2011+ Series 3 Lotus Elise Input Needed! - Page 2 - LotusTalk - The Lotus Cars Community
 6Likes
post #21 of 28 (permalink) Old 03-24-2017, 07:49 AM Thread Starter
RGB
RGB's Avatar
Great news for Series 3 owners and especially for ones in California! Found this: Lotus of West Covina
Awesome place sells OEM parts by factory number and catalogs. And best of all, the info is so good that we can cross reference parts on every models!!
Sam
RGB is offline
post #22 of 28 (permalink) Old 10-10-2017, 07:20 AM Thread Starter
RGB
RGB's Avatar
**********coolant u-tube update**********
I have double checked the coolant u-tube location, and after cross referencing with multiple sources, the 2011 and up Lotus Elise has gotten rid of the u-tube and no longer has rubbing the issue. See the attached pic.
Sam
DamianLynch and amoe like this.
RGB is offline
post #23 of 28 (permalink) Old 10-10-2017, 11:21 AM
centerpunch's Avatar
Originally Posted by O LEE O View Post
I have been thinking of creating a thread just for the 2011 group to be able to share our experiences in one place instead of searching a myriad of threads.
Lee
Good idea. Maybe this is that thread.
Subscribed!
(Just picked up my new 2011 R yesterday from Motorcars of Georgia, driving it back to OH via an extra day in NC.)
centerpunch is offline
post #24 of 28 (permalink) Old 10-12-2017, 06:53 AM
Hey, fellow 2011 owners- do your main headlights come on when you start the car?
I thought the white leds were the drls, but on my car the main headlights come on and can't be turned off when the car is on.
I started a thread on the electrical forum here: https://www.lotustalk.com/forums/f322...unning-430170/
post #25 of 28 (permalink) Old 10-13-2017, 04:18 AM
omotilla's Avatar
Hi, mine work OK, only the DRLs (LED white string) are on when I start the car, AFAIK.
My car is a 2013 european version though, I'm so not sure it is 100% the same electrical schema as in the US.
omotilla is offline
post #26 of 28 (permalink) Old 10-15-2017, 08:18 AM
The US cars use the headlights for DRLs, but by unplugging a single wire can be converted to euro spec (white led strips for DRLs).
https://www.lotustalk.com/forums/f322...ml#post5589226
post #27 of 28 (permalink) Old 10-15-2017, 07:03 PM
Originally Posted by amoe View Post
here is the comparison between the region engine and transmission data side by side. If anyone can find more details on the specs. And does that mean the euro specs have different parts.... dare I say...
[CENTER]
Euro
2ZR-FE
Displacement 1798cc
Compression Ratio 10.0:1
Bore 80.5 mm
Stroke 88.3 mm
Weight (without fuel) 97kg (214Ib)
Transmission 6-speed Toyota EC60
1st 3.538
2nd 1.913
3rd 1.310
4th 0.971
5th 0.818
6th 0.700
Reverse 3.333
Final 4.294
Supercharger Magnuson R900 supercharger
US
2ZZ-GE
Displacement 1796cc
Compression Ratio 11.5:1
Bore 82 mm
Stroke 85 mm
Weight (without fuel) 115kg (253.5 Ib)
Transmission 6-speed Toyota C64
1st 3.166
2nd 2.050
3rd 1.481
4th 1.166
5th 0.916
6th 0.815
Reverse 3.250
Final 4.529
Links with info:
https://en.wikipedia.org/wiki/Toyota_ZR_engine#2ZR-FE
https://en.wikipedia.org/wiki/Toyota_ZZ_engine#2ZZ-GE
Lotus Elise Toyota Engine Comments
Toyota Gearboxes - TechWiki
Here's a quickie spreadsheet I did showing the real-world differences between driving with the two gearboxes.
I'd personally prefer the euro tranny. Ratios seems close enough, but cruising would be MUCH more relaxed- 3200 rpm at 80 mph instead of 4000 rpm.
Track guys would disagree.
(jpg attached, plus xls for anyone who wants to change the conditions)
post #28 of 28 (permalink) Old 10-15-2017, 08:56 PM
cain-it's Avatar
A key difference missed above, is the S3 Elise, with the 2ZR-FE supercharged engine, is charge cooled by Lotus, the old 2ZZ version in the Elise wasn't. Power will be a lot more consistent as temps rise.
This is why Lotus pushed a bit further, with minor mods, to offer the Cup 250. Same 2ZR-FE SC CC drivetrain as the standard 220 (all power is measured in PS, not BHP).
For those who miss the S2 Exige S2 240 / 260 power levels, with the small car dynamics, the Elise Cup 250 has effectively taken that place, whereas the Exige V6 feels quite different to drive.
Another key difference is torque. The 2ZR-FE has more torque & lower down than any SC 2ZZ (Lotus OE)
Finally, the gear change on the EC60 is much more precise than the C64 & I've not heard of failures
So although the 2ZZ drivetrain is more 'exotic' than the hum-drum 2ZR-FE, the newer drivetrain still performs OK - thats progress I guess.
Given equal drivers / conditions, I dont feel an Exige Cup 260 (the peak S2 out of the factory) is any faster than an Elise Cup 250... in fact, the Elise Cup 250 might be quicker, as you have better torque to pull out of slower speed corners, less chance of a missed gear change & its easier to place due to better visibility.
Roundabout likes this.
Arabian Elises R US
cain-it is online now
