Battery options - Page 2 - LotusTalk - The Lotus Cars Community
 1Likes
post #21 of 41 (permalink) Old 06-11-2019, 06:38 AM
J-Son's Avatar
Will this device make the battery change easier? Seems it might keep power to the alarm and the computer while the battery is removed.
Just plug it to the dash and clips go to jump box clips.
https://www.amazon.com/gp/aw/d/B07LC...ZNY593KR&psc=1
Just want to make sure it would work on our elises before I attempt it.
2005 Ardent Touring Elise,
should i keep it or sell it?!
J-Son is offline
post #22 of 41 (permalink) Old 06-12-2019, 08:28 AM
TedR's Avatar
You don't need it. Just remove the cables from the old battery, negative first. When you connect the new battery, connect the negative last. You will need to reprogram your radio settings, but that should be it.
From your posts in other threads, you may have other issues, but your battery is definitely toast. Once the battery is replaced, report back if it fixed your issues or if you still have some. You might start your own thread instead of pulling up old threads that are not totally relevant.
TedR is offline
post #23 of 41 (permalink) Old 06-12-2019, 08:31 AM
J-Son's Avatar
I just ordered the battery from advance Auto...will pick it up Friday and try to swap it out.
J-Son is offline
post #24 of 41 (permalink) Old 06-14-2019, 04:00 PM
J-Son's Avatar
swapped out the battery and now the car starts....i havent taken it for a drive yet but i noticed the check engine light is on. tomorrow i will hook up an obd scanner and see if i can clear it.
next month the car inspection is due and it wont pass inspection if the check light is on.
J-Son is offline
post #25 of 41 (permalink) Old 06-15-2019, 02:46 PM
J-Son's Avatar
So I hooked up the obd2 reader and it didn't list any codes and looked all fine. Then the gas gauge listed no gas even though it's a full tank and the engine light is still on.
J-Son is offline
post #26 of 41 (permalink) Old 06-15-2019, 03:20 PM
The Enforcer
oldmansan's Avatar
Disconnect the battery and then step on the brake pedal for 10 seconds. Reconnect and check it again. A check engine light will fail you, and at least here in California, you also need all the emmissions systems to show ready. That may take some mileage and/or driving cycles.
There is also a dash reset. Get in the car and I beleive you want to leave the driver's door open. Turn on the ignition and turn it off. Press and hold the trip meter reset button. Turn on the ignition and wait about five seconds. Turn ignition off and release the trip meter reset button. Turn on the ignition and the Service light comes on and goes off after a few seconds.
San
oldmansan is online now
post #27 of 41 (permalink) Old 06-16-2019, 02:33 PM
J-Son's Avatar
battery disconnect and brake step seemed to have fixed the gas gauge.
change engine light is still on though and obd reader says all is ok.
J-Son is offline
post #28 of 41 (permalink) Old 06-17-2019, 08:23 AM
TedR's Avatar
I assume you have tried to clear the codes with the code reader, even though no codes are showing up?
Now that you have a new battery, check the resting voltage. Should be 12.6-ish volts. Now start the car and check the voltage, should be 13.7 to 14.7 volts.
TedR is offline
post #29 of 41 (permalink) Old 06-23-2019, 07:46 AM
J-Son's Avatar
Finally a nice day free of rain. The car started fantastically with the new battery. I drove it around an hour to see if the check engine light would reset...and it didn't.
Now when I check the code it spits out p0630 code. My reset won't clear it. Is this a dealership fix?
J-Son is offline
post #30 of 41 (permalink) Old 06-23-2019, 08:23 AM
Less is Better
me73's Avatar
The standard P0630 code is a VIN error. I expect the dealer would have to address that. There's a recall on our cars for replacing a generic VIN with the specific VIN so you could get that done anyway.
me73 is offline
post #31 of 41 (permalink) Old 06-23-2019, 01:49 PM
The Enforcer
oldmansan's Avatar
I wouldn't bother with the VIN error. If you have a tune, you don't want the dealer flashing your ECU (you'll lose the tune).
San
post #32 of 41 (permalink) Old 06-23-2019, 04:16 PM
CALtd's Avatar
Can't pass CA smog test with VIN error. For NY YMMV.
CALtd is offline
post #33 of 41 (permalink) Old 06-23-2019, 04:22 PM
The Enforcer
oldmansan's Avatar
I had my ECU flashed 8 years ago and I've never had a problem passing the CA testing. There really isn't a 'smog' test anymore in CA as they don't do the sniffer test, at least in my location.
San
post #34 of 41 (permalink) Old 06-23-2019, 08:21 PM
CALtd's Avatar
San
All shops have to connect to ODB and transmit to DMV. If the VIN doesn't match = FAIL. $200 was quote from dealer to reflash VIN. When it only took 15 min, they only charged me $115.50 @ Galpin Lotus.
CALtd is offline
post #35 of 41 (permalink) Old 06-24-2019, 06:03 AM
Less is Better
me73's Avatar
San
I didn't see that @J-Son said he had a tune.
me73 is offline
post #36 of 41 (permalink) Old 06-24-2019, 03:13 PM
The Enforcer
oldmansan's Avatar
Maybe my VIN is correct. Couldn't say.
San
post #37 of 41 (permalink) Old 06-24-2019, 03:15 PM
The Enforcer
oldmansan's Avatar
Neither did I. I said If you have a tune..
San
post #38 of 41 (permalink) Old 07-17-2019, 01:03 PM
J-Son's Avatar
so now i had the lotus dealership tell me to bring it in today...i brought it this morning. they said i had to leave it with them. i told them the error code and the issue. they said they are not sure when they can get to it and they will call me when its done. i told them i wasnt able to reset the code myself and they said the only way i can reset the code is if i became a lotus dealership and had the correct software.
i told them i can stop by on sunday to pick it up and they said...not sure if it will be done by sunday (today is wednesday).
i hope they will fix it somewhat soon since summer is my time to drive it.
so now i wait for the call from them.
J-Son is offline
post #39 of 41 (permalink) Old 07-18-2019, 09:12 AM
EddieA's Avatar
Not my experience last time I had my Exige smoged. It passed with a completely different VIN.
The tech said as long as the paperwork matched the VIN on the windshield, that was all he was required to check.
Cheers.
2007 Exige S. Phantom Black/Black. KoldFire 270 SC.
1993 3000GT VR4. Green, not quite BRG, but close.
1988 Fiero GT. Red. RIP.
EddieA is offline
post #40 of 41 (permalink) Old 07-18-2019, 09:13 AM
J-Son's Avatar
They called. Dealer was able to rewrite the VIN issue. Now they are getting it inspected.
Maybe I will have it back Sunday 😀
J-Son is offline
