Project Car: Exige + Honda K24A2 + MPx90 Supercharger - Page 6 - LotusTalk - The Lotus Cars Community
 9Likes
post #101 of 355 (permalink) Old 04-02-2014, 05:42 PM
Plug Whisperer
turbophil's Avatar
This is painful!!!
"Pain Makes Man Think
Thinking Makes Man Wise
Wisdom Makes Life Endurable"
turbophil is offline
post #102 of 355 (permalink) Old 04-02-2014, 06:59 PM
Apex_in_sno's Avatar
Painful, yes but almost done. But we've been saying that for a good month now...
I guess we should feel lucky that the KPro is a MAP system, at least the recent tune isn't a complete waste.
I've never seen a system leak this bad, jesus still idles with the TB completely blocked off... WTF
Butters, you need to post the pictures that we took of the blower intermediate plate.
We've gotta keep the amusement factor going.
VFII, Eliseparts Sequential, Geartronics Paddle shift.
You name it, I've probably got that installed too...
1864lbs, full tank
Otherwise, it's bone stock....
Apex_in_sno is offline
post #103 of 355 (permalink) Old 04-02-2014, 07:27 PM
The Enforcer
oldmansan's Avatar
Sorry to hear you're still having issues. Best of luck.
San
oldmansan is offline
post #104 of 355 (permalink) Old 04-02-2014, 08:44 PM Thread Starter
Butters's Avatar
Here is what was found.
2007 SUZUKI SV650 Track bike.
Butters is offline
post #105 of 355 (permalink) Old 04-03-2014, 03:24 AM
streetthrowback's Avatar
This is why I do the work myself, no one will take care of your stuff more then you. if you can I would sue them.
06 OCM elise r.i.p.
streetthrowback is offline
post #106 of 355 (permalink) Old 04-03-2014, 03:32 AM
thats horrible new man, and that some horrible work i see too. Keep your head high, when that thing in finally finished it will put a smile on your face and bring back some life to you. Hard work and dedication
nuk1ear is offline
post #107 of 355 (permalink) Old 04-03-2014, 08:21 AM
re: Honda conversions
I have built a few race cars, so the engine 'conversion' task is not new to me.
The biggest lesson is to find people that worked with your engine and technology before. I use Corvette spline and bearing hubs on my Honda axles, because, I know these parts.
1. I bought an assembled motor from a reputable shop. I bought it from a customer that never used it. However, I talked to the shop, got the build sheet and got references.
2. I found reputable sources of aftermarket parts. This came from Honda forums k20a.org.
3. I found a local tuner and watched him tune a similar set-up, before I let him touch mine.
I cannot over-emphasize (1). I had to replace cams and thought that I should be able to handle the timing. Bent 2 valves!
Whenever, you undertake such complex projects some problems are to be expected.
I had a bad MAP sensor. It was brand new. The car would almost start i.e. catch, then moment ECU went into its standard mode, it would say MAP=0 so fuel =0 and stop. Took me a day to figure it out. I cannot build a motor, but I am good at diagnostics.
Anton
This is painful!!!
ageshelin is offline
post #108 of 355 (permalink) Old 04-03-2014, 10:16 AM Thread Starter
Butters's Avatar
If there is a lesson I'm taking away from all this is that you should indeed do as much of the work yourself if you can.
If I had a bunch of money laying around that I could burn on lawyer fees I'd think about suing those bastards. But as it stands, I don't. However, good news is some other, richer, guy is doing that already. I don't suspect they'll be in business that much longer...
Butters is offline
post #109 of 355 (permalink) Old 04-03-2014, 12:59 PM
Vulcan Grey's Avatar
Butters,
Did you replace the oil cooler after you found that bead blasting material had ruined the previous engine?
Any time you get metal or other debris in the oil system, you should really replace the oil coolers!
BTW, same thing happened to a few Esprit V8's recently after the engine re-builder re-painted the cam covers!
