BOE Pro Alloy or Inokinetic Champrad + RADhoses - LotusTalk - The Lotus Cars Community
 5Likes
  • 1 Post By GregsRaceParts
  • 1 Post By Ghia914
  • 1 Post By ScottH83
  • 1 Post By mwehnes
  • 1 Post By SergeLotus
post #1 of 14 (permalink) Old 09-10-2019, 09:11 AM Thread Starter
Verichai's Avatar
Are these units similar? Any owner insight would be appreciated. Not sure which to go with for mostly street driving with occasional track duty.
Also Ino's GPAN3 or BOE's baffeled pan?
These products look very similar...
Thanks in advance!
Verichai is offline
post #2 of 14 (permalink) Old 09-12-2019, 07:41 PM
They are all functionally the same.
Pick which ever vendor offers the best price and service.
111Joe is offline
post #3 of 14 (permalink) Old 09-13-2019, 08:28 AM
senna's daddy's Avatar
I went with the 27MM DENSO F1 RADIATOR, it's a beautiful piece of welded aluminum bits, and feather-light - you can easily hold it up with one hand.
https://www.blackwatchracing.com/product-p/1215.htm
senna's daddy is offline
post #4 of 14 (permalink) Old 09-13-2019, 08:36 AM
Rizzydee's Avatar
Another option is Koyorad Racing. They made an aluminum radiator for the Elise/Exige and is a lot cheaper than the other two options. Think mine was $320.
http://koyoradracing.com/news.asp?id=152
Rizzydee is offline
post #5 of 14 (permalink) Old 09-18-2019, 12:45 PM Thread Starter
Verichai's Avatar
@senna's daddy and @Rizzydee , some great suggestions, thank you.
I'm wondering about the baffled oil pans.
@111Joe , Does the BOE pan work with a Fumoto valve? From searching the forum, it seems the BOW pan does accomidate one while the GPAN3 does not.
Also, can the GPAN3 be used with the BOE gasket instead of permatex?
Verichai is offline
post #6 of 14 (permalink) Old 09-18-2019, 12:51 PM
Elise Guru
GregsRaceParts's Avatar
We carry the Koyo as well as the Wizard radiators: https://www.gregsraceparts.com/colle...lise-exige-211
Feel free to email with any questions if interested!
Verichai likes this.
Check out GregsRaceParts.com for all of your Elise, Exige and Evora parts needs!
Email:[email protected]
IG: @gregsraceparts
FB: @gregsraceparts
GregsRaceParts is offline
post #7 of 14 (permalink) Old 09-18-2019, 12:53 PM
Ghia914's Avatar
I went with InoKinetic's ChampRad and silicone hose combo. I have more than 2 years of daily driving on it with no issues. Even with the hoses included, it was a decent savings over the ProAlloy. It's basically an Asian-sourced copy, as many of the other less expensive alternatives mentioned in this thread likely are.
This is the site for Champion Cooling Systems (the supplier of the ChampRad): https://www.championcooling.com/
Ghia914 is offline
post #8 of 14 (permalink) Old 09-18-2019, 02:00 PM
Yes. Thats what I did.
Sent from my SM-G950U using Tapatalk
ScottH83 is offline
post #9 of 14 (permalink) Old 09-18-2019, 02:10 PM
ArizonaExige's Avatar
Arrow 27MM DENSO F1 RADIATOR ----> BWR
I'll put in another vote for the thinner 27MM DENSO F1 RADIATOR with the silicone hoses.
08 Exige S240 - Chrome Orange
ArizonaExige is offline
post #10 of 14 (permalink) Old 09-18-2019, 04:43 PM
@Verichai For your described use any radiator will work fine. The F1 is overkill for street driving.
Cleaning your AC condenser and straightening the fins (assuming you have the stock fans installed, they tend to mangle it) will make more of a difference than different models of radiators.
mwehnes is offline
post #11 of 14 (permalink) Old 09-18-2019, 05:40 PM Thread Starter
Verichai's Avatar
Can anyone confirm the Fumoto valves on the oil pans? I got spoiled by the use of the F-valve on my other cars for making oil changes much neater, and would prefer to be able to use on the Elise after the pan replacement.
Verichai is offline
post #12 of 14 (permalink) Old 09-19-2019, 07:30 PM
I use an EZ Oil drain valve (Fumoto competitor) on mine. Once you decide which pan to buy just ask them the thread size and pitch and then by one that matches. Amazon carries these.
mwehnes is offline
post #13 of 14 (permalink) Old Yesterday, 07:45 PM
SergeLotus's Avatar
I went with Inokinetic's Champrad. I haven't had any issues in 13 months and 7,000 miles. No leaks or funny noises. Thermostat stays constant at about 194 degrees even in summer months. A/C works great. I had the radiator installed as a precautionary measure when I bought the car, given all the horror stories about the OEM radiator.
SergeLotus is offline
post #14 of 14 (permalink) Old Yesterday, 10:35 PM Thread Starter
Verichai's Avatar
Good to know yours is functioning well and right on, good call. That's what I'm doing as well...precaution.
Verichai is offline
