Project Car: Exige + Honda K24A2 + MPx90 Supercharger - Page 3 - LotusTalk - The Lotus Cars Community
 9Likes
post #41 of 355 (permalink) Old 01-03-2014, 05:19 AM
countryboyshane's Avatar
Subscribed
countryboyshane is offline
post #42 of 355 (permalink) Old 01-06-2014, 09:29 AM Thread Starter
Butters's Avatar
Update. Looks like we've sorted the engine mount issue. Full steam ahead. Should be into the cabin next weekend for wiring madness.
One thing that is outstanding... the exhaust system from HyTech only came with one bung for O2 sensors. Need another one for wideband so we're looking for a good welder in town to help us weld a stainless bung onto the system. But they need to be good. The welds on this system are some of the best I've ever seen and don't want an amateur muddying it up. If anyone has any recommendations please let me know!
2007 SUZUKI SV650 Track bike.
Butters is offline
post #43 of 355 (permalink) Old 01-06-2014, 10:32 AM Thread Starter
Butters's Avatar
Firewall Insulation. Real quick. Here is the firewall insulation going in. Once the motor was settled, there was actually enough room for it. Crazy.
Butters is offline
post #44 of 355 (permalink) Old 01-06-2014, 10:06 PM
aztec1382's Avatar
What fixed the engine mount issue
slwkart
aztec1382 is offline
post #45 of 355 (permalink) Old 01-06-2014, 10:40 PM
Why do you need a o2 sensor? There is no cat? No emissions? Just run the wideband into the ecu and tune?
Formula313 is offline
post #46 of 355 (permalink) Old 01-07-2014, 01:57 AM
forgive me if im being somewhat mean, but a wideband is an O2 sensor my friend
nuk1ear is offline
post #47 of 355 (permalink) Old 01-07-2014, 04:56 AM
Apex_in_sno's Avatar
There was enough "slop" in the mounts to remove about half the distance it was off.
VFII, Eliseparts Sequential, Geartronics Paddle shift.
You name it, I've probably got that installed too...
1864lbs, full tank
Otherwise, it's bone stock....
Apex_in_sno is offline
post #48 of 355 (permalink) Old 01-07-2014, 04:58 AM
The ECU uses a narrow band, the wide band runs the AFR gauge.
1864lbs, full tank
post #49 of 355 (permalink) Old 01-07-2014, 06:42 AM Thread Starter
Butters's Avatar
+1. Need a bung for narrowband (ECU) and another for wideband (AFR gauge).
Butters is offline
post #50 of 355 (permalink) Old 01-07-2014, 06:58 AM
Yeah. I got that, referring the term o2 sensor in the context of a narrowband.
I was unsure why butters wanted narrowband into the ecu based on it reads very limited information (only +/- 14.7) vs running the wideband into the ecu and the gauge as I did on my last turbo exige? It seems to give the tuner better capabilitys, but maybe it has something to do with the hondata ecu being a stock style ecu?
post #51 of 355 (permalink) Old 01-07-2014, 07:03 AM
aztec1382's Avatar
Learning a lot
slwkart
post #52 of 355 (permalink) Old 01-07-2014, 09:31 AM
streetthrowback's Avatar
So we still need to run the up stream of sensor correct?
06 OCM elise r.i.p.
streetthrowback is offline
post #53 of 355 (permalink) Old 01-07-2014, 10:56 AM
Yea, the hondata hack (er ECU) does allow usage of a wide band, however it requires several mods to the harness that we've got, custom sensor calibration ect, and I'm reluctant to add yet another variable to the mix at this point.
1864lbs, full tank
post #54 of 355 (permalink) Old 01-11-2014, 08:33 AM
Where's the updates?
post #55 of 355 (permalink) Old 01-11-2014, 06:56 PM
Inactive
dstevens's Avatar
To correct both of you: The stock ECU uses a wideband, plus you can input an aftermarket wideband for tuning if you desire.
2005 Elise with Honda engine
Please don't PM me - this forum is no longer usable and I do not monitor it.
It was fun while it lasted.
dstevens is offline
post #56 of 355 (permalink) Old 01-11-2014, 08:40 PM
Exiged's Avatar
Derek how is your car doing these days?
Sent from AutoGuide.com App
DIY 2007 Exige S K20A2 C38 Rotrex
Www.onetonracing.com
Exiged is offline
post #57 of 355 (permalink) Old 01-11-2014, 08:45 PM Thread Starter
Butters's Avatar
We got the engine bay all buttoned up today! Started in on routing harnesses and wiring up the dash. Ran into some road blocks.
Namely that we cannot upload to the ECU! The software recognizes the ecu is connected, sees that the ignition is on. But when we go to upload a base map, it tells us the upload failed. The relays cycle and everything, but the upload fails. The ecu also blinks red.
Will upload more photos tomorrow.
Butters is offline
post #58 of 355 (permalink) Old 01-11-2014, 08:53 PM
Exiged's Avatar
This has happened to me quite a bit with my kpro as well. Doesn't matter what computer I use it just gets picky sometimes and I have to try again. Try clearing security on it. If it fails that then you are having the same problem that I have from time to time. Maybe Derek can help?
Exiged is offline
post #59 of 355 (permalink) Old 01-12-2014, 01:44 PM
Inactive
dstevens's Avatar
I removed the K24 & supercharger and now have a built 89x90.7 engine ready for the TVS supercharger. Car is slow without any forced induction (only 100 hp over stock).
dstevens is offline
post #60 of 355 (permalink) Old 01-12-2014, 07:37 PM
Exiged's Avatar
Post up some pics when you are done I would love to see it. The original work you did was unreal!
Exiged is offline
