Battery light on! Need Help! - LotusTalk - The Lotus Cars Community
post #1 of 5 (permalink) Old 10-21-2017, 04:56 AM Thread Starter
The battery light on when i start the engine every time, then i raise up above 2000rpm ,the light will flash few times and light off(13V at this moment), after that , the light has not turn on again i keep it idling in 15mins (battery voltage 11V at this moment) Is that mean the alternator has been dying?
Lob Lo is offline
post #2 of 5 (permalink) Old 10-21-2017, 05:02 AM
Probably
Sometimes the wiring going to the alternator can cause a similar issue. When you lose the regulator feed, some alternators will self excite at a higher rpm and then run somewhat normally, tho sometimes weaker at idle.
So check the wiring first, a slim chance there is something wrong there
exigegus is offline
post #3 of 5 (permalink) Old 10-21-2017, 07:52 AM
11 volts at the battery......???
Nessal is offline
post #4 of 5 (permalink) Old 10-23-2017, 07:27 AM Thread Starter
some more information hope helpful
i have try jump start, after the engine started. i disconnected the jump start battery , engine can be run in good and the light off. but i cant start the engine again.
my car is 2002 k series elise
thank you for the advise!!
Lob Lo is offline
post #5 of 5 (permalink) Old 10-23-2017, 07:36 AM Thread Starter
and i hear some noise faintly from the alternator
Lob Lo is offline
