Shifting ? - LotusTalk - The Lotus Cars Community
post #1 of 8 (permalink) Old 07-30-2017, 07:07 PM Thread Starter
Shifting ?
So I've always loved the Elise / Exige and am finally in a position to possibly add one to my garage.
My question is I drove one yesterday that was very well cared for and seems to be an excellent example. I have seen several posts regarding the shifter being sloppy. So what I experienced was 1-2, 3-4 were fine. the 2-3 shift was very vague and definitely took some finesse. Is that the basic issue others have?
If so, I've seen the Alitech shifter which seems awesome, but a bit pricey. are there any other more reasonably priced options that will improve the shifting? It was just such a shame that the shifter on such an awesome car is the worst I think i've ever shifted.
Thanks. Hoping to join your ranks soon!
blown9746 is offline
post #2 of 8 (permalink) Old 07-30-2017, 07:30 PM
Nein Kinder
Glen's Avatar
@blown9746 - Alitech and InoKinetic both make replacement shifters. In addition to those, the following items may improve a specific Elise or Exige's shifting performance:
- different transmission lube
- stiffer transmission mounts
- replacement cables
- replacement external shift levers on transmission case
- replacement shift ball
There are lots of posts on LotusTalk on this subject, many of them going back a decade or more. I have made every mod I know about to my shifter on my 2011 Elise SC and it now shifts reliably . . . the only OEM part left in the shifter system is the transmission.
So in answer to your question, driver experiences are all over the map, from awesome OEM shifter to vague piece of garbage that is constantly missing shifts. The shifter feel can be improved, but it may cost from hundreds to several thousand dollars to get there.
Glen
2011 Lotus Elise SC
Glen is offline
post #3 of 8 (permalink) Old 07-30-2017, 09:45 PM
glb
glb's Avatar
See #5. My car shifts wonderfully.
Stock: “Excuse me”
Stebel: “HONK! LOOK OUT!”
3. The early cars came with misaimed and dim headlights. If you drive at night, convert to HIDs. While better than stock halogen bulbs are available, HIDs throw more light. Stay around 5000k.
5. The best transmission lube I’ve found is Redline MT-90 plus a little Power Punch Extreme Gear Oil Additive. (Note that it takes two changes to get rid of the previous lube.)
https://www.inokinetic.com/lotus/re-...y=Transmission
7. Rear toe-links can loosen and break with disastrous results. You can check tq periodically, or use Nordlock washers. Best is conversion to better engineered brace, such as BOE’s for one example.
https://www.lotustalk.com/forums/f311...-u-tube-47232/
11. Visit the Uber Thread
https://www.lotustalk.com/forums/f3/e...ow-here-25131/
10. Most parts on the car are made by Toyota and others, so buying things like a/c compressors, engine parts, etc. are wildly expense when purchased thru Lotus.
Plus:
https://www.lotustalk.com/forums/f101...brakes-241138/
How to Search:
Driving Tips-https://www.lotustalk.com/forums/f100...art-1-a-49665/
Moss Emergency Line-https://www.lotustalk.com/forums/f100...cy-line-36631/
Safely Piercing Wires-https://www.lotustalk.com/forums/f129...esting-106438/
Bleeding Brakes- https://www.lotustalk.com/forums/f101...-brakes-241138
glb is offline
post #4 of 8 (permalink) Old 07-31-2017, 05:20 AM
My 07 Exige shifts fine except for 5-6. I have solved this by always making that shift thumb down[suggested in a posting here]. My shifter is factory except for the extra bolt and washer mod made by the PO.
Other than feeling like every other cable shifter it is as normal as any car I have driven
I feel like the 5-6 problem could be solved by a weaker crossgate spring, but have not been brave enough to play with that yet.
exigegus is offline
post #5 of 8 (permalink) Old 07-31-2017, 05:29 AM
Nein Kinder
Glen's Avatar
Quite right - I should have said improvements start at around $1.
Glen
2011 Lotus Elise SC
Glen is offline
post #6 of 8 (permalink) Old 07-31-2017, 07:56 AM
glb
glb's Avatar
Forgot to add that when the "console" cover was removed, one of the swivel joints (?) was at a bad angle. Noting where it was, I moved it to a better position.
I also lubed the moving parts.
Good result.
glb is offline
post #7 of 8 (permalink) Old 07-31-2017, 10:23 AM
Glen
Even cheaper, I think the most noticeable change was a little spray grease on the transmission end linkage
exigegus is offline
post #8 of 8 (permalink) Old 12-29-2017, 02:55 PM
All good information. I just purchased an 08 that has the Letsla kit in it. I'm not used to cable shifted cars, but the shifts are vague and imprecise. I'm going to try to narrow it down or improve a little at a time, but this thread saved from starting my own, thanks.
Troublemaker is offline
