'07 Lotus Exige Front Clam Fitment on '05 Elise - Interference?! - LotusTalk - The Lotus Cars Community
 1Likes
  • 1 Post By exigegus
  • 1 Post By countryboyshane
  • 1 Post By khamai
post #1 of 6 (permalink) Old 08-27-2019, 02:07 AM Thread Starter
countryboyshane's Avatar
I had to buy a new front clam for my 2005 Lotus Elise due to a racing incident. Because of the better aero characteristics, and class legality, I chose to get a new 2007 Exige front clam.
To my surprise, and against everything I've heard on Lotus Talk, the clam doesn't fit perfectly over the radiator surround. All of the factoring fastening points are lining up perfectly. As you can see in the picture, about 5/8" of the surround is still poking through the radiator opening.
For those that have done this swap, is this normal?
I did find this picture on How Tune of the radiator surround of a 2007 Lotus Exige (link below), and the surround looks just a little bit different.
https://howtune.com/articles/437-rem...-a-lotus-exige
This car is so far removed from stock I don't care how I need to make this work.
Safe to say, break out the dremel and start carefully cutting?
What are everyone's thoughts that have ran into a similar situation with this exact same front clamshell swap?
2005 Lotus Elise, naturally aspirated and always at redline!
2018 NASA Great Lakes Region TT4 Champion
countryboyshane is offline
post #2 of 6 (permalink) Old 08-27-2019, 09:56 AM
He's on fire!
jds62f's Avatar
Does the elise radiator shroud support/affix the plastic vent things?
On th exige the mesh is glued to the clam.
jds62f is offline
post #3 of 6 (permalink) Old 08-27-2019, 10:12 AM
los
unfortunately, Exige and Elise have different cutouts for the radiator leading to different radiator housing AND different radiator shrouds (elise has 2 shrouds, exige has 1 shroud)
los is offline
post #4 of 6 (permalink) Old 08-27-2019, 10:19 AM
Crazy05's Avatar
Here is a pic of my 05 clam off recently. I pointed out a few things that may be causing the issue. Although I'm not 100%
*** Looking at the pics again I can clearly see that the Elise shroud is LONGER than the Exige!
Currently:
2005 Lotus Elise
2015 Audi A3 Wife's car
2012 Toyota Prius C Daily Commuter
Sold:
2006 Pontiac Solstice
2003 350z Touring
2006 Eclipse GT
Crazy05 is offline
post #5 of 6 (permalink) Old 08-27-2019, 10:24 AM
Crazy05's Avatar
Look at the length, also how much radiator is covered.
Currently:
2005 Lotus Elise
Sold:
2003 350z Touring
2006 Eclipse GT
Crazy05 is offline
post #6 of 6 (permalink) Old 08-27-2019, 10:31 AM
Is it possible they are the same molding with different trims?
So basically it is get out the sawszall and get to work?
Crazy05 likes this.
exigegus is offline
post #7 of 6 (permalink) Old 08-27-2019, 10:41 AM Thread Starter
Wow, guys thanks for the reply. It's very clear now that the shrouds are completely different. On the Elise, the clam slips past the "ledge" and is positioned over it. On the Exige, that methodology wasn't used.
Jigsaw with a Permagrit edge is going to be getting a workout. I wish I knew about this beforehand!
Crazy05 likes this.
post #8 of 6 (permalink) Old 08-27-2019, 11:04 AM
cyow5's Avatar
Yup, I need to do the same but have some interruptions and not gotten around to it yet.
The plus side is that (theoretically at least) the trimmed shroud should have less drag and lift. More noticeably, it'll make removing the clam a billion times easier, haha.
cyow5 is offline
post #9 of 6 (permalink) Old 08-27-2019, 12:01 PM
khamai's Avatar
The Elise clam is molded glass composite and the Exige clam is hand laid thus thicker and heavier. The shroud differences are in line with making space for a thicker clam.
Kiyoshi
countryboyshane likes this.
Lotus events in California - www.gglotus.org
khamai is offline
