven't received it without them if I was you I would contact them and ask them for them because they should have came with them.
06 OCM elise r.i.p.
post #27 of 355 (permalink) Old 12-31-2013, 08:37 AM
Apex_in_sno's Avatar
Well we think it's solved based on the pictures of the various parts from Innovatives site, won't know for sure until the bits show up.
Regarding the axels, the CV joints on the set we have are designed to be used with the single use nuts, so aren't cross drilled for the castellated nut and cotter pin like OEM.
VFII, Eliseparts Sequential, Geartronics Paddle shift.
You name it, I've probably got that installed too...
1864lbs, full tank
Otherwise, it's bone stock....
Apex_in_sno is offline
post #28 of 355 (permalink) Old 12-31-2013, 09:35 AM Thread Starter
Butters's Avatar
I didn't send mine in to be built. I received all new axles from Tim. And like Apex said, they weren't drilled for the cotter pin but for the one time use only nut where you hammer in the flanges. You can see a picture of it on the first page of this thread.
The original axle nuts went with the original axles I sold.
Butters is offline
post #29 of 355 (permalink) Old 12-31-2013, 11:31 AM
MotoGeek's Avatar
Glad to see this project is going through.
Can you pm me (or post) the shop, so I know to steer clear?
MotoGeek is offline
post #30 of 355 (permalink) Old 12-31-2013, 12:25 PM Thread Starter
Butters's Avatar
MotoGeek, just PM'd you.
Butters is offline
post #31 of 355 (permalink) Old 12-31-2013, 02:15 PM Thread Starter
Butters's Avatar
So the plot thickens. After speaking with Tim at Innovative Mounts and sending him a bunch of photos of the mount, it seems that we indeed have the CORRECT mount. We were comparing what we had to the pictures on the Innovative site. Turns out the ones on the site are outdated.
Which makes the mystery even deeper. Does that mean that there are multiple kswapped Lotuses out there running around with slightly off-kilter engines? Is my subframe somehow tweaked? I have no idea.
Either way, more exacting measurements will have to be taken and sent to Tim for investigation.
As far as the axles go, we'll probably just have to buy a few extra thick washers and stack them to make up the extra 8-9mm for the nut to sit in the proper place.
Butters is offline
post #32 of 355 (permalink) Old 12-31-2013, 06:20 PM
Hey butters just buy the axle nut and washer at the dealer
06 OCM elise r.i.p.
post #33 of 355 (permalink) Old 12-31-2013, 09:25 PM Thread Starter
Butters's Avatar
Yeah, we are going to source the washer separately. The OEM washer is only 3-4mm. And we have 8-9mm of thread to make up before the nut sits correctly.
Butters is offline
post #34 of 355 (permalink) Old 01-01-2014, 04:10 AM
Gamera The Atomic Turtle
komiko's Avatar
damn butters. That's gonna be one sick ride. Thanks for the post.
Lotus Elise #134 - S O L D BOE REV400 street car built at BOE in KC. , Stock motor, low boost w/stock cat/mani, 292whp, (5.95 lbs/hp) passes all 50 states emissions/OBD, BOE ST exhaust, ACT HDSS, BOE Clam Hinge, BOE Oil Cooler Relocation, BOE Surge Tank/750cc injectors, BOE Race Links, MWR Rear Lift Kit etc. 0-100 = you bet!
Build thread :
https://www.lotustalk.com/forums/f160...seline-114302/
komiko is offline
post #35 of 355 (permalink) Old 01-01-2014, 01:11 PM
Ummm...., castellated nut on a non cross drilled shaft, no workie so goodie...
1864lbs, full tank
post #36 of 355 (permalink) Old 01-01-2014, 01:13 PM Thread Starter
Butters's Avatar
^+1.
If you check the picture I posted earlier you'll see that the axle is not cross drilled for use with a castellated nut.
Butters is offline
post #37 of 355 (permalink) Old 01-01-2014, 01:24 PM
Current motor alignment measurements I just took...
Distances were measured from the exhaust manifold face on the head, just above the studs to the rear of the rear chassis cross member. It was observed that a line between these points was approximately perpendicular to the header mounting surface on the head (per the attached)
The block's left to right attitude is parallel with the chassis to within 0.1 degree, although this did require raising the drivers mount .25"
The difference between the two measurements was .125" over a distance (between studs) of 8".
The left and right mounts are about 40" apart, simple math tells us, that leaving the left mount in place, that the motors right side would have to move rearward approximately 5/8" to become parallel with the rear cross member.
0.125 / 8 = x / 40
8x = 5, x = 5/8...
Moving the motor that amount should help considerably with the passenger side's current shaft angle of 8-9 degrees, which is almost twice the drivers side.
1864lbs, full tank
post #38 of 355 (permalink) Old 01-01-2014, 01:45 PM
aztec1382's Avatar
Wow
slwkart
post #39 of 355 (permalink) Old 01-01-2014, 03:21 PM
6i9
6i9's Avatar
I did not take measurements like apex_in_sno did, but I believe my passenger side is slightly skewed forward as well, relative to the driver side. I have not taken any pictures of the CV joint angles, but I'll try to do that the next time I am under the car. However, I have noticed no ill effects on driveability or reliability.
I had Tim's original mount kit for the passenger side which did not line up at all with the bracket provided. Tim insisted that this fit all the other cars he's sold the kit to and that my car's subframe must be off or had been in an accident (not that I am aware).
Because of this, the car was taken to Innovative Mount's facility where Tim fabbed an extended bracket to meet the passenger motor mount, which is the same bracket that I see on your car now (maybe Tim has changed the provided bracket now to this design on all his kits?)
2005 Magnetic Blue Lotus Exige
Drivetrain: Honda K20A Type R | Innovative Kit | Arqray Ti | SCM Intake/Header | Hondata | proRAD | Setrab | KTuned | V2 Fuel Tank | BOE Swirl
Aero: Exige Clams | Reverie | TWRD GT | Craftsquare | IMRP | BSK | Voltex
Suspension: Penske SA | V2arms | RTDbrace | CE28N | R888 | BOE Floating | Pagid RS14
Interior: Recaro SPG | Willans | WorksBell | Sparco
6i9 is offline
post #40 of 355 (permalink) Old 01-01-2014, 06:00 PM Thread Starter
Butters's Avatar
Ah, interesting bit of history there. Yeah, it looks like the Lotus swap kit is including those now. Thanks for posting those, 6i9. If you could take a look at your axle angles that would be awesome.
Butters is offline
