Blinkers only work when hazard button depressed - LotusTalk - The Lotus Cars Community
post #1 of 3 (permalink) Old 08-31-2019, 03:28 PM Thread Starter
fv9
I read several posts about blinker problems. My 05 Elise just developed this. Blinkers and hazards do not work on their own. Light work when I lock the car with the fob. Blinkers work when the hazard light switch is pressed. Fuses are fine. Bad hazard switch? Thanks!
fv9 is offline
post #2 of 3 (permalink) Old 08-31-2019, 04:45 PM
Jetblast's Avatar
Originally Posted by fv9 View Post
Bad hazard switch?
You said you checked the fuses, did you mean fuses F6 and F9? There is a (small) chance it could be the flasher module itself but I'd guess the problem is the hazard flasher switch; they seem to be the most common problem for directional indicator and hazard light problems.
Jetblast is offline
post #3 of 3 (permalink) Old 08-31-2019, 06:26 PM Thread Starter
fv9
Bad hazard switch?
Yes, fuses were good. Seems plenty of people have had hazard switch issues that led to similar symptoms. Probably a good bet to just replace it I’m thinking.
fv9 is offline