Travis
Vulcan Grey Esprit 89 SE
Vulcan Grey is offline
post #110 of 355 (permalink) Old 04-03-2014, 01:02 PM Thread Starter
Butters's Avatar
I dumped the oil out of the oil cooler and filtered it --- it was clean, no sand. The engine didn't get hot enough for the oil stat to open up in the first place...
Butters is offline
post #111 of 355 (permalink) Old 04-03-2014, 01:10 PM
6i9
6i9's Avatar
Wow. I guess I really should be grateful for how my swap turned out, despite my own bumps.
Good luck and don't get discouraged!
2005 Magnetic Blue Lotus Exige
Drivetrain: Honda K20A Type R | Innovative Kit | Arqray Ti | SCM Intake/Header | Hondata | proRAD | Setrab | KTuned | V2 Fuel Tank | BOE Swirl
Aero: Exige Clams | Reverie | TWRD GT | Craftsquare | IMRP | BSK | Voltex
Suspension: Penske SA | V2arms | RTDbrace | CE28N | R888 | BOE Floating | Pagid RS14
Interior: Recaro SPG | Willans | WorksBell | Sparco
6i9 is offline
post #112 of 355 (permalink) Old 04-03-2014, 03:25 PM
I'll throw down some money if you want to hire a lawyer. Imagine if 50 people threw down $100 each. Looks to be a pretty open and shut case.
Nessal is offline
post #113 of 355 (permalink) Old 04-03-2014, 03:28 PM Thread Starter
Butters's Avatar
Hahaha! That would be awesome. **sigh**
Butters is offline
post #114 of 355 (permalink) Old 04-04-2014, 05:06 AM
You would have to get in line for this place, there's already one open and shut case going on, in the end you could win, but your prize would be en empty paper bag...
1864lbs, full tank
post #115 of 355 (permalink) Old 04-05-2014, 10:28 AM
Callsign_Vega's Avatar
Oh wow crazy thread. To spend what, $40K+ total and have all these problems.
That's why I never take my cars to any shops and do all work myself. 99% of shops will half ass everything and cut corners like you wouldn't believe. Or basically not even know what they are doing.
Really the only way to get high end sports cars. Pay big $$ for one from the factory, or build/modify one yourself which costs <time>.
2009 S260 Sport Exige - Storm Titanium / Carbon Fiber
Callsign_Vega is offline
post #116 of 355 (permalink) Old 04-07-2014, 03:08 PM
bbs350z's Avatar
How do you guys have your throttle cable arranged? Ive got alot of play in mine but not sure if its hooked up properly
Built LS1 Turbo 350Z ** Built Viper SRT-10 ACR'd out ** SL500 low n slow daily
[email protected]
bbs350z is offline
post #117 of 355 (permalink) Old 04-08-2014, 05:02 AM
I made a custom bracket for the TB side and added another return spring at the pedal (pic is in this thread someplace)
The cable routes from the pedal through the tunnel (following the e brake cable) into the engine bay, then up to the custom bracket.
If there's slop, you have adjusters on both ends to deal with.
Not really sure how one could hook it up improperly...
1864lbs, full tank
post #118 of 355 (permalink) Old 04-08-2014, 09:22 PM
bbs350z's Avatar
Is yours an 05? Im using the factory throttle cable and this bracket. I believe theres only 1 way to mount it on the tb, but it snags when it opens and closes
[email protected]
bbs350z is offline
post #119 of 355 (permalink) Old 04-08-2014, 09:59 PM Thread Starter
Butters's Avatar
It's an 06. The throttle cable I used is a piece that Exiged had custom made. Its stronger than the Innovative Mounts cable.
Butters is offline
post #120 of 355 (permalink) Old 04-09-2014, 04:52 AM
It's hanging on the TB side or the pedal side (or possibly in the middle), disconnect one end at a time to test. with both ends disconnected you should be able to easy move the cable back and forth within the sheath.
If the cable's fine then look for binding at the pedal and tb.
1864lbs, full tank
