Airbox delete threads- 05 Elise - LotusTalk - The Lotus Cars Community
post #1 of 11 (permalink) Old 05-08-2019, 08:05 PM Thread Starter
dviolet8981's Avatar
Can anyone post some links to past threads about doing an air box delete for the Elise? Having some trouble finding them after doing a lot of searches. Looking forward to an even louder Elise and a little extra air😎
dviolet8981 is offline
post #2 of 11 (permalink) Old 05-09-2019, 05:41 AM
glb
glb's Avatar
When BOE installed Rev 300, they put in their intake system.
https://www.boefab.com/collections/e...00-400-itg-cab
NOTE: Custom tuning req'd to run this intake.
glb is online now
post #3 of 11 (permalink) Old 05-10-2019, 09:17 PM
Is the reason for “tuning” because of the intake or the size of the throttle body?
As offered by BOE
h20ham is offline
post #4 of 11 (permalink) Old 05-11-2019, 08:56 AM
glb
glb's Avatar
I say to ck with BOE, not me.
glb is online now
post #5 of 11 (permalink) Old 05-12-2019, 11:29 AM
I'm a fan of the smooth tube intake, K&N filter and snorkel delete. This set up basically maximizes the intake's performance without having to deal with MAF scaling or have any concern with heat shielding /water ingestion.
I might enlarge the airbox inlet to get closer to the cup car airbox inlet to get more sound and throttle response out of the system.
white out is offline
post #6 of 11 (permalink) Old 05-18-2019, 08:19 PM
The throttle response makes sense.
I cant imagine much change the sensors cant handle.
As far as colder more dense air, we are talking of dirty, disrupted air. Not clean surface air as from low at the front.
h20ham is offline
post #7 of 11 (permalink) Old 06-05-2019, 02:08 PM
Question... I'm prepping my car for the Torque250, sorting through the mods done before I acquired the car.
The filter/intake was replaced with the red HKS clown nose thing. I'm planning to replace it with the BOE 3" CAI.
Where the ITG Cold Air Box tube goes down to the vent scoop, is there a piece of trim that the tube feeds into? Like that holds in in place to collect and "ram air". Or does the tube just get zip-tied in place down near the side vent?
motorducky is offline
post #8 of 11 (permalink) Old 06-05-2019, 04:09 PM
glb
glb's Avatar
Listen,
BOE are not amateurs. Moreover, their intake is likely to make the biggest difference if it needs a tune. Logic.
You should know that K&Ns are not very good and are often over oiled, which messes things downstream up.
Also, there is little hp gain, if any, with almost all intakes. The 2ZZ is an efficient engine, so gains don't drop from the sky.
Last, pls read the last entry here:
Stock: “Excuse me”
Stebel: “HONK! LOOK OUT!”
3. The early cars came with misaimed and dim headlights. If you drive at night, convert to HIDs. While better than stock halogen bulbs are available, HIDs throw more light. Stay around 5000k. As of this writing LEDs are not as good.
5. Transmission:
The best transmission lube I’ve found is Redline MT-90 plus a little Power Punch Extreme Gear Oil Additive. (Note that it takes two changes to get rid of the previous lube.)
And, use:
https://www.inokinetic.com/lotus/re-...y=Transmission
For street cars, consider removing one or both oil coolers. Some cover them. Oil doesn’t get hot enough on street, leading to cam wiping.
https://www.lotustalk.com/forums/f311...-u-tube-47232/
https://www.lotustalk.com/forums/f320...ramming-70940/
You NEED a digital multimeter (voltmeter) to work on modern cars. Handy around house too. Get one this week.
14. Visit the Uber Thread
https://www.lotustalk.com/forums/f3/e...ow-here-25131/
Plus, “How to bleed brakes”:
https://www.lotustalk.com/forums/f101...brakes-241138/
How to Search:
glb is online now
post #9 of 11 (permalink) Old 06-05-2019, 04:11 PM
glb
glb's Avatar
Same response as #4, above.
glb is online now
post #10 of 11 (permalink) Old 06-06-2019, 04:32 AM
Gunpilot's Avatar
The BOE intake is good stuff. I have one on all 3 of my cars.
It does need to be cleaned periodically. If you get one order some cleaner and oil.
The aero duct on the end just sits down in the scoop area. Not attached to anything.
2012 Evora 2+0 IPS.
2007 Exige mental track toy.
2005 Elise.
1982 Brunette.
"CHARLIE DON'T SURF"
Gunpilot is offline
post #11 of 11 (permalink) Old 06-06-2019, 09:40 AM
Yea, I hate to take his time... especially due to this line from his Torque250 description:
"We cannot assist in sorting or compiling parts to create "used kits""
Similar Threads
WTB: Factory Airbox Piece or Complete Airbox gamefreak32 Parts Wanted 2 02-29-2016 04:06 PM
Brand New Lotus Cup Airbox Lid, Frame & Filter + Used OEM Lower Airbox slightly2ned Parts For Sale 1 12-07-2012 11:16 AM
Cup AirBox (TRD) or 2006 stock Airbox Totus Parts Wanted 2 08-31-2011 07:27 PM
FS: Cup airbox(entire airbox) + TRD filter ZJChaser Parts For Sale 0 06-14-2010 10:03 PM
05 Elise krypton green, sport pack, both tops (threads merged) stormin Lotus Cars For Sale 11 01-15-2009 08:15 AM
