Anyone with an Elise with stock exhaust? - LotusTalk - The Lotus Cars Community
post #1 of 13 (permalink) Old 05-22-2019, 06:07 AM Thread Starter
For anyone with a stock exhaust on a Elise, could I get you to measure the exhaust pipe OD and the center-to-center distance (or outer edge to outer edge) between the two pipes? I want to modify my current stage-2 exhaust to fit the stock non-cut diffuser tray. My plan is to cut-off the expanded stage-2 tips, and re-configure and re-center the outlets to match the stock outlets.
Why, you might reasonably ask? SCCA Auto-X stock rules prohibit body modifications, but allow exhaust changes. While I have my car apart, replacing the previously damaged diffuser with a stock (non-cut) one, I figured I may as well sort this. From an SCCA protest perspective, it's well along on the "truly nit-picking" spectrum of possible items, but I may as well address it while it's convenient as I've tried to ensure everything else is "correct".
PM me or post here if you can measure one up for me. Looked in the exhaust thread, but didn't see anything on this. Thanks much!
truckin-on is offline
post #2 of 13 (permalink) Old 05-22-2019, 06:24 AM
Plural of Lotus is Lotus
OD = 25 mm. Center to center = 30 mm, give or take a few mm's :-)
"If I've passed you on the RIGHT, you are in the WRONG lane!"
JFHughes08088 is offline
post #3 of 13 (permalink) Old 05-22-2019, 06:50 AM
Isn't there an outline in the factory shop manual for the cutout, meaning it is factory approved?
exigegus is offline
post #4 of 13 (permalink) Old 05-22-2019, 07:21 AM Thread Starter
Thank you!
post #5 of 13 (permalink) Old 05-22-2019, 07:42 AM Thread Starter
Not sure about that, but regardless, The stage-2 exhaust is an "aftermarket" part, not available from the factory (as factory installed on the vehicle) so the "body modification" necessary to install it technically doesn't qualify in SCCA stock-class unfortunately. I'm not sure I'll ever again compete at the level at which it matters, but it's one of those things that I may as well put right. Will be interesting to see if the change to smaller outlets alters the sound at all.
post #6 of 13 (permalink) Old 05-22-2019, 07:46 AM Thread Starter
Just confirming - the stock outlet pipes are only 1" (25mm) in outside diameter? Smaller than what I thought. And 30mm center to center means they are only 5mm apart?
The stage-2 pipes are one 56mm pipe splitting into two 43mm pipes, then the larger diameter tips of course at the ends.
post #7 of 13 (permalink) Old 05-22-2019, 07:47 AM
TedR's Avatar
Why not just cut off the wye with the twin tips and weld a single pipe with a 90 degree bend? Lighter and no added restriction.
TedR is offline
post #8 of 13 (permalink) Old 05-22-2019, 12:39 PM
CRG53's Avatar
I think JF got his MM and Inches mixed up.
The outlet pipes on the stock muffler are 2.5" OD and 3" C-C.
Boe REV 300 Supercharger.
Boe DMC Ultimate header.
Boe Clam Hinge.
Boe Pro Alloy Radiator.
Boe TOC wet sump oil pan.
Boe Fuel surge tank.
Boe Oil catch can.
Boe HP fixed rotors with Ferodo DS 2500 pads.
BWR Larini Group B Muffler.
BWR Street/Track Anti roll bar.
Mocal rear mounted oil cooler.
V2 steering arms,
Nitron Singles 425/550.
InoKinetic DS rear toe links.
CRG53 is offline
post #9 of 13 (permalink) Old 05-22-2019, 05:16 PM Thread Starter
Thanks CRG53 - that makes more sense - and appreciate the picture!
post #10 of 13 (permalink) Old 05-23-2019, 07:08 AM Thread Starter
Yes, I may do this - just maintain the one 56mm pipe to the outlet. Simpler for sure and I think it would clear the stock opening. I do wonder if the stage-2 expanded tips have any contribution to the sound and lack of resonance, but I'll shortly find out :-)
post #11 of 13 (permalink) Old 05-23-2019, 12:20 PM
Oops, My bad.
61 (ish) MM outside diameter
76 (ish) MM outside to outside
post #12 of 13 (permalink) Old 05-23-2019, 02:36 PM
CRG53's Avatar
Oops, My bad.
Oops, you did it again.
61mm OD is close, but 76mm outside to outside is way..... off. Take a look at the picture I posted and multiply the inches on the tape with 25.4. You should get something like 140mm.
Boe Clam Hinge.
Boe Oil catch can.
V2 steering arms,
CRG53 is offline
post #13 of 13 (permalink) Old 05-23-2019, 05:37 PM
Diameter is 61 ish MM. Outside to outside (or center to center as the original poster asked) is about 76, or 15 MM between the pipes.
140 MM is to distance of both, including center gap.
I should have better clarified outside to outside as to mean center to center
Similar Threads
FS garage clean-rear panel delete, stock exhaust, stock diffuser, stock NA intake man Tasracer Parts For Sale 3 10-29-2015 12:16 PM
Stock cat stock header stock exhaust Ked67madison Parts For Sale 4 05-10-2013 06:26 PM
$500 - Stock 05 Elise wheels (excellent condition), stock exhaust (make offer) RossPhosphorous Parts For Sale 10 11-30-2012 12:41 PM
Stock Elise exhaust for trade/cash for aftermarket Elise exhaust? PermaGrinNeeded Lotus Elise 1 02-22-2011 06:37 PM
Stock NA exhaust vs Stock ExigeS exhaust scottyb Intake and Exhausts 10 02-06-2008 08:43 PM
