Bespoke Titanium Exhaust - Dual Exit - Page 6 - LotusTalk - The Lotus Cars Community
 61Likes
post #101 of 144 (permalink) Old 05-31-2019, 03:00 AM
Originally Posted by KZ3 View Post
Thanks. Still trying to figure out how to mount the plate though. If anyone has any ideas Iím all ears
there are holes for the original panel in the trunk floor
You can bend a simple bracket to pick up those holes and catch the plate holes.
You could weld up a bracket with rods to match the others you have there
Or maybe a horizontal rod going from the verticals
OR , depending on how vicious your local constabulary are, slap it in the back window
exigegus is offline
post #102 of 144 (permalink) Old 05-31-2019, 03:59 AM
VisualEchos's Avatar
So it's available in angled-tip and straight-tip?
2006 Exige
VisualEchos is offline
post #103 of 144 (permalink) Old 05-31-2019, 05:07 AM
Saffron Yellow is Lighter
XtinctElise's Avatar
Arrow Just Say No
One more pic:
Can you get the tips without that engraving?
XtinctElise is offline
post #104 of 144 (permalink) Old 05-31-2019, 05:18 AM Thread Starter
Check with Millionaire. Theyíd probably do it.
addliteness is offline
post #105 of 144 (permalink) Old 05-31-2019, 05:20 AM
Brandonm84's Avatar
Yes, I requested mine without and thatís how I got it.
VisualEchos likes this.
Brandonm84 is online now
post #106 of 144 (permalink) Old 05-31-2019, 05:26 AM Thread Starter
Not sure. But they probably want their branding on there. Check with Millionaire.
post #107 of 144 (permalink) Old 05-31-2019, 07:41 AM
titaniumdave's Avatar
Anyone done an install with a clam hinge? Looking to set the car up with a BOE hinge but running into clearance issues...wondering if there is a solution that has worked before we start making parts...
2006 Elise with BOE 400 supercharger and some aero mods, CRF floating oversized rotors, MCS single adjust coil overs, CRF exhaust, CRF sway bar w/adjustable link, mono-ball pivots, machined steer arms, baffled oil pan, CRF titanium toe link brace, hardened motor mounts, Ethos wheels w/Yoko slicks
titaniumdave is offline
post #108 of 144 (permalink) Old 05-31-2019, 10:07 AM Thread Starter
I have the hinge and had issues with my Larini. I donít have the ability to shorten the cable, so I basically wrapped it around the mount point once to effectively shorten it. That then stopped the clam just before it made contact with the tips. You donít have quite as much access but it worked. I havenít tried since installing the titanium exhaust but given that the exit points are the same as the Larini, I donít foresee any issues.
post #109 of 144 (permalink) Old 05-31-2019, 10:09 AM Thread Starter
Originally Posted by ManuelG1986 View Post
Damn this thing has many angles and why has one tip 2 silencers and the other one only 1?
Isn't there a Version with just one Silencer and a straight side tip possible? - Like the BOE Featherweight?
It has resonators on both outlets. Check original post.
post #110 of 144 (permalink) Old 05-31-2019, 10:21 AM
NoRawkus305's Avatar
@KZ3 How does it sound with your setup? Do you get the gurgles and pop? Flames even with no supercharger? Man, this is truly tempting. After Brandon's vid, I can't stop thinking about scooping one up lol. TIA
2002 Honda S2000 - RIP MAY 2012
2005 Lotus Elise Sport and Touring Package - Weekend Warrior
2015 NX200T F-Sport - DD and Winter Beater
2006 Hummer H3 - The wife's
NoRawkus305 is online now
post #111 of 144 (permalink) Old 05-31-2019, 10:25 AM
KZ3
KZ3's Avatar
Yes, tons of gurgles and pops. I can make it sound like similar to an F type on decel
NoRawkus305 likes this.
2007 Chrome Orange Elise
KZ3 is offline
post #112 of 144 (permalink) Old 05-31-2019, 02:08 PM
What rear support did you use? Pics please...
post #113 of 144 (permalink) Old 05-31-2019, 02:11 PM Thread Starter
Rear support for what? The diffuser? Mineís GRP, but you have to remove that to tilt clam.
post #114 of 144 (permalink) Old 05-31-2019, 02:34 PM
Got it, was trying to do the BOE style where the clam can tilt with the support in place.
post #115 of 144 (permalink) Old 06-01-2019, 02:21 PM
Just pulled the trigger on mines. Sucks I didnít see it earlier and get in the group buy.
jhentr is offline
post #116 of 144 (permalink) Old 06-02-2019, 02:41 AM
Anyone else interested in another group buy (not sure how many people they would need to offer the same part)? Now that they have the jigs, hopefully wouldn’t need a lot.
jsottile is offline
post #117 of 144 (permalink) Old 06-02-2019, 06:38 AM
My single order was $1895. Not sure how many for a GB but last GB had 8 orders for $1600.
You can contact Millionaire (wolf) for more info. I would guesstimate 5 or more...
jhentr is offline
post #118 of 144 (permalink) Old 06-02-2019, 09:41 AM
I confirmed, we would need 5 total. I would be in if we could do meet it.
jsottile is offline
post #119 of 144 (permalink) Old 06-03-2019, 07:46 AM
Here is what I did to make the BOE clam hinge support work, looks like it will all clear with no removal of parts. Still need to limit the cable length so the tips don’t touch the clam will be my guess...
addliteness likes this.
post #120 of 144 (permalink) Old 06-03-2019, 07:54 AM
Also made a set of adjustable exhaust hanger mounts so I could align the tips and get them to sit level. These also lower the tips a bit so hopefully they won’t burn the edge of the clam.
Similar Threads
FS: Larini SE dual tip exhaust, rear exit ///MD Parts For Sale 2 10-23-2013 01:50 AM
Lotus Reveals Bespoke Engine On Facebook AutoGuide.com Front Page News 33 02-11-2012 12:06 PM
FS: Arqray Full Titanium Dual Euro Exit ZTEC Parts For Sale 14 11-19-2010 01:29 PM
