2005 Elise Remote Lock - LotusTalk - The Lotus Cars Community
post #1 of 11 (permalink) Old 08-23-2019, 08:52 AM Thread Starter
MBchrono's Avatar
Howdy,
I bought my Elise without a remote lock. I've been manually locking/unlocking the doors. I would like to get this working again, as it's a slight hassle when I have passengers.
I am not too familiar with the Elise regarding the immobilizer. I found the fob with electronics that just need to be programmed https://www.monkeywrenchracing.com/product/lotus-oem-key-fob-remote-elise-exige-2005-12/. I was curious if can just buy this and program it, or if I need to check for something else beforehand? I don't want to spend 100 bucks unless I am sure this could be a viable solution.
Thanks!
Matt
2005 Lotus Elise
Salt Lake City, UT
MBchrono is offline
post #2 of 11 (permalink) Old 08-23-2019, 09:24 AM
NoRawkus305's Avatar
I would first suggest to check if the alarm/immobilizer is still actually hooked up in the car. Plenty of owners either bypassed it or totally removed everything.
If I recall, itís located behind the rear panel on the driver side seat. Unless you can get hold of a cobra fob to test it and see if your able to sync to it, than you may need to physically check if itís there. And if itís there but bypassed, than you may need to read up on some posts about how it was bypassed. Quick google search should pull that up. Possibly other members may know a different way to inspect. Good luck.
2002 Honda S2000 - RIP MAY 2012
2005 Lotus Elise Sport and Touring Package - Weekend Warrior
2015 NX200T F-Sport - DD and Winter Beater
2006 Hummer H3 - The wife's
NoRawkus305 is offline
post #3 of 11 (permalink) Old 08-23-2019, 09:48 AM
PeteB37's Avatar
You'll need the PIN code for your car to program the remote, but if you can start the car without a remote, then your immobilizer is obviously disabled.
PeteB37 is offline
post #4 of 11 (permalink) Old 08-23-2019, 12:55 PM
EddieA's Avatar
Originally Posted by NoRawkus305 View Post
If I recall, it’s located behind the rear panel on the driver side seat.
That's just the immobiliser circuit isn't it. The main "brain" is inside the dash, IIRC.
Or the alarm has been reprogrammed not to automatically set the immobiliser, but only when the alarm is armed. Knowing how the tell-tale light in the tach is flashing or not can determine this.
Cheers.
2007 Exige S. Phantom Black/Black. KoldFire 270 SC.
1993 3000GT VR4. Green, not quite BRG, but close.
1988 Fiero GT. Red. RIP.
EddieA is offline
post #5 of 11 (permalink) Old 08-26-2019, 08:38 AM
Le0nz's Avatar
If immobilizer is taken out, is it still possible to use the fob to lock and unlock?
Le0nz is offline
post #6 of 11 (permalink) Old 08-28-2019, 03:21 PM Thread Starter
MBchrono's Avatar
Cheers.
I rolled the dice and grabbed the FOB, which was just delivered. Seemed pretty straightforward to program it. I get the light on the FOB, but turning the key 3 times doesn't give me the tach light at all. I wonder if this means I can't program a keyless entry at all. Still researching.
2005 Lotus Elise
Salt Lake City, UT
MBchrono is offline
post #7 of 11 (permalink) Old 08-28-2019, 04:14 PM
Less is Better
me73's Avatar
Have you looked in the access panel on the right side of the dash to see it the alarm is still hooked up?
me73 is offline
post #8 of 11 (permalink) Old 08-29-2019, 06:14 AM
Le0nz's Avatar
Just curious - since you and I are in the same place.... do you use the key to lock/unlock the doors or the power door switch?
Le0nz is offline
post #9 of 11 (permalink) Old 08-29-2019, 06:22 AM Thread Starter
MBchrono's Avatar
I have always used the key. I've hit the door lock button a few times, but have never used it to lock/unlock the door.
2005 Lotus Elise
Salt Lake City, UT
MBchrono is offline
post #10 of 11 (permalink) Old 08-29-2019, 06:29 AM
Krazykevin's Avatar
It sounds like your alarm system may be disabled. Like others have said, you should check the panel on the passenger side dash.
2005 Storm Titanium Elise
Krazykevin is offline
post #11 of 11 (permalink) Old 09-10-2019, 09:51 AM
Le0nz's Avatar
Have you checked if your alarm module is disconnected in the passenger side cubby? I haven't checked mine, just curious though... Although I have more of a piece of mind with also just going old-school with a key only
Le0nz is offline
